ngc 9999
Reged: 08/13/12
Loc: Sunrise, Fl. 26 degrees N
Tripod suggestion for my Garrett SS 10x50 new
      #5577682 - 12/18/12 06:06 PM
Hello,
I need suggestions about buying a tripod for my binoculars, enough to take the 3 lb of the binocular but not too costly. For the adapter I've decided on the Garrett metal adapter.
Thank you.
Rich V.
Reged: 01/02/05
Loc: Lake Tahoe area, Nevada, USA
Re: Tripod suggestion for my Garrett SS 10x50 new [Re: ngc 9999]
      #5577829 - 12/18/12 07:47 PM
I'd suggest Garrett's 3000 tripod/head; it's nice and tall (78") plus it's relatively inexpensive. The less expensive Orion HD-F2 tripod they offer is a bit short (69.5") for many users though it does provide a geared column.
If you plan to add a 15x70 or even larger bino some day, the 5000 combo would be a better bet with the extra capacity, geared center column and adjustable spreaders for greater rigidity.
Binocular viewing requires more height than many "photo" tripods can provide; check the specs carefully.
Rich
kenrenard
Reged: 12/13/12
Loc: Dunmore, PA
Re: Tripod suggestion for my Garrett SS 10x50 new [Re: Rich V.]
      #5584672 - 12/22/12 08:33 PM
Does the Garrett 5000 work well? I am trying to decide on either a Orion paragon plus or the 5000. Since I have 15 x 70s and may want to move up I am thinking the 5000 is the way to go.
rdandrea
Reged: 06/13/10
Loc: Colorado, USA DM59ra
Re: Tripod suggestion for my Garrett SS 10x50 new [Re: kenrenard]
      #5584723 - 12/22/12 09:19 PM
The 5000 is a great tripod for the money. Very stout, smooth motions. It would handle 15x70s without a second thought.
kenrenard
Reged: 12/13/12
Loc: Dunmore, PA
Re: Tripod suggestion for my Garrett SS 10x50 new [Re: rdandrea]
      #5584734 - 12/22/12 09:25 PM
Thanks I can't handhold well enough. I also would like to get a 80 or 100 down the road. I keep learning as I go along. It looks like a nice mount and tripod on the site. I have a slik tripod for my small refractor and that works pretty good. The 5000 looks much beefier. Thanks again for your advice.
richsvt
Reged: 01/09/09
Loc: North Shore of Boston
      #5584792 - 12/22/12 10:12 PM
I would also advise using the 5000. It works wonderfully with the 15x70s. I use my GBT100s with it. Works wonderfully for those as well. Smooth action. Solid and sturdy. When I use on a grassy surface, damping time is a hair above a second with use for the 100s with the center section moderately cranked up. All controls are well placed and easy to operate in darkness.
Jawaid I. Abbasi
Reged: 06/19/07
Loc: LEVITTOWN, PA
      #5584804 - 12/22/12 10:19 PM
Do not need to say anymore and you got the best suggestion as everyone agreed on it
kenrenard
Reged: 12/13/12
Loc: Dunmore, PA
Re: Tripod suggestion for my Garrett SS 10x50 new [Re: Jawaid I. Abbasi]
      #5585173 - 12/23/12 07:48 AM
Thanks for the advice. I will be getting one in the new year
daniel_h
Reged: 03/08/08
Loc: VIC, Australia
      #5586428 - 12/23/12 11:12 PM
Yep the 5000 if you intend getting a 80 or 100mm glass, other things to consider are the bogen manfrotto 028,056,045/6
Bhhphtoto also seek a Davis sanford which is very similar spec wise to the 5000, it's still cheaper I think
ngc 9999
Reged: 08/13/12
Re: Tripod suggestion for my Garrett SS 10x50 [Re: daniel_h]
      #5587344 - 12/24/12 02:43 PM
daniel h,
Thank you for your suggestion, but I am not willing to get any binoculars so far. The next binocular that I'd be getting is the 22x85 but for that to happen I need about 10 to 15 years to reach the full potential of my binoculars, they are that good.
So for now an economical and temporal option is acceptable.
9 registered and 33 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, WOBentley
