Telescope Specific Forums >> Meade LX
curiosidad
Reged: 06/09/11
ETX 90 like soptting scope? new
      #5559678 - 12/07/12 05:51 PM
Hello,
Anyone use this ETX 90 optical tube like a spotting scope for day birding?
Good results?
jgraham
Reged: 12/02/04
Loc: Miami Valley Astronomical Soci...
Re: ETX 90 like soptting scope? new [Re: curiosidad]
      #5560041 - 12/07/12 10:08 PM
It should work fine on a good tripod. I've used the Orion 90mm tabletop Mak as a spotting scope and it worked very well.
moynihan
Reged: 07/22/03
Loc: Lake Michigan Watershed
Re: ETX 90 like soptting scope? new [Re: jgraham]
      #5560551 - 12/08/12 09:21 AM
I have used an ETX 90 OTA as a spotting scope, when i needed high magnification and a good stand off distance. Found it to work well.
dengwer
Reged: 02/14/06
Loc: Texas
Re: ETX 90 like soptting scope? new [Re: moynihan]
      #5561512 - 12/08/12 09:08 PM
We take photos through my wife's ETX90 out of our car window using a sony cybershot and 40mm eyepiece. Here is one example of hundreds of pics.
dengwer
Reged: 02/14/06
Loc: Texas
Re: ETX 90 like soptting scope? new [Re: dengwer]
      #5561523 - 12/08/12 09:18 PM Attachment (96 downloads)
oops now to upload photo
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #5562345 - 12/09/12 12:21 PM
I keep one at the lake on a DS2000 mount for use as a spotter and observing. The 45 deg. erect image diagonal is best for spotting.
moynihan
Reged: 07/22/03
      #5562493 - 12/09/12 01:48 PM
Very nice
FeynmanFan
Reged: 02/18/11
Loc: N Colo front range
Re: ETX 90 like soptting scope? [Re: moynihan]
      #5562539 - 12/09/12 02:15 PM
They make great spotting scopes. I use mine as such when target shooting. If you think night time thermals are bad, try looking across 100 yards of sun-baked prairie!
seeindoubles
Reged: 01/15/12
Loc: Pacific Northwest-Oregon
Re: ETX 90 like soptting scope? new [Re: FeynmanFan]
      #5886530 - 05/27/13 03:10 AM Attachment (54 downloads)
Mine works great for birding. Just took this shot of the Western Tanager that hangs out in the backyard today. Used my Canon EOS with remote release through my PC.
cpsTN
Reged: 04/26/07
Loc: Rutherford Co, TN
Re: ETX 90 like soptting scope? new [Re: seeindoubles]
      #5886798 - 05/27/13 10:32 AM
I have a SkyWatcher 90mm Mak (1250mm FL) and Orion's F2-HD tripod and I use it with a 25mm EP (50x) or a 40mm EP (32x) for birding, plane watching, etc. Works great. This is the same one as the Orion Apex 90 I used to have. The ETX (used to own as well) should work better due to better optics.
Edited by cpsTN (05/27/13 10:35 AM)
REC
Reged: 10/20/10
Loc: NC
      #5886899 - 05/27/13 11:20 AM
Yep, have mine now for 15 yrs. and still works great! Keep it on a lightweight tripod all the time ready to check out the birds ans also have a solar filter in it for sunspots.
Bob
Mike Cook
Reged: 07/13/08
Loc: Moncton NB (Cloud Central)
Re: ETX 90 like soptting scope? new [Re: REC]
      #5887319 - 05/27/13 03:25 PM
I've used my ETX 125PE to bird watch. Focusing can be slow, spinning the focus knob quite a bit but I have a lot of fun with it.
highertheflyer
Reged: 07/08/05
Loc: Ft. Worth, Texas
Re: ETX 90 like soptting scope? new [Re: Mike Cook]
      #5887682 - 05/27/13 07:07 PM
Can one show us your camera to ETX setup?
