DonsDob
Reged: 05/21/12
Loc: CT
Telrad Dew Shield Plus new
      #5475467 - 10/17/12 05:04 PM
Has anyone used this? (http://www.optcorp.com/product.aspx?pid=4088) I assume the right angle mirror reverses/flips the image? It sounds useful as craning my neck around the straight-thru can be a pain sometimes.
beatlejuice
Reged: 04/05/11
Loc: Hamilton, ON,Canada
Re: Telrad Dew Shield Plus new [Re: DonsDob]
      #5475585 - 10/17/12 05:59 PM
It is just dead weight on my Telrad. I find the Telrad riser much more useful for awkward positions and now when the Telrad window dews up(although I do cover it up with the dew shield when I think of it) I just wipe it with a small cloth that I keep in my pocket. (its not expensive optical glass)
Eric
wolfman_4_ever
Reged: 07/15/11
Loc: El Segundo, Ca, So. Cal
Re: Telrad Dew Shield Plus new [Re: beatlejuice]
      #5475820 - 10/17/12 08:30 PM
I use it. Works well. It is pricy..
Eddgie
Reged: 02/01/06
      #5476050 - 10/17/12 10:59 PM
It is indeed a mirror about the size of the window that flips out of the way, or you can flip it down so that you can view the reticle like using a diagonal mirror.
I have used it in the past. It works OK sometimes, but it is best when you are trying to center on a bright star.
Does a good job of combating dew I think, if you can remember to flip the cover over the window.
So, it works OK. Not great, but not bad either.
Reged: 06/16/04
      #5476339 - 10/18/12 04:15 AM
I have not used one, generally I am OK with the viewing positions the Telrad requires... One thing to be aware of is that when using the Telrad straight through you can keep both eyes open and so more than double the brightness of the sky and what you can see. With the right angle mirror, you can only use one eye and there is maybe some additional loss because it must be rear illuminated.
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
Re: Telrad Dew Shield Plus new [Re: Jon Isaacs]
      #5476698 - 10/18/12 10:47 AM
Jon, I have one, and I use both eyes viewing the mirror. It simply is a reflective view of the straight forward (normal) view of the Telrad, similiar to mirrors used with binoculars. With the mirror, you are looking down towards the scope, rather than "up" thru the Telrad. The bullseye shows up very well in the mirror. I rarely use it, however; as with the riser, it's comfortable to use the straight-thru view at all angles.
Reged: 06/16/04
Re: Telrad Dew Shield Plus new [Re: csa/montana]
      #5476713 - 10/18/12 10:56 AM
Carol:
I see, in the photo, the mirror did not look large enough to use with both eyes.
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
      #5476734 - 10/18/12 11:06 AM
Jon, looking directly down on it, I've always used both eyes. Similiar to a small ladies compact mirror, they use both eyes to look at it. I suppose one could close one eye, but it's not necessary, as one is not putting their face down on it, rather viewing from a distance.
It definitely works, and would be very useful when not using a riser with the Telrad; but since I have a riser, I don't need it for the mirror.
Bob Griffiths
Getting Grouchy
Reged: 10/10/05
Loc: Frederick Maryland
      #5476809 - 10/18/12 11:58 AM
They work..BUT to be truthful I gave up using the mirror to be able to use it as a RACI finder...
Just way too difficult to get my eye into position to use it that way... Its easier for me to squat down or kneel down and use it as a straight thru finder and believe me once I am down on my knee I have one heck (*&%**) of a time standing back up...
The 4 inch raiser base solved most of my "physical" problems
Bob G.
Eddgie
Reged: 02/01/06
      #5477400 - 10/18/12 05:02 PM
I used both eyes also. There is no need to get close to the mirror. I would usually look at it from a couple of feet away.
It could be hard sometimes to aquire the reticle when using the mirror becase when you use just the Telrad, you have a much better sense of being directly behind it.
With the mirror, it sometimes would take some head movement to get exactly over the axis of the reflection.
I agree though, works fine with two eyes.
n1wvet
Reged: 04/22/11
Loc: Northern Virginia, USA, Earth
Re: Telrad Dew Shield Plus new [Re: Eddgie]
      #5478127 - 10/19/12 01:19 AM
I have this option as well. The mirror works well. It keeps me from squatting in weird contortions to align a star. I usually forget to close the shield to keep dew off. So, I added resistors to the Telrad window and the back of the mirror to elimnate dew issues. It is not the best fit on the telrad. It is a little loose but OK.
Fireball
Reged: 03/24/06
Re: Telrad Dew Shield Plus new [Re: n1wvet]
      #5478256 - 10/19/12 05:11 AM
I have the "plus". The dew shield itself works just fine (unless it is too humid and cold) but I never used the mirror - don't need it all.
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
      #5478557 - 10/19/12 10:41 AM
Carol:
Jon, you are standing over the mirror, with your head a couple of feet above it; there would be no reason to close one eye. The mirror itself is 2" square.
demiles
Reged: 11/07/06
      #5479602 - 10/19/12 10:21 PM
Interesting product. Being someone with neck problems I've been looking for a solution for my Telrad that I use exclusively. The four inch riser has helped but after a few hours of observing I'm starting to hurt. I just completed a mod that moves the Telrad farther forward on the scope. I haven't tried it out on the field yet but here's a pic.
http://db.tt/L2HlBuqU
beatlejuice
Reged: 04/05/11
Re: Telrad Dew Shield Plus new [Re: demiles]
      #5479830 - 10/20/12 01:41 AM
You can actually stack the risers as well. A 2" riser on a 4" riser might be worth a shot.
Eric
Perigny270
Reged: 10/23/11
Loc: Temiscaming, Quebec
Re: Telrad Dew Shield Plus new [Re: wolfman_4_ever]
      #5480025 - 10/20/12 08:35 AM
My experience too.
DonsDob
Reged: 05/21/12
Loc: CT
Re: Telrad Dew Shield Plus new [Re: Perigny270]
      #5484348 - 10/22/12 09:12 PM
THanks for all your comments - reviews seem to be mixed. I think I might try the riser first.
Eric38
Reged: 05/04/07
Loc: Chicago
Re: Telrad Dew Shield Plus [Re: DonsDob]
      #5569587 - 12/13/12 05:04 PM Attachment (12 downloads)
I had mine about a year. The dew was not deterred. The mirror is hard to use. I prefer to sight straight through anyway. Reading some threads in the DIY forum I found some interesting designs for dew removal, here is mine.
Edited by Eric38 (12/13/12 05:05 PM)
13 registered and 20 anonymous users are browsing this forum.
Moderator:  Jarad, tecmage
