bunyon
Reged: 10/23/10
Loc: Winston-Salem, NC
Re: Jupiter Nov 23 0440UT in fine seeing new [Re: DesertRat]
      #5547521 - 11/30/12 04:54 PM
Fantastic stuff!
astrovienna
Reged: 12/04/06
Loc: The NoVa White Zone
Re: Jupiter Nov 23 0440UT in fine seeing new [Re: WayneJ]
      #5547813 - 11/30/12 08:27 PM
Wayne, Paul and Glenn, thanks for the kind words. Autorun is a great innovation, but focus is the obvious issue. But I find that nights of good seeing here in the mid-Atlantic have temp drops of only 2 degrees F or less, at least over the two hours or so that I'd leave the scope on its own (lots of trees).
Glenn - focus changes 1-2mm? Wow, the desert really is harsh! Even with temp comp, a good forecast and a good model, that would be awfully tough to deal with. I haven't worked on TC yet, but it's on the list.
And gamma is in WinJupos in the Derotate RGB Frames step. (I usually capture each channel at 80% fill on the histo.) I really ought to ask Grischa why it's like this, to make sure I'm not doing something wrong somewhere.
Kevin
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Jupiter Nov 23 0440UT in fine seeing new [Re: astrovienna]
      #5547821 - 11/30/12 08:30 PM
Very nice images there!
astrovienna
Reged: 12/04/06
Re: Jupiter Nov 23 0440UT in fine seeing new [Re: Rankinstudio]
      #5548557 - 12/01/12 10:40 AM Attachment (20 downloads)
Last one, with Io, at 0701 UT. I think the color on Io worked out well, but there's not much detail. Somebody needs to do a tutorial on moon imaging!
Kevin
astrovienna
Reged: 12/04/06
      #5548621 - 12/01/12 11:28 AM
And a WinJupos strip map of the whole night is here:
http://www.pbase.com/skybox/image/147624964
Kevin
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #5549062 - 12/01/12 04:31 PM
Thats a great map Kevin!
The best way to treat moons in my experience is to align on them separately, stack and resample at 2X or possibly more before applying sharpening. At a larger scale you can fine tune the effective psf more easily - too large and wavelets or deconvolution will simply yield an annular ring with a central dark spot. To convince yourself of that create a small circle of mid level gray, gaussian blur it a bit and try to recover using wavelets.
Glenn
Daniel Chang
Reged: 07/05/06
Loc: Hong Kong
      #5549161 - 12/01/12 05:53 PM
Excellent shot !
AlanL
Reged: 11/11/10
Loc: Kansas, USA
      #5566801 - 12/11/12 11:45 PM
Kevin,
I would be interested to know more about the Winjupos batch mode you mention.
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
Re: Jupiter Nov 23 0440UT in fine seeing [Re: AlanL]
      #5566871 - 12/12/12 12:57 AM
SEB revival ?
karlo
Reged: 05/21/09
Loc: Yorkshire,UK, BLIGHTY !!
Re: Jupiter Nov 23 0440UT in fine seeing new [Re: Freddy WILLEMS]
      #5567066 - 12/12/12 07:18 AM
Crikey Kevin that last image and the map are truly wonderful ! The details are fantastic !
tjensen
Reged: 02/16/05
Loc: Chapel Hill, NC
Re: Jupiter Nov 23 0440UT in fine seeing new [Re: karlo]
      #5567101 - 12/12/12 07:54 AM
really outstanding!
sfugardi
Reged: 09/30/06
Loc: CT
Re: Jupiter Nov 23 0440UT in fine seeing new [Re: tjensen]
      #5567500 - 12/12/12 12:35 PM
Kevin, gorgeous images! Top shelf off the way. Thanks for posting the eye candy
Steve
8 registered and 9 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
