fuzzystuff4ever
Reged: 11/26/12
Loc: Micco, FL
Smaller counterweight for CG5 mount? new
      #5541646 - 11/27/12 08:14 AM
First, hello to everyone as I have just joined. My question: does anyone sell a smaller (less than 11 lb.) counterweight which will fit the CG5 dec shaft? I have some smaller scopes (SV66, C90, etc.) which cannot balance with the 11 lb. weight. Orion has a 7.5 lb. weight advertised but I don't know if the hole diameter will fit. Thanks.
RTLR 12
Reged: 12/04/08
Loc: Capistrano Beach, Ca
Re: Smaller counterweight for CG5 mount? new [Re: fuzzystuff4ever]
      #5541762 - 11/27/12 10:04 AM
The Orion fit perfectly. I have 2 of them for use with my CG-5s. Also Celestron use to supply the C6N ASGT with a 7½ lb and a 4 lb counter weight. Celestron does not sell them, but I have found them used.
Stan
tjay
Reged: 02/03/07
Loc: just outside of Toronto
Re: Smaller counterweight for CG5 mount? new [Re: RTLR 12]
      #5543964 - 11/28/12 02:15 PM
I bought the SkyWatcher 3.42&1.8 kg (7.5 and 4 lbs) set from here and they work fine with my CG5:
http://www.kwtelescope.com/SW_Mounts.htm
Agatha
Reged: 06/04/12
Loc: Minneapolis, MN
      #5544061 - 11/28/12 03:17 PM
I have a couple of Vixen counterweights that are less weight. One is 6.2 pounds and the other is 4.2 pounds. They are very handy for lightweight scopes and I love the white color. Much easier to see. Good luck.
Best, Linda B.
Agatha
Reged: 06/04/12
      #5544078 - 11/28/12 03:23 PM
Oops, forgot to mention that they both fit the CG-5 counterweight shaft beautifully.
Linda B.
fuzzystuff4ever
Reged: 11/26/12
Loc: Micco, FL
Re: Smaller counterweight for CG5 mount? new [Re: Agatha]
      #5547206 - 11/30/12 01:12 PM
Thanks everyone for the responses. The Skywatcher ones look like a good idea, but it seems I may have to get them from a Canadian vendor (if possible); none of the American Skywatcher dealers seem to carry them.
Brian
RTLR 12
Reged: 12/04/08
      #5547214 - 11/30/12 01:16 PM
Orion has the 7½ lb counter weight.
http://www.telescope.com/Mounts-Tripods/Mount-Tripod-Accessories/Orion-Counte...
Stan
fuzzystuff4ever
Reged: 11/26/12
Loc: Micco, FL
      #5547233 - 11/30/12 01:30 PM
Stan;
I saw those on their site just a couple of weeks ago, and I may have been hallucinating but I remember the ad stating that they fit the CG5 mount as well, but it doesn't say that anymore. Since it's Orion I can always return it if necessary if it doesn't fit. Thanks.
Brian
RTLR 12
Reged: 12/04/08
      #5547276 - 11/30/12 01:55 PM Attachment (18 downloads)
Here's one on one of my CG-5s...
Stan
fuzzystuff4ever
Reged: 11/26/12
Loc: Micco, FL
      #5547357 - 11/30/12 03:00 PM
Stan;
Looks like a winner. BTW, very pretty setup with the shiny black WO.
Brian
RTLR 12
Reged: 12/04/08
      #5547390 - 11/30/12 03:23 PM
Thanks...It's actually a Celestron Onyx 80 EDF. I added a WO retro 2 speed focuser.
Stan
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: Smaller counterweight for CG5 mount? [Re: RTLR 12]
      #5550568 - 12/02/12 03:42 PM
For light counter weights you can use a length of 16mm all thread, a couple of nuts and as meny washers as you need. 1" washers are a nice weight but you'll have to find some 3/4" thin walled tube to fit over the all thread to center them on the all thread.
19 registered and 38 anonymous users are browsing this forum.