I have a number of these and would like to capture views like yours.
seeindoubles
Reged: 01/15/12
Re: ETX 90 like spotting scope. new [Re: highertheflyer]
      #5888234 - 05/28/13 01:02 AM
I use a Meade rear cell adapter that I purchased from OPT for $19.95. I have attached a photo here. It screws onto the threads of the sub-diameter rear port. Once installed it allows use of standard SCT accessories including photo adapters, eyepiece holders and even off axis guiders. For photos I use a SCT prime focus adapter coupled to my camera. For a slightly wider field of view I thread on my Celestron focal reducer first, then couple the prime focus adapter to the back of that. You gain perhaps 15% extra field of view that way on the ETX. The Tanager photo I posted earlier was from about 45 feet with just the SCT prime focus adapter.
Edited by Starman27 (06/24/13 08:31 AM)
seeindoubles
Reged: 01/15/12
Re: ETX 90 like spotting scope. new [Re: seeindoubles]
      #5888269 - 05/28/13 01:44 AM Attachment (56 downloads)
Attached is a shot of my setup showing the Celestron F6.3 focal reducer threaded to the ETX rear cell adapter and the SCT prime focus adapter attached to the rear of the focal reducer, coupled to my Canon EOS XS. This combination gives maybe 15% more field of view with the ETX90 than without the reducer. I use this for birding shots and also used the same combination to record the Venus transit last May. For quick and dirty I just thread on the prime focus adapter and the camera.
Ekyprotic
Reged: 11/28/12
      #5934034 - 06/22/13 01:44 AM
Thanks for uploading these images! Can this combo also be used for wide field astro work? I have the Celestron 6.3 reducer I use with my 8 SE, can I use it similarly (with an SCT correct image diagonal) on my ETX 90? One problem I can see would be to view targets near the zenith, I dont think the rear view port has enough clearance for the base of the mount.
seeindoubles
Reged: 01/15/12
Re: ETX 90 like spotting scope. new [Re: Ekyprotic]
      #5934437 - 06/22/13 11:31 AM
Maybe snapshots of the moon (or sun with filter). The drive isn't good enough for long exposure photography-too much periodic error and too unsteady. However you can use a Canon EOS camera using a utility called Backyard EOS to record webcam movies of the planets with it with some success. Even with the jerky drive it will still work as you can keep only the frames where the image was steady. I was able to do a few decent shots of the Venus tranit last year in this manner. Wide field visual work could be done with the appropriate SCT adapter and eyepeices at the camera port though. I am actually planning to use my OTA for a guide scope as soon as the mount rings arrive.
seeindoubles
Reged: 01/15/12
      #5934449 - 06/22/13 11:36 AM Attachment (40 downloads)
This isn't birding but does demonstrate the capabilities of my setup. This shot of the Venus transit last year was made with this setup plus a full aperture solar filter. This is one frame of a webcam movie made running Backyard EOS which allows you to use the Live-View feed to record webcam movies, even if your Canon model cannot normally record video.
*skyguy*
Reged: 12/31/08
Loc: Western New York
      #5934582 - 06/22/13 12:57 PM Attachment (38 downloads)
I have an ETX-125 and a very handy photography accessory to own is the Zhumell 8-24mm zoom eyepiece ($60). It has a male T-thread located under the rubber eye guard that will screw into any DSLR or camera that has a T-thread adapter. Also, the zoom (magnification) can be adjusted on-the-fly without changing the camera's orientation. The posted image shows a water tower 2 miles away with my DSLR attached at prime focus and then with eyepiece projection using the zoom from 24mm to 8mm.
Ekyprotic
Reged: 11/28/12
Re: ETX 90 like spotting scope. new [Re: *skyguy*]
      #5935566 - 06/22/13 11:31 PM
what's the longest exposure you can do if you use the table top tripod in equatorial mode with the etx 90? 30 seconds?
2 registered and 7 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
