Equipment Discussions >> Classic Telescopes
moynihan
Reged: 07/22/03
Loc: Lake Michigan Watershed
Question about Carton mount dec axis
      #5591268 - 12/27/12 02:19 PM
I have an original Carton GEM that came with the 60mm f/15. There is some play in the dec axis, about 2-3 degrees, even when fully "clamped" down.
Apart from this, the head is in excellent shape, and i would really like to use it.
Has anyone had a similar problem of this kind, with this mount or similar? Any suggestions on how to approach fixing it?
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Re: Question about Carton mount dec axis new [Re: moynihan]
      #5591278 - 12/27/12 02:32 PM
I had trouble with a smooth action not being there. If you take the casting apart you'll notice where the drill bit to bore the screw holes went awry. These had to be filled in with JBWeld and smoothed. Lousy design and machining I thought. Dang thing went herky jerky on me with the slightest drag applied. Mike
moynihan
Reged: 07/22/03
Re: Question about Carton mount dec axis new [Re: mikey cee]
      #5592220 - 12/28/12 07:43 AM
... If you take the casting apart you'll notice where the drill bit to bore the screw holes went awry. These had to be filled in with JBWeld and smoothed....
By "casting", do you mean the stout metal structure the dec axis shaft runs through, or the small structure for the dec slow mo, with the plastic access plate?
BarrySimon615
Reged: 03/01/04
Loc: New Orleans, LA
      #5592293 - 12/28/12 08:52 AM Attachment (15 downloads)
Is this the mount you are referring to? The Dec. and RA on mine snug down without any slop in the movement.
Barry Simon
Edited by BarrySimon615 (12/28/12 08:55 AM)
moynihan
Reged: 07/22/03
Re: Question about Carton mount dec axis new [Re: BarrySimon615]
      #5592319 - 12/28/12 09:12 AM
Yes, apart from the silver ring at the base of the mount structure
14 registered and 25 anonymous users are browsing this forum.
Moderator:  RLTYS, BRisley
