Footbag
Reged: 04/13/09
Loc: Scranton, PA
Concrete floor or deck over grass?
#5565916 - 12/11/12 01:13 PM
What are the advantages of using a raised wood floor rather then a concrete floor? I know you could separate the wood from the pier, but all things equal would a concrete slab be better?
Norm Meyer
Reged: 02/08/09
Loc: Warren, ME 04864
Re: Concrete floor or deck over grass?
[Re: Footbag]
#5566039 - 12/11/12 02:21 PM
Adam, I don't know if one is preferable over the other. I used cement for my 8' x 8'. It took about a cubic yard of cement. I spent about a day mixing with a mixer. I dug out all the topsoil and put down a layer of gravel about 8 or 9 inches.Then mixed and poured the cement. The perimeter of the slab is deeper than the rest of it but minimum thickness is 4". It has been there for 15 years or so and is still good shape. There is one hairline crack but it isn't getting any worse. There is re-bar in the slab. I haven't noticed any lifting due to frost. Cement has a feeling of permanency. The disadvantages are: More physical work initially.There is more mass so it will retain summer heat and it is quite hard if you drop an eyepiece.You can alleviate these problems if you put wood or carpet on top of slab. a wooden platform is physically easier to build.It won't be a problem with heat built up because of lower mass. You wouldn't need to cover it to protect dropped items. If you use wood it should be pressure treated and you have to be careful with that because the newer PT does not keep insects out of it especially in direct contact with soil. If I were to do it again I would definitely consider a wooden platform just because I couldn't do the cement work anymore. There are benefits to either way. Keep us posted on what you decide to do.
Norm
Chris Erickson
Reged: 05/08/06
Loc: Waikoloa Village, Hawaii
[Re: Footbag]
#5566043 - 12/11/12 02:25 PM
A slab of concrete has a lot of thermal inertia and will negatively impact your local seeing.
If you can easily go either way, I would suggest some of that new composite plastic deck planking that looks like wood but never rots, is invulnerable to bugs and doesn't need painting.
dwitek
Reged: 07/03/08
Loc: White Lake, Michigan
[Re: Chris Erickson]
#5566082 - 12/11/12 02:43 PM
After two years of design and reading I've decided on Dek-Block and 2X6 joists to get air flow under the obs. I thought about a concrete slab but I'd feel better getting off the ground but keep it high enough up (clearance of about 10 inches to the subfloor) to keep critters from living underneath, hopefully.
stmguy
Reged: 10/11/12
Loc: Western NH
[Re: dwitek]
#5567262 - 12/12/12 10:06 AM
besides the thermal issues the wood floor will feel much better if you are standing any length of time
Norm
DeanS
Reged: 07/12/05
Loc: Central Kentucky
[Re: stmguy]
#5567460 - 12/12/12 12:16 PM Attachment (18 downloads)
I did a solid concrete slab. Perhaps a compromise but I wanted the flexibility to mount a couple piers, and be able to move them around if needed.
The slab is about 3' thick under the scope area, and around the perimeter to get well below our frost line so there is no heaving. Very solid, so much I can jump up and down next to a pier while imaging and there is no movement. Plus in its next life it can be used as a machine shop or similar
The concrete is the same temp as the earth so does that really affect the seeing? I have carpet down as an insulator, plus the pad is in the shade so it is not absorbing the suns heat.
I do open windows and run a fan to help with cool down during the winter. Summer time I have a window AC unit on a timer so it is always cooler than ambient before imaging.
If you are going to do the wood, then you might as well get it up as high as you can to get all the benefits. I have no regrets, except I wish it was under some really dark skies
Dean
Galaxyhunter
Reged: 01/02/06
Loc: Northern Illinois
[Re: DeanS]
#5567559 - 12/12/12 01:12 PM
-----The concrete is the same temp as the earth so does that really affect the seeing? I have carpet down as an insulator, plus the pad is in the shade so it is not absorbing the suns heat.
I agree, How can there be a thermal issue when everbody that has a rooftop observatory claims that their shingles does NOT effect the seeing? And everybody knows that the shingles are soaking up the days heat.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
[Re: Galaxyhunter]
#5567593 - 12/12/12 01:32 PM
Well. I don't really think it would be any more expensive to pour the floor. I'd have to pay for a load of concrete, whether it's just a pier or the whole shebang. Initially I had planned to do it myself. I could probably dig a hole and mix up the pier but my back has gotten worse and my neighbor is a contractor. It's also in a better location then I had planned, so it will also have to look nice.
I'm inclined to just go with a slab. Animals are a primary concern. I had planned to put down a rubber mat in case of equip drops and just to soften my steps. If thermal issues effect it, maybe I'll get a solar powered fan to run across the floor.
It's a project for next spring, so now I'm planning and budgeting.
Chris Erickson
Reged: 05/08/06
[Re: Footbag]
#5568272 - 12/12/12 09:01 PM Attachment (20 downloads)
Concrete has considerable thermal inertia and if it is unsealed, it can have a big impact on humidity in an observatory. And it is NEVER thermally-matched to the ground it is sitting on or in. All it takes is an evening with a thermal imaging camera to conclusively-prove that concrete should be avoided whenever alternatives exist.
In this picture you will note that at 5:48pm, just after sunset, the observatory is at 35F but the concrete pad is still at 50F. The surrounding ground (barren, rocky) is around 40F. The concrete pad finally stabilized with the ground around 1am.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
#5568321 - 12/12/12 09:31 PM
Hmmm. I see your point from the image. I wonder if carpet or something else could insulate it. Maybe that with a solar cooling fan. Otherwise, it's probably easier and possibly cheaper to do a wood floor. It's keeping the critters out that I'm worried about.
