svthomas
Reged: 09/09/11
Loc: Billings, MT. USA
Baader VariLock T2 Extension Tube 29-46mm
#5555854 - 12/05/12 03:25 PM
I just purchased a used QHY8 camera, and I am now shopping for spacers to get the proper distance between the Field Flattener (AT2FF) and the sensor. I came across the following product, and am curious if anyone has any experience or thoughts on it. Would this be rigid enough? The reason I ask is that this would actually be convenient when switching between a reducer/flattener to a standard flattener when changing scopes, as the corrective products I will be using require different spacing.
Link to said product: http://www.optcorp.com/product.aspx?pid=15087&kw=VariLock&st=2
Thanks in advance for your help.
-SV
tecmage
Reged: 01/13/10
Loc: Groton, CT
Re: Baader VariLock T2 Extension Tube 29-46mm
[Re: svthomas]
#5556149 - 12/05/12 06:33 PM
wolfman_4_ever
Reged: 07/15/11
Loc: El Segundo, Ca, So. Cal
[Re: tecmage]
#5556345 - 12/05/12 08:18 PM
Works Great!
psandelle
Reged: 06/18/08
Loc: Los Angeles
[Re: wolfman_4_ever]
#5556354 - 12/05/12 08:23 PM
I second the "works great" notion. The guys from Boren-Simon (the PowerNewt guys) were the ones who first suggested it to me, so if they were good with it, I figured I'd be good with it. Easy, straightforward, no flex. I have the shorter one as well, for when I use a filter tray.
Paul
WadeH237
Reged: 02/24/07
Loc: Snohomish, WA
[Re: psandelle]
#5556635 - 12/05/12 11:03 PM
I have an AT6RC with *lots* of imaging equipment on it. I have one of these extensions between my rotator and ST10/CFW8. My Optec focuser has only 0.6" of travel, so the spacing needed to be precise. Instead of having a custom spacer machined, I got the VariLock.
The VariLock works beautifully. I have the sensor on my ST10 right in the middle of that short range.
wolfman_4_ever
Reged: 07/15/11
[Re: WadeH237]
#5556659 - 12/05/12 11:25 PM
Pretty much anything from Baader "Works Great"!
Mike Wiles
Reged: 02/04/09
Loc: Goodyear, AZ
[Re: svthomas]
#5556686 - 12/05/12 11:46 PM
I used one to get the spacing correct between a QHY8PRO camera and a Hotech field flattener...essentially the exact same thing you're asking. It was a perfect solution. You should order one. You'll be happy.
svthomas
Reged: 09/09/11
[Re: Mike Wiles]
#5556805 - 12/06/12 02:10 AM
Fantastic, thanks for the help everyone--always nice to see such positive feedback. I will get one of these ordered tomorrow and check it off of my list.
-SV
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
[Re: svthomas]
#5556927 - 12/06/12 06:13 AM
I just bought one these too . Like everyone said, anything from Baader works just great so I took a plunge. Good review on Agena as well.
18 registered and 28 anonymous users are browsing this forum.
Moderator: Oldfield, bilgebay
