John Miele
Reged: 05/29/05
Loc: North Alabama
It's in the ground! (another Wood Pier) new
      #5562926 - 12/09/12 06:34 PM Attachment (46 downloads)
Hi all,
I did not want to glom on to Dwight's thread any longer so I started a new thread here in the observatory forum on my wood pier build. This was inspired by the great write-up that Dwight shared over in the mounts forum
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5527689/page...
I always wanted a pier but did not want to go with concrete columns or the cost of a metal pier. One aching back later, I have my own backyard wood pier in the ground . It's a beast made just as Dwight did using four 6 feet long 6x6 wood posts glued and bolted together and dropped into a 36" deep hole. I'll be attaching some metal plates and the G11 adapter on Tuesday. Dug the hole by hand with a shovel and post hole digger. Good grief, Alabama red clay is hard to dig in . But the hard part is done! I'll be posting some cost numbers and more pics later...John
Edited by John Miele (12/09/12 06:37 PM)
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: It's in the ground! (another Wood Pier) new [Re: John Miele]
      #5562931 - 12/09/12 06:35 PM Attachment (42 downloads)
Pier is ready to roll to the launch pad!
John Miele
Reged: 05/29/05
Loc: North Alabama
      #5562934 - 12/09/12 06:36 PM Attachment (46 downloads)
In the ground!
John Miele
Reged: 05/29/05
Loc: North Alabama
      #5562939 - 12/09/12 06:39 PM Attachment (42 downloads)
Took seven 40 lb bags of quick-crete...
mich_al
Reged: 05/10/09
      #5562978 - 12/09/12 07:00 PM
Congratulations on the new pier, hope it serves you well. These things are starting to really multiply, I have one too. The first I heard of was built by Patrick in Northern Ohio about 3 years ago. Anyone know of an earlier 4 6*6 timber pier?
korborh
Reged: 01/29/11
Re: It's in the ground! (another Wood Pier) new [Re: mich_al]
      #5563211 - 12/09/12 09:51 PM
Looks great! waiting on more updates...
opticsguy
Reged: 02/02/09
Loc: Washington State
Re: It's in the ground! (another Wood Pier) new [Re: korborh]
      #5563358 - 12/09/12 11:52 PM
Looks good!!! What you gonna do about them trees??
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: It's in the ground! (another Wood Pier) new [Re: opticsguy]
      #5563886 - 12/10/12 10:17 AM
They block my neighbors lights right now. I plan to do a limited topping sometime soon as they restrict my southern view to about 45 deg. or higher. I'm pretty good East, West, and North...john
D_talley
Reged: 07/07/05
Loc: Richmond VA
      #5564947 - 12/10/12 09:35 PM
Great looking pier. Patrick is to blame for our back pain.
I wish I had your sky view. I have a north shot over the house and can just see Jupiter over the trees in the east by 10pm. No south view at all. West is just as bad as the east.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: It's in the ground! (another Wood Pier) [Re: D_talley]
      #5567510 - 12/12/12 12:38 PM
Beautiful John!
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: It's in the ground! (another Wood Pier) new [Re: Raginar]
      #5571808 - 12/15/12 12:05 AM Attachment (20 downloads)
Completed the pier yesterday . Notched the corners and installed the 1/4" x 12" x 12" steel plates and the G11 adapter. Here are some photos of the mount. Had a brief chance to use it last night. With my C8 on top, it felt very sturdy and rigid. A sharp rap on the tube damped out in about 2 seconds in a 220X eyepiece view of Jupiter. I think it's a success. Now to see how long it holds polar alignment...John
John Miele
Reged: 05/29/05
Loc: North Alabama
      #5571813 - 12/15/12 12:07 AM Attachment (18 downloads)
View of the south end...
John Miele
Reged: 05/29/05
Loc: North Alabama
      #5571814 - 12/15/12 12:08 AM Attachment (15 downloads)
I added two handles on the East and West sides under the top plate to hold cables and the controller...
John Miele
Reged: 05/29/05
Loc: North Alabama
      #5571817 - 12/15/12 12:11 AM Attachment (17 downloads)
As Dwight noted, the Gemini controller does not attach properly to the std brackets on the pier adapter. I made a couple of right angle brackets to move the controller to the back edge of the upper plate. It still allows a clear view through the polar scope and keeps adequate slack in the motor cables...
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5571938 - 12/15/12 02:15 AM
Hey John,
How'd you drill those steel plates?
John Miele
Reged: 05/29/05
Loc: North Alabama
      #5572298 - 12/15/12 10:22 AM
Hi Chris,
I bought the two plates from a local welding shop and had them match drill the 3/4" holes in the corners of each plate. They charged me $50 total to cut and drill both plates. I then had to drill 5 addtional 1/2" holes and 6 additional 1/8" holes to assemble everything. I used a drill press and standard metal drilling bits. The 1/8" holes were drilled in one pass. The 1/2" holes were first drilled with a 1/4" bit and then enlarged to 1/2". Dwight talked about this too...the key was to use a low speed on the press and lots of lubricating oil to keep the bits from overheating. It did get messy! I already owned all the bit sizes I needed. The plates are made from A36 steel which is easier to drill through than a high strength steel. But they are just as stiff because all steels have essentially the same Modulus (E) regardless of their hardness...John
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5573057 - 12/15/12 07:33 PM
Cool, thanks John.
Wmacky
Reged: 11/24/07
Loc: Florida
      #5573305 - 12/15/12 09:56 PM
How about those nuts, and bolts. Are they Stainless? If so were to you obtain them?
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: It's in the ground! (another Wood Pier) new [Re: Wmacky]
      #5573433 - 12/15/12 11:43 PM
The corner bolts are actually 3/4" threaded rod cut to lenght with a hacksaw. The rod and the nuts were bought from Lowes. They are standard zinc plated hardware. I will be keeping the pier covered with a Telegizmo continuus exposure cover and a dry stick (both on order from Scopestuff). Hoping that will keep any corrosion at bay for a long while...John
D_talley
Reged: 07/07/05
Loc: Richmond VA
      #5573447 - 12/15/12 11:56 PM
Perfect mount. I like your solution for the controller better than what I did. Enjoy!!!
7 registered and 5 anonymous users are browsing this forum.
Moderator:  Christopher Erickson, Mitchell Duke
