Privacy Policy |
Please read our Terms
of Service | Signup and
makintosz
Reged: 01/14/09
SBIG ST-2000XM and changed e-/ADU
#5553336 - 12/04/12 04:26 AM
Hello,
Recently I bought from someone an SBIG ST-2000XM Camera.
I did few tests and I found that Standard Deviation in bias frames i about 2,5x higher than my ST-2000XCM (now sold).
It was weird since both cams have same chip KAF 2020 etc.. so I searched further.
What I finally found is that e-/ADU is changed from oryginal 0.6 value to 0.26.
What can I do to switch it back to oryginal ? I dont want to return it to the guy I bought it since everything else is working fine.
I tried to contact SBIG about it to no avail so far... I searched whole internet and didnt found any solution.
Dear Forum Members, Can You help me ?
Thanks in advance!
Michal
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: SBIG ST-2000XM and changed e-/ADU
[Re: makintosz]
#5553385 - 12/04/12 06:14 AM
Wrong forum. Try emailing SBIG again, they're definitely the best source for this type of information.
ccs_hello
Reged: 07/03/04
[Re: makintosz]
#5553545 - 12/04/12 08:37 AM
Michal,
Definitely wrong subforum. You can also try CCD subforum.
For others:
a useful info to compare astroimager with others...
(Many high-end) astro-imagers tend to be designed/optimized with a factory preset gain (ISO / gain / e-/ADU), post the actual sensor output stage. Many models are factory fixed at a preset value (though still modifiable) not easily modified through menu setting by the end-user. The value chosen tends to be optimized toward the best possible S/N for the optimal image quality, not the highest possible gain (some loosely call it sensitivity.)
Clear Skies!
ccs_hello
makintosz
Reged: 01/14/09
[Re: ccs_hello]
#5553652 - 12/04/12 09:50 AM
Thanks, I will post it in the CCD forum. I tought that CCD forum is more for imaging and procesing in itself.
6 registered and 8 anonymous users are browsing this forum.
Moderator: Undermidnight, knuklhdastnmr
