Philip Levine
Reged: 03/22/07
Loc: near Boston, MA
Re: Vintage Binocular Collection
[Re: FrankL]
#5101597 - 03/02/12 06:39 PM
Hi Frank, Wow. thanks for posting the photo link for your new acquisitions. I especially liked seeing/reading about the Ross 10x50, and the Zeiss U-boat 7x50 binoculars. Lucky guy to have such distinctive binos. Phil
Gordon Rayner
Reged: 03/24/07
[Re: FrankL]
#5102122 - 03/03/12 02:49 AM
SARD 6x42
Another common problem with these is the plastic focusing grip. They tend to crack.
Also, there are better ways to design adjustment lock for the diopter setting.
45 deg LOS inclined Flak 10 x 80, the Busch design:
Most are uncoated . My dkl 81925 Schneider( Kreuznach) has cryolite coatings, which are more efficient than MgF2, but are , NB ,soluble in warm water. I have several partially coated Leitz. Sometimes one sees somewhat oddball coatings on cxn (Busch) production . IIRC, those were early
multilayers.
I have about 100 pages of the Busch 10 x 80 design Flak binocular plans, from a Leitz archive microfilmed just after the war ended.
FrankL
Reged: 07/30/09
Loc: Winnipeg, Manitoba Canada
[Re: Gordon Rayner]
#5102404 - 03/03/12 09:55 AM
SARD 6x42 Another common problem with these is the plastic focusing grip. They tend to crack. Also, there are better ways to design adjustment lock for the diopter setting.
45 deg LOS inclined Flak 10 x 80, the Busch design: Most are uncoated . My dkl 81925 Schneider( Kreuznach) has cryolite coatings, which are more efficient than MgF2, but are , NB ,soluble in warm water. I have several partially coated Leitz. Sometimes one sees somewhat oddball coatings on cxn (Busch) production . IIRC, those were early multilayers. I have about 100 pages of the Busch plans, from a Leitz archive microfilmed just after the war ended.
You're right about the SARD 6X42 focusing rings - they're plastic and not a very durable looking plastic either.
You mention "oddball coatings" on cxn 10X80's. Are you referring to the late-war red/orange coatings seen on some German binoculars? I have these on my U-Boat 7X50 and am trying to learn how they differ (other than color) from the the usual dark blue coatings. Are they an early type of multi-coating? The ones on my blc U-Boat perform very well - bright image and almost color neutral (ever so slightly warm). Also, the exterior as well as the interior of the lenses are coated unlike my beh Porro II's where only the interiors are coated (could have been coatings on the exterior but I doubt it because no traces of it can be found even at the very edge of the objectives).
Foss
Reged: 02/20/12
[Re: FrankL]
#5102609 - 03/03/12 12:00 PM
Just a shout out to Frank for the Flikr posts. Images and descriptions are outstanding, as is your collection. Thanks, Foss
Pinewood
Reged: 12/07/04
Loc: 40.77638º N 73.982652 W
Zephyr
[Re: FrankL]
#5103585 - 03/03/12 09:58 PM
Hello Frank,
Is the Zephyr coated? There are a surprising number of the earlier uncoated models floating around.
For a 7x35, the Zephyr may be a little narrow, but my main complaint is minimum focussing distance is about 7 meters. For bird watching, it is could be a little closer.
Nice collection, in any case, Arthur
Pinewood
Reged: 12/07/04
Zeiss Dialyt
[Re: FrankL]
#5103598 - 03/03/12 10:03 PM
Hello Frank,
I consider the 7x42 Dialyt to be close to the best compromise of any terrestrial binocular design. Good FOV, good ergonomics, brilliant, contrasty image, 6 mm exit pupil, neither too big nor too heavy and because of the Abbe König prisms, there is even a slight stereo effect.
Happy collecting, Arthur
FrankL
Reged: 07/30/09
Re: Zeiss Dialyt
[Re: Pinewood]
#5103728 - 03/03/12 11:08 PM
Hello Arthur,
Yes,the Zephyr is coated and it is a nice fairly color-neutral coating too. Close focus isn't great but the Rochester Zephyr's is about 1 meter closer focus than the Japanese version's.
