Bert
Reged: 02/17/06
Loc: Australia
Orions Sword in 3nm NII new
      #5569841 - 12/13/12 07:57 PM Attachment (18 downloads)
Managed to get 10x16 minutes in 3nm NII of M42 and made a mosaic with the earlier Horse head data. There is a mismatch at the overlap but it gives an idea of what is possible.
Large image 5MB FoV 6.0 X 3.4 degrees.
http://d1355990.i49.quadrahosting.com.au/2012_12/Orsword_NII.jpg
I am finding that gradients are still a problem even with 3nm filters.
Bert
Astrograph is an Officina Stellare RH200 which has a focal length of 600mm and is F3, yes F3! Clear aperture is 200mm.
FLI Atlas Focuser.
FLI ten position filter wheel CFW-3-10 with 50mm square filters.
Astrodon E series LRGB and HA, NII, SII and OIII 3nm NB filters. Also a continuum filter 5nm.
Camera is a FLI PL16803 which has a sensor size 36.8 X 36.8 mm.
The FoV of this system is 3.5 X 3.5 degrees.
Mount is a Software Bisque PMX.
Edited by Bert (12/13/12 08:01 PM)
SL63 AMG
Reged: 12/21/09
Loc: Williamson, Arizona
Re: Orions Sword in 3nm NII new [Re: Bert]
      #5569847 - 12/13/12 08:03 PM
That's amazing!
Kildar13x
Reged: 07/06/11
Loc: Maine
Re: Orions Sword in 3nm NII new [Re: SL63 AMG]
      #5569864 - 12/13/12 08:12 PM
broca
Reged: 03/26/10
Loc: Ocala, FL
Re: Orions Sword in 3nm NII new [Re: Kildar13x]
      #5569922 - 12/13/12 08:40 PM
Amazing amount of dust you were able to capture and process out. Well done!
psandelle
Reged: 06/18/08
Loc: Los Angeles
Re: Orions Sword in 3nm NII new [Re: broca]
      #5569953 - 12/13/12 09:03 PM
WHOA!!!!
Nice pic!
Paul
rigel123
Reged: 06/29/09
Loc: SW Ohio
      #5570013 - 12/13/12 09:47 PM
That is simply unreal!! Amazing!
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
Re: Orions Sword in 3nm NII [Re: rigel123]
      #5570060 - 12/13/12 10:18 PM
That's a terrific image!
David
freestar8n
Reged: 10/12/07
      #5570451 - 12/14/12 08:30 AM
Hi-
That's a nice image and it has potential, but I would be concerned that the mismatch is related to using 3nm at f/3 with wide field. Trying to separate Ha from Nii is fundamentally difficult with fast optics, and due to the large and variable angles through the filter, I would expect a variation in the ratio of Ha/Nii across the image. In a single image this wouldn't show much, even though it is present - but in a montage, any difference in this ratio would produce a mismatch.
I can't say for sure that is what is happening here, but some amount of variable mixing is inevitable across the image at fast f/ratio. I don't think there is a way to fully isolate Ha from Nii with fast optics - you either have to go wider band and combine them, or slower f/ratio to keep them separate.
This effect also may be related to your issue with gradients.
Frank
Konihlav
Reged: 03/05/09
Re: Orions Sword in 3nm NII new [Re: freestar8n]
      #5570619 - 12/14/12 10:38 AM
Bert - what a nice contrast :-) great!
Frank - I would not be afraid of F/3 and 3nm NII as the Astrodon filter is really ubercool (simply great!), but you are right that even that the Astrodon filters have very high transmittance and steep/narrow bandwith there probabably is some small % of Ha emission included in the image as the 658nm of NII in 3nm allows to pass light in between 656.5nm to 659.5nm in ideal case... and Ha is 656.3 if I am right... so the small % may be eventually 50% ;D who knows
so good point! with slower scope it would be much better separated, but who cares in ORION ;D
13 registered and 25 anonymous users are browsing this forum.
Moderator:  Oldfield, droid, Scott in NC, bilgebay, WOBentley
