whirlpoolm51
Reged: 01/05/12
Loc: pittsburgh,pa
Threaded tubing inserts?? where can i find them?? new
      #5563402 - 12/10/12 12:25 AM
I only know of one place to find threaded tube inserts and they are 5 dollars a piece!!! not my cup of tea to pay that much for somthing i know i can find somewhere else in bulk for cheaper and i need alot for my scope projects
anyone know of a nice place where i can easily get these in bulk and shipped fast and easy!!??? thanks!!
Retsub
Reged: 12/08/06
Loc: Houston,Tx.
Re: Threaded tubing inserts?? where can i find them?? new [Re: whirlpoolm51]
      #5563440 - 12/10/12 01:07 AM
Look hard in the online McMaster-Carr listing for various sizes ans shapes. *BW*
JimMo
I'd Rather Do It Myself
Reged: 01/08/07
Loc: Under the SE Michigan lightdom...
Re: Threaded tubing inserts?? where can i find them?? new [Re: Retsub]
      #5563678 - 12/10/12 07:46 AM
Yes, I bought mine from McMaster-Carr, too. Link
starman345
Wait, I'm Thinking
Reged: 07/06/10
Loc: New Brunswick, Canada
Re: Threaded tubing inserts?? where can i find them?? new [Re: JimMo]
      #5563682 - 12/10/12 07:53 AM
I got mine Here
MessiToM
Reged: 12/21/09
Loc: Huntingdon PA
Re: Threaded tubing inserts?? where can i find them?? new [Re: starman345]
      #5563710 - 12/10/12 08:22 AM
Do these induce any reduction in rigidity?
starman345
Wait, I'm Thinking
Reged: 07/06/10
Re: Threaded tubing inserts?? where can i find them?? [Re: MessiToM]
      #5563750 - 12/10/12 08:51 AM
They are plenty rigid. I used them in my upper cage assembly to join the two rings, I can crank down the bolts pretty tight without problem. I suspect it would be almost impossible to pull one out.
careysub
Reged: 02/18/11
Loc: Rancho Cucamonga, CA
      #5564032 - 12/10/12 11:58 AM
They are tricky to find in McMaster-Carr because they are called in that catalog "Tube Connecting Nuts", threaded tube inserts and variations on this bring up nothing.
These are used in bicycle frame building where they are called "star nuts". Type that into Google and you will get lots of suppliers for the bike market (this will also work in McMaster-Carr).
Other places that carry them:
http://www.meridiantelescopes.com/
http://www.dobstuff.com/
http://www.jwwinco.com/products/section7/gn992/
http://www.mjvail.com/holokrome/hk.html
http://www.marvolus.com/Inserts_double-fin.asp
Why aren't we calling the "star nuts"? We're astronomers for pete's sake! If we did we no one would have trouble finding them!
whirlpoolm51
Reged: 01/05/12
Loc: pittsburgh,pa
Re: Threaded tubing inserts?? where can i find them?? new [Re: careysub]
      #5565155 - 12/10/12 11:44 PM
Thanks everyone!! mcmaster-carr's prices are certainly the best i have found so i orderdd a bunch!! Theses things are plenty strong , once you put them in the pipe do not plan on pulling them out without a fight ahahahaha
careysub
Reged: 02/18/11
      #5565631 - 12/11/12 09:54 AM
Although you can't pull them out, you can push them farther in.
That is, if you find you pole too long, you can shorten it.
10 registered and 20 anonymous users are browsing this forum.
