Az Frank
Reged: 10/18/08
Loc: Tucson Arizona
Jupiter Dec. 10th from Az.
      #5564864 - 12/10/12 08:40 PM Attachment (41 downloads)
The seeing was not good . Almost didn't image at all when first seeing how bad Jupiter looked on the moniter. I noticed a large dark spot below the NEB,seeing calmed enough to take a couple of RGB sessions. This is the best image I could process showing an interesting large blue festoon coming from the NEB, the dominate feature in this image. Thanks for looking.
Az Frank
Reged: 10/18/08
Loc: Tucson Arizona
Re: Jupiter Dec. 10th from Az. new [Re: Az Frank]
      #5564891 - 12/10/12 08:59 PM Attachment (18 downloads)
An IR 742nm image. Even more pronounced in IR.
Edited by Az Frank (12/10/12 09:03 PM)
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #5564893 - 12/10/12 09:00 PM
Very good result Frank! Well done! I find it amazing you were able to achieve an image this good. You even got the NNTZ little red spot. It was too windy here, so I only carried half my stuff out to the backyard, and then later packed it back in.
Glenn
Az Frank
Reged: 10/18/08
Loc: Tucson Arizona
Re: Jupiter Dec. 10th from Az. new [Re: DesertRat]
      #5564910 - 12/10/12 09:10 PM
Thanks Glenn! Like I said I almost packed in as well but I saw the black spot coming in to view "strike maybe". Were it was located I knew a large festoon was more the answer. Still an interesting feature I thought. I was hoping maybe you or Paul had better seeing and could of got a better image, I guess not. Thanks again!
Edited by Az Frank (12/10/12 09:12 PM)
Kecktastic
Reged: 01/16/10
Loc: Broken Hill NSW Australia
      #5565024 - 12/10/12 10:29 PM
Well worth the effort Frank, certainly some interesting features there.
Regards
Trevor
DesertRat
Reged: 06/18/06
      #5565197 - 12/11/12 12:18 AM
Frank can you provide the time for either of these images? That feature is really something, I'd like to get a fix on it. Thanks!
Glenn
Az Frank
Reged: 10/18/08
Loc: Tucson Arizona
      #5566564 - 12/11/12 08:52 PM
Glenn images were taken around 04:45UT and 05:00UT which was 9:45 PM to 10:00 PM our time. Looking at Freddy's first set of images from Dec 7th shows the "Shark fin" like festoon. His are much sharper caught in better seeing.
Edited by Az Frank (12/11/12 09:52 PM)
DesertRat
Reged: 06/18/06
      #5566920 - 12/12/12 02:03 AM
Thanks Frank! I think I'm seeing the same feauture tonite as well. Sadly the seeing has turned poor (after being halfway decent earlier) as the thing was getting nicely presented. Anyway its really dark in IR like you noted.
Glenn
sfugardi
Reged: 09/30/06
Loc: CT
      #5567530 - 12/12/12 12:49 PM
Frank, excellent image considering the seeing. Your processing results are always smooth even under these conditions. Thanks for posting
Steve
4 registered and 11 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