There's something about the Dialyt 7X42's ergonomics - it's just so comfortable to carry and hold. I love this binocular. It's reputation is well-deserved.
Frank
Gordon Rayner
Reged: 03/24/07
[Re: FrankL]
#5103913 - 03/04/12 01:32 AM
I have seen the red/orange coatings which you mention on the blc KM 7 x 50. I have seen specimens, but do not have one. From the specimens which I have seen, the red/orange antireflection lens coatings were not used on the 8 x 60 handhelds, nor on the 8 x 60 deckmounts.
I have seen such red/orange coatings on several Busch (cxn) production Flak binoculars of the Busch design.
Some of the Busch design 10 x 80 from Busch, cxn, were made under great production pressure, it seems: Some of the objective lens elements were centered during cementing by simply placing them into their cells before the balsam cement had cooled. The evidence is balsam cement overflow on the cell wall.
I believe that I might be able to find material to answer your question, but it has been decades since I looked at some of the records, and finding a meaningful answer might take days.
My 45 deg. inclined 25 x 105 from Schneider Goettingen (Albert Tronnier (RIP), Chief Designer, who worked at Farrand and for Frankford Arsenal (defunct) in Philadelphia in the '50s and '60s. I corresponded with him briefly) is not coated. Most of those are not coated. The objectives are of telephoto construction, as in the similar Russian TAL (Novosibirsk) 90 deg field, yellow tint image 15 x 110, with 45 deg. inclination of the line of sight. I saw a specimen of a coated Schneider Goettingen 25 x 105 about six years ago. It is not far away. There was a 15 x 105 from them also. I have seen only one of those. IIRC, it was coated.
WW II German antireflection coatings have probably been discussed in the Peter Abrahams forum. Google gets into that forum.
Gordon Rayner
Reged: 03/24/07
Re: Zeiss Dialyt
[Re: Pinewood]
#5103939 - 03/04/12 02:03 AM
How do Abbe-Koenig prisms enhance stereo? Is not the axis of each objective lens separated from the axis of the other objective lens by the IPD distance? Am I missing something about Abbe-Koenig?
Pinewood
Reged: 12/07/04
A-K prisms
[Re: Gordon Rayner]
#5104144 - 03/04/12 08:37 AM
Hello Gordon,
On the Dialyt, the oculars are somewhat more closely spaced than the objective lenses. For a roof prism glass, this is unusual. So in comparison to Schmidt-Pechan, but not to Porro binoculars, there is a slight stereo effect.
Clear skies, Arthur
FrankL
Reged: 07/30/09
[Re: Gordon Rayner]
#5328467 - 07/21/12 03:48 PM
Additions to Vintage Binocular Collection
The following have been added to my collection since the last posting on March 2, 2012:
1) Avimo AP 1900A 7X/Barr & Stroud CF41 7X 2) Barr & Stroud CF15 7X 3) Bausch & Lomb Zephyr 8X30 4) Leitz Wetzlar Decimarit 10X60 5) Nikko(Nippon Kogaku/Nikon) Orion 6X24 6) PZO (Polish Optical Industries) LP 8X40S 7) REL C.G.B. 40 MA 7X50 8) Ross Stepnada 7X30 (pre-war version) 9) Ross Stepvue 8X30 10) Swarovski cag Dienstglas 6X30
I would appreciate any comments, further information or corrections the members of this forum could provide about these binoculars and my descriptions of them.
Once again, thanks to members of this and other forums who have provided new information about the binoculars in the collection.
