Tonk
Reged: 08/19/04
Loc: Leeds, UK, 54N
Re: Comet C/2011 L4 (PANSTARRS)
[Re: BrooksObs]
#5688582 - 02/19/13 09:54 AM
I cannot find any "bright" comet that was ever so continuously poorly placed for observation from my site following its perihelion as is PanSTARRS!
Indeed - should be called PantsARRS
AlaskaIsCold
Reged: 11/16/11
Loc: Anchorage, AK
[Re: Tonk]
#5691917 - 02/20/13 10:52 PM
I really hope that it puts on a reasonably good show. But even if it does. Odds are I wont be able to image it. I mean really how often do you hear "It was a star filled crystal clear march night in anchorage alaska." hahaha. Still though *fingers crossed*
SabiaJD
Reged: 02/20/05
Loc: Clarks Summit, PA
[Re: BrooksObs]
#5693190 - 02/21/13 05:32 PM Attachment (39 downloads)
Least favorable viewing circumstances in decades?
At least we'll get a chance.
I seem to remember Kohoutek also had less than optimal viewing circumstances: low in the evening sky right after sunset. I was a fairly young and inexperienced observer, but I was unable to catch it, even though both Venus and Jupiter provided helpful guideposts in the sky.
In point of fact even Comet Kohoutek was far better situated in the sky for observation by northern hemisphere observers than will be PanSTARRS. Kohoutek rose steadily upward from the SW horizon and away from the twilight as January of '74 progressed. PanSTARRS, on the otherhand, will virtually parallel the western horizon from mid March until well into April, never being higher up than 5-10 degrees an hour after sunset in twilight and essentially setting by the time full darkness comes. A nice binocular object in the afterglow of dusk perhaps, but no naked eye spectacle.
Incidentally, looking back over my observing journals, which span 1957 to the present, I cannot find any "bright" comet that was ever so continuously poorly placed for observation from my site following its perihelion as is PanSTARRS!
BrooksObs
As stated above, Kohoutek was a difficult comet to find in early twilight the first week of Jan 1974. By the second week of January 1974, it was higher in altitude and easily seen against a darker background sky before setting.
This image of C/1973 E1 Kohoutek take on January 4,1974 EST. KAF 500 Slide Film, 400mm telephoto lens mounted on a equatorial mount. Taken by my friend Ken Mason
Stars on right are Alpha and Beta Capricorni
Edited by SabiaJD (02/21/13 05:35 PM)
Tonk
Reged: 08/19/04
Loc: Leeds, UK, 54N
[Re: SabiaJD]
#5693303 - 02/21/13 06:33 PM
Wow - brings back memories. Kohoutek was my first astronomical observation and my entry into the astronomy hobby
BrooksObs
Reged: 12/08/12
[Re: Tonk]
#5696198 - 02/23/13 09:04 AM
Updating my previous posts concerning the evolution of C/2011 L4, it is significant to note that no sightings of the comet seem to have been reported by southern hemisphere observers over the past 3 days as the comet moves ever deeper into the twilight. At last report PanSTARRS was 4th magnitude with a 1 degree tail, situated very low in the afterglow of dusk about 29 degrees almost due south of the Sun and visible only briefly in nautical twilight. Although continuing to brighten steadily, it seems ever more likely that the comet may become temporarily lost in twilight as its elongation from the Sun dwindles to just 15 degrees between now and March 10th. Just when it might be visually recoverable by northern hemisphere observers remains open to question and highly dependent on just how bright the comet becomes.
As of today selected photometric observations covering the past 6 weeks indicates a very steady but slow rise in the comet's brightness and development. An analysis of these data indicate that they can be very well represented by the formula:
m1 = 5.6 + 5 log(D) + 6.9 log(r)
as can be seen from the graph presented below.
These parameters, only very slightly differing from those presented earlier, but now even more certain, suggest a peak brightness of about +2.2 on or about March 10th, with a slow progressive fading thereafter taking the comet to about magnitude +5.0 by month's end.
These parameters also imply a resemblance to Comet Mrkos, 1957 P1, both in regard to observational geometry and brightness. If this is true, then PanSTARRS could put on a fairly respectable showing during late March and early April although heavily impacted by the inconvenient timing of the March full moon.