Tom and Beth
Reged: 01/08/07
Loc: Tucson, AZ
[Re: Footbag]
#5568354 - 12/12/12 09:51 PM
I have a slab and considering a sub-floor for
1) standing 2) those times you drop an EP.
With a roll off roof, I've never encountered thermal problems from the slab. Maybe because it's shaded? YMMV.
Chris Erickson
Reged: 05/08/06
[Re: Tom and Beth]
#5568413 - 12/12/12 10:49 PM
Most people don't recognize the thermal problems they have created with their observatory designs and unless you have an identical scope outside of the observatory and are set up to compare the seeing differences.
A thermal imaging camera can easily-show the temperature differences throughout the entire night.
One way to evaluate if there are big thermal problems is to compare seeing between, say, 10pm and 3am. If the 3am seeing is consistently better than your 10pm seeing then you are likely suffering from local seeing problems.
Many structural engineering firms and housing inspectors have thermal imaging cameras these days. You might also be able to rent one locally.
I hope this helps.
Steve Drapak
Reged: 09/18/08
Loc: Toronto, Canada
#5568542 - 12/13/12 12:56 AM
Raised platforms are a whole lot easier if you decide to move
Starman27
Reged: 01/29/06
Loc: Illinois, Iowa
[Re: Steve Drapak]
#5568781 - 12/13/12 07:58 AM
I have a raised deck under both of my observatories. It helps deal with local thermals along with appropriate landscaping.
DeanS
Reged: 07/12/05
[Re: Starman27]
#5568804 - 12/13/12 08:23 AM
Everything is a compromise. I wanted flexibility and to do some visual out of mine.
If I was given the opportunity to build again in a dark sky site I would like to have a raised dome strictly for imaging, then a large roll off for visual.
I have a laser thermometer and will do some measurements and see what the slab is doing. I don't doubt it holds some heat since it is so thick.
We invest a lot in our equipment so it would be nice to get the most out of it, but at what point are we going overkill?
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
[Re: DeanS]
#5568994 - 12/13/12 10:47 AM
Wow! Dean, that slab will never move! Beautiful!
Since my Dobservatory is on a slope, wood was used, with a concrete pier (even with the wood floor) for my dob. The concrete is buffered from the wood floor with automotive foam. I then put indoor/outdoor carpet over the wood. It's worked out very nicely for me.
Galaxyhunter
Reged: 01/02/06
#5569245 - 12/13/12 01:11 PM
That pic is all fine & Dandy. But there is a couple of questions: 1: Where is that Observatory 2: Is that a professional or a backyard observatory? 3: How much concrete is involved with that structure? 4: How much of the concrete is exposed to the Sun light during the day?
For the record, I am not opposed to a wood deck.
I just re-read you post, You counter-dick yourself. "And it is NEVER thermally-matched to the ground it is sitting on or in." The next paragraph you said.
"The concrete pad finally stabilized with the ground around 1am."
Tom and Beth
Reged: 01/08/07
Loc: Tucson, AZ
#5569263 - 12/13/12 01:19 PM Attachment (15 downloads)
1) standing
<<SNIP>>
<<SNIP>>
I hope this helps.
Yes, Erik...as I'm a visual observer who doesn't need to rise early I can/do this every clear night. Whatever OBS thermal issues are present are overwhelmed by the MC scope's thermal issue.
it's just a short scoot over to another scope that cools rapidly.
I attached a low resolution pic of the scopes from the Security
Edited by Tom and Beth (12/13/12 01:25 PM)
Chris Erickson
Reged: 05/08/06
[Re: Galaxyhunter]
#5571094 - 12/14/12 04:19 PM
You are right. I could have phrased that a lot better than I did.
Answers to your questions:
1&2. That fully-robotic observatory is owned by the University of Hawaii and is called VYSOS-20. It has an uninsulated Ash dome and contains a 20" Planewave RC scope on an Astro-Physics 3600GTO mount. It is located at the Mauna Loa Weather Observatory, on the slopes of Mauna Loa on the Big Island of Hawaii. Its coordinates are 19.535948, -155.576140. It is a barren, volcanic, incredibly-dry place at 11,000'. It could be described as a professional observatory built with high-end, COTS amateur equipment.
3. There is an estimated three cubic yards of concrete involved in that observatory's pier and foundation/floor.
4. About 5% of the concrete is exposed to the Sun at any given time during the day.
The observatory's inside and outside temperatures are like two sine waves that are permanently out of phase with each other. The inside temps are always following after the outside temps. Because of the concrete mass, the local seeing is "bad" until about 1am, when it improves to "marginal." At about 3am, the local seeing improves to "acceptable." About one hour after sunrise, the outside temperature warms past the inside temperature and then the inside stays cooler until about sunset, when the outside temps once again cool past the inside temps.
One solution I have recommended to the university is to insulate the dome and install a remote-computer-controlled A/C unit. The plan would be to pre-cool the observatory interior to the predicted night-time temperature when night-time operations would commence. This will use a whole-lot more electricity (especially painful at $0.47/kWh) and still wouldn't give ideal local seeing but it would improve their local seeing considerably.
Local seeing is a cumulative issue. People who choose to believe that they can ignore one factor because it is "swamped by other factors" are overlooking the reality that all of the factors are cumulative. Every improvement that can be reasonably-made will give dividends.
I hope this helps.
Galaxyhunter
Reged: 01/02/06
[Re: Tom and Beth]
#5571101 - 12/14/12 04:24 PM Attachment (16 downloads)
I just placed a temperature probe roughly 2" deep in the ground off of the North East corner of my Observatory so that it is in the shade most of the day. I placed the readout on the upper left hand corner of the attached pic. This pic was taked @ 15:03 Central Time.
So much for THAT theory
