jareddewitt
Reged: 05/23/12
Adding a filter for astrophotography new
      #5554834 - 12/04/12 11:15 PM Attachment (12 downloads)
I recently purchased a 2" Orion SkyGlow to use for astrophotography in my urban area. I feel so stupid though because I can't figure out where screw it in. None of the threads in my optical path allow for it. The picture attached is my optical path.
Fotodiox DSLR adaptor -> T-Ring -> focal reducer -> micro focuser adapter.
So as you can imagine, the DSLR camera would hook up at the left, and then tighten in to the microfocuser on the right.
I've tried searching for fotodiox filter threads but so far have come up short. Any suggestions?
howard929
Member
Reged: 01/02/11
Loc: Low End of High Ground
Re: Adding a filter for astrophotography new [Re: jareddewitt]
      #5555375 - 12/05/12 09:53 AM
A filter can be inserted anywhere in the optical path even in front of a diagonal if you have one.
Is the problem that there isn't any internal threads for that filter or that there is threads but the filter won't thread into it.
jareddewitt
Reged: 05/23/12
Re: Adding a filter for astrophotography [Re: howard929]
      #5556109 - 12/05/12 06:12 PM
Thanks for the reply.
There seems to be threading in multiple spots like in the T-Ring adapter but the filter's threads don't match up. It will if on the diagonal, but I'd rather not use that for astrophotography.
howard929
Member
Reged: 01/02/11
      #5556260 - 12/05/12 07:28 PM
Don't know if this is the issue you're having. I was unable to thread any of 3 or 4 2" Orion filters into any of the 2" TV eyepieces the store had in stock. I passed on it and bought a Lumicon because it did.
jareddewitt
Reged: 05/23/12
Re: Adding a filter for astrophotography new [Re: howard929]
      #5559214 - 12/07/12 12:22 PM
Thanks, I might just give that a try.
jareddewitt
Reged: 05/23/12
      #5559620 - 12/07/12 05:10 PM
I actually found a T-Ring adapter by Baader that has an internal filter bay. Just bought it, hopefully it will work out to replace my current EOS t-ring.
http://www.telescopes.com/telescope-accessories/photographic/baaderplanetariu...
oo_void
Reged: 11/13/09
Loc: San Francisco, CA
      #5559672 - 12/07/12 05:45 PM
Orion filters have notoriously bad threading. You can either complain and send it back (maybe Orion will finally get the message), or you can just slowly work the filter on something that accepts 2" threads the losen it up. Make sure to avoid optics though (I used a extension tube) because you don't want to make a mess with paint flakes or metal spurs dropping onto it. Even after all this, the best I get with mine is about halfway in.
Edited by oo_void (12/07/12 05:47 PM)
jareddewitt
Reged: 05/23/12
Re: Adding a filter for astrophotography new [Re: oo_void]
      #5560158 - 12/07/12 11:30 PM
Yeah, funny you mention that because right out of the box I noticed the filters glass was chipped near the edges. I might just return it based on that. So far not too impressed, especially since it cost $160.
23 registered and 22 anonymous users are browsing this forum.
