Pinbout
Reged: 02/22/10
Loc: Montclair
McMaster Carr's 3d Models
      #5560561 - 12/08/12 09:27 AM
I use cad a lot, I use McMasters a lot. I never played with their 3d models.
Duh!
Last night I had some free time so I tried several of their 3d formats and it locked my program up, until I imported the *.sat files. They didn't import to autocad but they import into my 3dviz.
the *.sat files import into viz so easily, I was like wow why didn't I do this before. wow, I can actually use the washers, shoulder bolts and everything to layout my 6point cell. Its so nice to be able to see that the 3-1/2in long hex head cap screw didn't work, so lets see the 4-1/2in and not spend money. they even had the black nylon acorn nuts and external tooth washers.
and how doesn't the spherical bearing fit, height/width, compared to the oval top distorted nut? wow the oval top distorted nut would make things lower, but spherical bearings are so nice...
It was fun laying this out with real parts instead of schematically deriving the parts.
the only part they didn't have was the wire rope single saddle clips to attach the wire rope around the linear bearings.
The linear bearigns came with the clips that were editable but the eyebolts come with the nuts attached, and I couldn't edit them out.
and since I already made my mirror box and cell, lets just see if my design of the tailgate clears against real parts.
Yes, another test that proves success!
GpB311
Reged: 05/29/12
Loc: Los Angeles, CA
Re: McMaster Carr's 3d Models new [Re: Pinbout]
      #5560723 - 12/08/12 11:25 AM
We use their parts fairly frequently in a solidworks and an autodesk inventor class Im taking. I just ordered something from them for the first time on Thursday and one of my items arrived the next day. Great service, maybe not the cheapest prices, but I love that so many of their parts and such are available for download in multiple formats.
zippeee
Reged: 12/27/10
Loc: Alberta, Canada
Re: McMaster Carr's 3d Models new [Re: GpB311]
      #5561155 - 12/08/12 04:28 PM
I'm a heavy CAD user too. I never even knew they had those files available, that's awesome!
Pinbout
Reged: 02/22/10
Loc: Montclair
      #5561293 - 12/08/12 06:17 PM
yeah somethings aren't the cheapest but that next day shipping is very inexpensive.
careysub
Reged: 02/18/11
Loc: Rancho Cucamonga, CA
      #5564052 - 12/10/12 12:10 PM
Often times there stuff really is cheap compared to most sources, and don't forget the time savings.
Trying to hunt up a lot of stuff in hardware stores is time-consuming if not outright futile.
The biggest problem I see is the minimum quantity (for fasteners, say) - on a per piece basis it is really cheap, but you need to buy a bag or box of 10, 25, 50 or 100.
Pinbout
Reged: 02/22/10
Loc: Montclair
Re: McMaster Carr's 3d Models new [Re: careysub]
      #5564060 - 12/10/12 12:15 PM
and they even have 3d models of your "star" nuts.
Pinbout
Reged: 02/22/10
Loc: Montclair
      #5619751 - 01/12/13 08:08 PM
here's a mirror cell teeter totter with mcmaster-carr parts in sketch-up.
ccaissie
Reged: 09/13/10
Loc: Whitefield, Maine
      #5619891 - 01/12/13 10:04 PM
Careful when you rotate the view. You'll have parts in your lap.
Pinbout
Reged: 02/22/10
Loc: Montclair
Re: McMaster Carr's 3d Models new [Re: ccaissie]
      #5619942 - 01/12/13 10:33 PM
really?
I could put the entire cell cause sketchup has a 10meg limit.
I was really suprised how the kydex ring turns a bunch of floppy sloppy parts into a real spring loaded system.
Pinbout
Reged: 02/22/10
Loc: Montclair
      #5619951 - 01/12/13 10:39 PM
here's another model I couldn't load cause their goofy limit. but since I took out the threaded rod and just used cylinders the same size this model is up there now...
Edited by Pinbout (01/13/13 09:31 AM)
jonathanCR
Reged: 07/02/07
Loc: Costa Rica
      #5625562 - 01/16/13 01:50 AM
Nice work, I really hate the size limit in the 3D warehouse.
don clement
Vendor (Clement Focuser)
Reged: 02/02/11
Loc: Running Springs, California
      #5625738 - 01/16/13 07:56 AM
I live up in the So. Cal Mountains and use McMaster-Carr. Typically McMaster-Carr ships UPS ground out of Santa Fe Springs and if I order on a business weekday Mon-Thursday even as late as 6PM my order will arrive on my doorstep the next day. If I really need a part I can call and pick the part up at will call in Santa Fe Springs, a straight drive down the 330 across the 210 and down the 605. Then there is always McFadden-Dale industrial hardware closer by in Ontario or Corona http://www.mcfadden-dale.com/.
Don Clement
Pinbout
Reged: 02/22/10
Loc: Montclair
Re: McMaster Carr's 3d Models new [Re: jonathanCR]
      #5625829 - 01/16/13 09:18 AM
gracias
Pinbout
Reged: 02/22/10
Loc: Montclair
Re: McMaster Carr's 3d Models new [Re: don clement]
      #5625835 - 01/16/13 09:21 AM
yeah, I have a McMaster dist center about an hour away, if I really need it I could drive down and pick it up.
boy I wish I still had my YMAX 14-40 lathe with DRO!!!
Pinbout
Reged: 02/22/10
Loc: Montclair
      #5628624 - 01/17/13 06:27 PM Attachment (8 downloads)
just put up a craford focuser...although I had to replace the threads with cylinders to keep the files size down...
skywolf856
Reged: 01/25/08
Loc: SE Michigan
      #5628730 - 01/17/13 07:43 PM
Yea use 'em and love it!
Just about anything industrial that you want has a cad file available. Not like the old day's when you had to draw it from scratch! I don't miss getting pencil lead all over my shirt!
15 registered and 33 anonymous users are browsing this forum.