If PanSTARRS attains 2nd magnitude it should likewise exhibit a fairly broad, strongly curving, dust tail between 5 and 15 degrees in extent. How much of this will be suppressed by the bright twilight in mid March is, of course, open to question. However, those with the lowest western horizons and clearest, darkest, skies are likely to be favored since this will allow following the comet as late as possible in the dying twilight glow.
BrooksObs
Edited by BrooksObs (02/23/13 11:46 AM)
RLTYS
Reged: 12/18/04
Loc: New York (Long Island)
[Re: Tonk]
#5699332 - 02/25/13 06:35 AM
The latest issue of S&T has a good article on Kohoutek.
Rich (RLTYS)
RobK
Reged: 07/06/08
Loc: Bright, Vic, Australia
[Re: BrooksObs]
#5700794 - 02/25/13 11:29 PM
...it is significant to note that no sightings of the comet seem to have been reported by southern hemisphere observers over the past 3 days as the comet moves ever deeper into the twilight.
Not quite right, there has been a steady stream of sightings right through. You probably need to cast your net a bit wider, into southern astronomy forums, groups, blogs etc. The comet has been both a morning and evening object recently - in evening skies, I first imaged it on 17 Feb and since then there have been regular evening sightings, images and observations. Observations are the problem due to the difficulties with bright skies but some experienced observers are now reporting it in the mag 3s. I last saw it visually on the morning of 16 Feb (15 Feb UT) in fairly bright sky after it had cleared an annoying cloud band! It was beautiful, a 'classic' comet - a small, very bright inner coma (false nucleus) surrounded by a small coma swept back into a large broad fan tail, with a bright edge each side. And this was through a very modest telescope.
Regardless of its performance at perihelion and observing it in bright skies, I think you northerners have a real treat in store for you! I'm still hoping to get another look at it, but first I have to get rid of bushfire smoke and cloud which has plagued me since the 17th!
Cheers -
Rob
RobK
Reged: 07/06/08
[Re: RobK]
#5700824 - 02/26/13 12:01 AM Attachment (57 downloads)
FWIW here's my PANSTARRS images from 15 & 17 Feb. All were taken in bright sky through thin cloud. There are a lot better than these around! The garish one from 17th was particularly difficult, with the comet at less than 3-deg altitude, twilight background glow and a bright Moon illuminating a band of haze and smoke.
Rob
RLTYS
Reged: 12/18/04
[Re: RobK]
#5701081 - 02/26/13 07:22 AM
Rob, nice images of Comet Panstarrs, thanks for the views. At this point I'm quite jealous.
Rich (RLTYS)
RobK
Reged: 07/06/08
[Re: RLTYS]
#5701107 - 02/26/13 07:41 AM
Thanks Rich, I suspect I'll be the one who is jealous shortly!
I should add in regard to the image on 17 Feb that it is presented at a much wider scale than the other two - aside from the poor sky condition, there was a another hiccup in that my polar alignment slipped without me noticing and hence there was bad star trailing.
Cheers -
Rob
Special Ed
Reged: 05/18/03
Loc: Greenbrier Co., WV 38N, 80W
[Re: RobK]
#5701320 - 02/26/13 10:09 AM
Rob,
Thanks for the report and images--they look good.
BrooksObs
Reged: 12/08/12
[Re: RobK]
#5701450 - 02/26/13 11:28 AM
Not quite right, there has been a steady stream of sightings right through. You probably need to cast your net a bit wider, into southern astronomy forums, groups, blogs etc. Rob
To be honest, Rob, I peruse mostly those sites posting reliable observations from experienced comet observers, north and south, because of the often mistaken and error-prone posts one sees on so many of the "popular" astronomy websites.
As things stood, for the first time in weeks a 5-day gap (Feb 20-25) appeared in the posted data on the sites I cover. Only last evening did a new, rough, observation from the evening of the 24th get posted by John Drummon of Gisborne, NZ. John noted the comet to be "about" magnitude 3.0 with a short tail, situated very low in the sky deep in the evening twilight. This approximate magnitude is in rather good agreement with the parameters I had posted earlier.
Unfortunately, the comet's position in bright twilight and with a lack of much in the way of really suitable comparison stars is likely going to severely hamper accurate observation of PanSTARRS for some time to come, as the same difficulties will prevail when the comet first becomes visible to northern observers.
