azerrad15
newbie
Reged: 06/01/12
Any way to adapt a Takahashi Mamiya 645 mount?
      #5557670 - 12/06/12 02:44 PM
Hello, just thought I would throw this out there. I've done some considerable googling on this to no avail.
I have a Takahashi Mamiya mount and I would like to adapt it to use on a standard 2" tube. I realize that I would get some or perhaps a lot of vignetting on my Phase One back but would like to give it a shot as long as I don't have to tear up the mount adapter itself to try?
The Tak Mamiya mount adapter is a standard Mamiya camera mount on one side but has male threads on the other side with a diameter of approx 71 or 72 mm. Not sure of the thread size.
Any feedback would be greatly appreciated!
Thanks...
TxStars
Reged: 10/01/05
Loc: Lost In Space
Re: Any way to adapt a Takahashi Mamiya 645 mount? new [Re: azerrad15]
      #5560345 - 12/08/12 02:19 AM
The Mamiya 645 coupler for the FC/FS-100/125 has a 72mm thread.
Precise Parts could make an adapter for you:
http://www.preciseparts.com/ppmain/index.html
Yes your image circle will be reduced to the smallest I.D. of your focusing system.
Which scope are you trying to put it on?
azerrad15
newbie
Reged: 06/01/12
Re: Any way to adapt a Takahashi Mamiya 645 mount? new [Re: TxStars]
      #5560571 - 12/08/12 09:33 AM
Thanks for the reply. In this case it's a TV85. I have tested out the scenario by placing a simple Orion 2" draw tube against the inside of the 645 Tak adapter and snapping a few pics through the scope. It appears to work okay with a bit of vignetting.
I considered cementing the draw tube to the adapter with JB Weld but that would basically ruin the adapter and the end goal is to mate it with a TSA-102 once funding permits.
I like the idea of having these folks build a custom adapter. It would have to be a female 72mm Tak on one end to a 2" drawtube. I would think I would want it to be a few inches long so I could experiment with correct image plane distance by simply moving the tube in and out. I have not been able to locate anything with these basic requirements.
Thanks for the tip, I'll give these guys a call and go from there,
piaras
Reged: 01/26/09
Loc: Niagara Region
      #5564988 - 12/10/12 10:08 PM Attachment (9 downloads)
Not to highjack your thread, but I built a Phase One digital back to Canon FD lens body to play with.
I do like the idea of the MF lenses since the Pentax 67/645s are cheaper than current EOS lenses.
Maybe it will be the next step.
15 registered and 24 anonymous users are browsing this forum.
Moderator:  zjc26138, tecmage, rflinn68
