SMark
Reged: 08/29/11
Loc: Atlanta, GA USA
UV Filters & Canon IS Binoculars... new
      #5589054 - 12/25/12 11:27 PM
The Canon IS 10x42, 15x50, and 18x50 come threaded for filters, and I know that many have purchased a set of filters simply to protect the objectives.
When I purchased my 15x50 IS, it came with a set of 58mm polarizer filters (the previous user was a fisherman) which I don't have a lot of use for since I use this binocular for night sky observing about 80% of the time. So I chose to purchase a set of screw-on lens hoods instead (about 20mm length) to give some protection to the objectives.
So now I purchase a Canon 10x42 L IS and the previous user installed a set of B+w F-Pro UV-Haze filters over the objectives. I'm again tempted to remove them and buy a pair of lens hoods again, but is there a good reason to leave the UV filters in place? I expect to use this binocular about 50%/50% night/day...
Thanx.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: UV Filters & Canon IS Binoculars... new [Re: SMark]
      #5589093 - 12/26/12 12:07 AM
Unless you use the binos in 'gritty' environments, during use I should think the hoods would be the better option. Flat filters can be a source of reflections generated in double-pass, autocollimation. The hoods offer the possibility of reducing the amount of extra-field light scattering about.
SMark
Reged: 08/29/11
Re: UV Filters & Canon IS Binoculars... [Re: GlennLeDrew]
      #5593176 - 12/28/12 07:18 PM
Thanx Glenn. I ordered myself a pair of hoods. Not very expensive and should do the job well.
11 registered and 43 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, WOBentley