Incidentally, nice photos on your part!
BrooksObs
Edited by BrooksObs (02/26/13 11:40 AM)
krp
Reged: 11/10/10
Loc: Central Illinois
[Re: RobK]
#5702162 - 02/26/13 05:50 PM
Nice shots Rob. How much did you crop that last one?
jiahao1986
Reged: 08/19/06
Loc: Singapore
[Re: krp]
#5702188 - 02/26/13 06:08 PM
This Japanese folk Minoru Yoneto in New Zealands has been following the comet photographically with a decent setup.
http://homepages.ihug.co.nz/~mkyoneto/camel.htm
His latest photo of the comet taken on the 22nd (UT) shows a dust tail of 2 degrees. The ion tail was still rather weak though.
Anyways this is a great resource for up-to-date photographic references on the comet's development. Looking at the lovely dust tail I'm sure we northerners have something great in store awaiting.
Jack
Edited by jiahao1986 (02/26/13 06:10 PM)
Ptarmigan
Lagopus lagopus
Reged: 09/23/04
Loc: Arctic
[Re: RobK]
#5702428 - 02/26/13 08:42 PM
Nice image of PANSTARRS. Looks rather bright.
BrooksObs
Reged: 12/08/12
[Re: Ptarmigan]
#5704916 - 02/28/13 08:57 AM
For those northerners awaiting their first glimpse of Comet PanSTARRS the latest sightings reported by southern observers earlier today continue to show the comet to be following the magnitude formula I posted here last weekend very closely. The comet is now about 2nd magnitude and in addition displays three distinct short tails on briefly exposed images. There is a moderately obvious straight ion (gas) tail, a classic gently curving normal dust tail, and a much shorter and fainter feature that in years gone by was often classified as a type III "heavy dust" tail. All three taken together present a very broad fan of bright material issuing from the comet's head and spanning an arc roughly 75 degrees in breadth. What sort of tail lengths may be apparent visually in the very bright twilight of mid March for northerners remains to be seen, but with the comet's head shining at +2.0, or possibly even a little brighter, at least a few degrees can be confidently anticipated and the comet should present a fine sight for those with binoculars.
BrooksObs
Edited by BrooksObs (02/28/13 09:14 AM)
Phillip Creed
Idiot Seeking Village
Reged: 07/25/06
Loc: Canton, OH
[Re: BrooksObs]
#5705204 - 02/28/13 12:03 PM
BrooksObs
John,
I've got a set of 15x70's that are just waiting for a chance to collect some photons from this comet, so I'm definitely looking at the period between March 20 - March 25 to allow it get a little higher.
Based on your experience, does C/2011 L4 stand a decent chance of having a post-perihelion "bump" in brightness/dust production, or at least a brief period of a few days to a week or more after perihelion where the output remains the same before decreasing?
Clear Skies, Phil
OldDeadOne
Reged: 09/09/06
Loc: West Virginia
[Re: Phillip Creed]
#5705247 - 02/28/13 12:24 PM
So this comet might be a dud,after all the hype I've read about it,I hope this isn't the case for the comet coming this fall. I've been waiting for a naked eye comet with a tail for a looooong time(And I hope I get to see PANSTARRS with binoculars later in March).
Darren Bly
Reged: 07/24/06
Loc: Bakersfield, Ca
[Re: OldDeadOne]
#5705376 - 02/28/13 01:43 PM
The latest update from S&T is here:
http://www.skyandtelescope.com/observing/highlights/Comet-PanSTARRS-Updates-1...
An observation on 2/28 has the comet at mag 2.6! IF, and that is a big IF, this is correct PanSTARRS is running about 1/2 mag behind the original light curve.
We might get a very good show!
Dave Mitsky
Reged: 04/08/02
Loc: PA, USA, Planet Earth
[Re: Darren Bly]
#5705417 - 02/28/13 02:04 PM
Is the reason that comets discovered by automated survey systems such as Pan-STARRS, LINEAR, and NEAT are named after the surveys simply because there are, I assume, a number of individuals involved in conducting such surveys? I've been unable to find a source that discusses this matter.
Dave Mitsky
