Privacy Policy |
Please read our Terms
of Service | Signup and
Zebenelgenubi
Reged: 04/06/12
Loc: Texas, USA
Lost RA Drive on my CGEM 800
#5570007 - 12/13/12 09:42 PM
I set up my C9.25 this evening only to find the RA drive motor isn't working. No slew,no whiring. The declination drive is fine. I rebalanced the setup and adjusted the clutch without effect. How does one trouble shoot this situation? The mount is only about one year old.
RTLR 12
Reged: 12/04/08
Loc: Capistrano Beach, Ca
Re: Lost RA Drive on my CGEM 800
[Re: Zebenelgenubi]
#5570118 - 12/13/12 10:58 PM
Remove the control panel and swap the connectors on the motors and see if the RA works.
Stan
Zebenelgenubi
Reged: 04/06/12
Loc: Texas, USA
[Re: RTLR 12]
#5570470 - 12/14/12 08:45 AM
Stan,
Good idea. I had a chance to look at the symptoms since my initial post. I found that the RA will slew counterclockwise (from Polaris point of view) while straining but will not go clockwise independent of how I balance the mount.
RTLR 12
Reged: 12/04/08
[Re: Zebenelgenubi]
#5570521 - 12/14/12 09:28 AM
Now that sounds mechanical in nature, rather than electronic. You can try backing off the worm gear adjustment on the RA axis to see if it's a binding problem of the worm gear/ring gear.
Stan
17 registered and 23 anonymous users are browsing this forum.
