kpendlebury
Vendor Main Sequence Software
Reged: 11/12/08
Loc: Central TX
Sequence Generator Lite - Image Capture - Free! new
      #5558178 - 12/06/12 07:53 PM
Main Sequence Software is set to release a free version of the Sequence Generator Image Capture Software Suite. While it will not have near as many features as the "Pro" version, it is still quite capable in its own right. With it, you will be able to:
- Create (but not save) multi-target sequences using a camera and filter wheel
- Set your camera's temperature (manually)
- Pause and resume sequences
- Dither with any supported auto guider
- Perform a manual frame and focus (using a mask or your choice of focusing aide)
- Use and save the user interface and its modules (except the PHD module)
Anything you are used to using, that is not a part of this list is likely restricted to the "Pro" feature set. It should be noted that there is not a separate version (download) to get Sequence Generator Lite... when your trial expires, your installation will automatically convert to the free "Lite" version.
This feature will be available in the 2.1 release of the software. If you are interested in using it now, please download the 2.1 Beta software.
For a more complete comparison, you can check out this page (draft):
http://www.mainsequencesoftware.com/store2.html
Please let us know if you have any questions.
herrindude
Reged: 07/25/10
Loc: Fairhope Alabama
Re: Sequence Generator Lite - Image Capture - Free! new [Re: kpendlebury]
      #5562819 - 12/09/12 05:21 PM
Thanks for the heads up on this software, I am going to give it a try, I greatly appreciate it.
Denimsky
Reged: 01/21/07
Loc: BC, Canada
Re: Sequence Generator Lite - Image Capture - Free! new [Re: herrindude]
      #5563048 - 12/09/12 07:47 PM
SGPro is excellent software. SGPro, PHD and Elbrus plate solver combination saved me big $$ (compared to Maxim) as well. It is very easy to use but also very flexible and powerful.
kpendlebury
Reged: 11/12/08
Loc: Central TX
Re: Sequence Generator Lite - Image Capture - Free! [Re: kpendlebury]
      #5567365 - 12/12/12 11:21 AM
Hi folks,
Just want to re-iterate a couple things:
1.) The software you download to access the free "Lite" version is the same as the "Pro" version. When you install it, you will have the Pro version for 45 days. After this, you will automatically use the Lite version.
2.) The free version is currently only available in Beta right now. The Beta is fairly stable at this point. You can find it here:
http://mainsequencesoftware.com/downloads.php
Ken
4 registered and 10 anonymous users are browsing this forum.
