Privacy Policy |
Please read our Terms
of Service | Signup and
mega256
Reged: 05/10/07
Loc: N of Tampa
$5-9 Dew Controller 8amp
#5563423 - 12/10/12 12:53 AM Attachment (18 downloads)
This is cheap and will handle 8 amps !=96 watts.. For $5-9..
http://www.amazon.com/LEDwholesalers-Dimming-Controller-LED-Lights/dp/B003L4K...
korborh
Reged: 01/29/11
Re: $5-9 Dew Controller 8amp
[Re: mega256]
#5563446 - 12/10/12 01:16 AM
Cool! I wonder if it is really rated at 8A. Dew strip will use much less unless there are several of them tied in parallel.
I may just get it to take it apart and check the safety aspect of its design.
Silicon Owl
Reged: 11/25/05
Loc: Waimea, Hawaii 20N
[Re: korborh]
#5563514 - 12/10/12 03:29 AM
From the closeup of the circuit board it looks to be just an oscillator and a switch transistor, no attempt to filter or smooth the current. It should work well on a resistive load like a dew heater. Not so sure about using it on some LED's!
My handmade dew heater controller is much the same... http://darkerview.com/wordpress/?p=3947
korborh
Reged: 01/29/11
[Re: Silicon Owl]
#5563849 - 12/10/12 09:53 AM
Very nice Andrew! Your dew heater looks really well made and the case is pretty cool. Mine is much simpler and not so finished looking but works. I needed to push only 1.5A so just used a LM317 with pot and input from old laptop charger.
Don Trinko
Reged: 07/05/09
Loc: Ohio
[Re: korborh]
#5563891 - 12/10/12 10:22 AM
very interesting, I put it on my wish list for further consideration. Don T.
Silicon Owl
Reged: 11/25/05
[Re: Don Trinko]
#5568082 - 12/12/12 06:46 PM
An LM317 would work, but is quite inefficient. A lot of your battery power is wasted in the regulator. The Huub Willems/Chris Heapy design is very simple, not much more difficult than the LM317, and nearly all of your battery power is dumped into the dew heater, not dissipated in the controller.
http://www.backyard-astro.com/equipment/accessories/dewheater/dewheater.html
korborh
Reged: 01/29/11
[Re: Silicon Owl]
#5568286 - 12/12/12 09:10 PM
The power dissipation will depend on the input/output voltage differential. In my case it is <10W. With the tin can easily dissipating it, I don't think about it much....as long as it works. Its wall powered so I did not care much about efficiency. I wanted to avoid noisy switching PWM for this ultra-simple application.
15 registered and 22 anonymous users are browsing this forum.
Moderator: Cotts, Starman27
