RAK on Tour
Reged: 11/12/07
Loc: Sedalia, Missouri
Finder O-Rings new
      #5519581 - 11/14/12 02:00 PM
Does anyone know where to get replacement O-rings for the common 6x30 finderscopes? I need to replace a broken one, and the auto parts store's O-rings are too thick.
Also, does anyone sell replacement holders that have the spring button and two adjustment screws at 90 degrees apart? Th current holder I have is the old style with three screws placed every 120 degrees.
rdandrea
Reged: 06/13/10
Loc: Colorado, USA DM59ra
Re: Finder O-Rings new [Re: RAK on Tour]
      #5519654 - 11/14/12 03:01 PM
Try the plumbing department at a well-stocked hardware store.
coopman
Reged: 04/23/06
Loc: South Louisiana
Re: Finder O-Rings new [Re: rdandrea]
      #5520202 - 11/14/12 09:38 PM
Try Agena Astro.
RAK on Tour
Reged: 11/12/07
Re: Finder O-Rings new [Re: coopman]
      #5520208 - 11/14/12 09:44 PM
Thanks, guys. I'm going to try Ace, Lowe's, and a local plumbing store. If I come up empty, I'll try Agena Astro. I've used them before and have been well satisfied.
kfiscus
Reged: 07/09/12
Loc: Albert Lea, MN, USA
      #5520367 - 11/14/12 11:50 PM
My ACE Hardware had the correct one. Take your scope and mount with you!
Midnight Dan
Reged: 01/23/08
Re: Finder O-Rings new [Re: kfiscus]
      #5520651 - 11/15/12 07:12 AM
For all things hardware, McMaster Carr:
http://www.mcmaster.com/#o-rings/=k68vhp
-Dan
scott m
Reged: 12/06/07
Loc: Hatfield Pa
Re: Finder O-Rings new [Re: Midnight Dan]
      #5520754 - 11/15/12 08:49 AM
Scope Stuff also has them http://www.scopestuff.com/ss_fring.htm
RAK on Tour
Reged: 11/12/07
Re: Finder O-Rings new [Re: scott m]
      #5522943 - 11/16/12 01:44 PM
I found an O-ring that works! At Ace, in the metric O-ring drawers, I found the part # ORM-204-026 at a cost of $1.39. It's a 26mm inside diameter O-ring, 2mm thick. I tried it there in the store on my 6x30 finder and it works perfectly, including fitting into the finder bracket. I tried a slightly larger inside diameter O-ring, but there wasn't enough tension to keep the O-ring in place when I tried to slip the finder bracket over the O-ring. If you have a broken or missing O-ring on your 6x30 Synta finder, this works great!
hottr6
Reged: 06/28/09
Re: Finder O-Rings [Re: RAK on Tour]
      #5569481 - 12/13/12 03:40 PM
Good to know the metric version.
I grabbed the SAE version at ACE Hardware for $0.57. It is -026 size, 1/16" width, ID=1.25", OD=1.375".
ScopeStuff and Agena Astro have o-rings for 50mm finders only.
5 registered and 20 anonymous users are browsing this forum.
Moderator:  Jarad, tecmage