The new binoculars can be viewed at: http://www.flickr.com/photos/binocwpg/sets/72157630609720154/detail/
The entire collection including additions can be viewed at: http://www.flickr.com/photos/binocwpg/sets/72157623234405689/detail/
mdowns
Reged: 06/12/10
Loc: Englewood,FL
[Re: FrankL]
#5330225 - 07/22/12 06:50 PM
Hi Frank, I have long lost your contact info.This is Mike Downs in Florida. I know I sold you some Canadian binos and I think I may have sent you a few old french glasses 3 or 4 years ago. I also commented on the HMR designation while you were searching for a definition. I hav'nt viewed your collection since then and must say the quanity,quality and rareness of your group is amazing.I doubt duescthoptik has anything on you now.Outstanding!!!!
FrankL
Reged: 07/30/09
[Re: mdowns]
#5330318 - 07/22/12 07:48 PM
And a very nice Mk 28 too. Good to hear from you, Mike.
FrankL
Reged: 07/30/09
[Re: FrankL]
#5589617 - 12/26/12 12:12 PM
The following have been added to my collection since the last posting on July 21, 2012:
1) Bausch & Lomb Zephyr 9X35
2) Bausch & Lomb (Japan) Elite Model 6128-43 8X42
3) Bausch & Lomb Zephyr 6X30
4) Emil Busch, Rathenow, Prisma-Binocle “Terlux” 9X36.5
5) Bushnell Featherlight 7X35
6) Huet Paris Modele 1933 Type 1 7X50
7) H. Hughes & Son Collimator Binocular Mk II
8) Kershaw Vanguard 7X50
9) Leitz Wetzlar, Trinovid 8X32
10) Leitz Wetzlar, Trinovid 7X42B
11) OIP Gand (Optique et Instruments de Précision, Ghent ) 8X38
12) Ross 5X40 Mk V 6E/392 5X40
13) Voigtländer Braunschweig 8X36
14) Wollensak Optical Company 8X30
The new binoculars can be viewed at: http://www.flickr.com/photos/binocwpg/sets/72157632281149716/detail/
My best wishes to the members of this forum for a happy holiday season and a good new year.
Edited by FrankL (12/26/12 12:27 PM)
FrankL
Reged: 07/30/09
[Re: FrankL]
#5806351 - 04/18/13 10:07 AM
The following have been added to my collection since the last posting on December 26, 2012:
1) Emil Busch Rathenow Marluxon 7X50 with Finnish Markings
2) Goerz Marine Trieder 6x30 in Green Color
3) Hensoldt Wetzlar Jagd-Dialyt 6X42
4) Huet Paris Modèle 1933 Type 1 10X50
5) Huet Paris Miralux 8X30
6) Huet Paris Modèle 1951 Étanche 8X30
7) Ross Steplite 7X30
8) Voigtländer Braunschweig D.F. 7X50 Imperial German Navy
9) Carl Zeiss Jena D.F. 8X30 B.C. Nr.7 Romanian Contract
10) Carl Zeiss Jena blc 7X50 Adjustable Rubber Eyecup Model (Gasmask Model)
11) Carl Zeiss Jena D.F.7X50 Smooth Ocular Model
http://www.flickr.com/photos/binocwpg/sets/72157633275485688/detail/
Edited by FrankL (04/18/13 07:44 PM)
Pinewood
Reged: 12/07/04
[Re: FrankL]
#5807578 - 04/18/13 07:47 PM
Hello Frank,
I have always found the Huet binoculars to be well made, but I have never owned a civilian model. The Paris Modèle 1951 is marked waterproof, if my French is holding up.
Happy collecting, Arthur Pinewood
FrankL
Reged: 07/30/09
[Re: Pinewood]
#5807796 - 04/18/13 09:55 PM
Hello Arthur, Yes, means waterproofed. The binocular is well-sealed with rubber gaskets so although by today's standards it may not be immersion proof it does look reasonably splash proof. I've seen a circa 1960's French military binocular manual and this manual references the binocular as "Modèle 1951, Étanche". The manual also includes the WWII U.S. Army M13 6X30 and M15 and 17 7X50's which apparently the French also used post-war. The manual describes these binoculars as Étanches but not as waterproof as the Modèle 1951 which if they were not gasket sealed is probably true. Frank in Winnipeg
