tclehman1969
Reged: 05/18/10
Loc: SF Bay Area, California
Modified vs Unmodified DSLR new
      #5589131 - 12/26/12 01:02 AM
Good evening, everybody!
Just a simple question: I have read a lot about the modifications to DSLR's for astrophotography use. Can somebody show me two pictures of the same celestial body photographed with the same equipment and the same number of images, etc., etc., but one from a modified and the other from an unmodified DSLR? I'd really like to see what the difference is.
Jerry Lodriguss
Vendor
Reged: 07/19/08
Loc: Voorhees, NJ
Re: Modified vs Unmodified DSLR new [Re: tclehman1969]
      #5589285 - 12/26/12 08:09 AM
Here ya go... M27 (this is mostly an O III object) with an unmodified 60D, a stock 60Da and a modified T2i (550D):
http://www.astropix.com/HTML/I_ASTROP/EQ_TESTS/60Da_60D_550Da.HTM http://www.astropix.com/HTML/I_ASTROP/EQ_TESTS/60Da_60D_550Da.HTM
Here's another article you may be interested in... down the page shows the comparison between a stock camera with and without a deep-sky filter on a red emission nebula object, the North America Nebula:
http://www.astropix.com/HTML/I_ASTROP/DSLR_HA.HTM
Jerry
WhitenerJ
Reged: 02/06/12
Loc: Waxahachie, Texas
Re: Modified vs Unmodified DSLR new [Re: Jerry Lodriguss]
      #5589303 - 12/26/12 08:29 AM
My T2i once modded showed a huge difference in the HA regions in my images. Well worth the mod!!
Jason
Hap Griffin
Vendor (Imaging Infinity)
Reged: 04/15/08
Loc: Sumter, SC
Re: Modified vs Unmodified DSLR new [Re: WhitenerJ]
      #5589543 - 12/26/12 11:32 AM
I have a couple of before and after images on my modifications page listed in my signature.
tclehman1969
Reged: 05/18/10
      #5589873 - 12/26/12 03:18 PM
You all are awesome! Thanks! So, for DSLRs at least it's the Ha that is the issue, not so much for anything else?
Just out of curiosity, if DSLRs are made to approximate human vision, does that mean astrophotography with film would also be limited? I remember taking some astro shots "back in the day" and discovering some films were more sensitive than others in various wavelengths, but didn't know if there was that much difference.
Jerry Lodriguss
Vendor
Reged: 07/19/08
Loc: Voorhees, NJ
      #5589900 - 12/26/12 03:43 PM
Yes, it is mostly Ha that is filtered out.
As far as film, it would depend on the spectral sensitivity of the particular film you use. Some used to be more sensitive to Ha. Don't know what they do now, haven't shot film in almost 10 years.
Jerry
mmalik
Reged: 01/13/12
Loc: USA
      #5590022 - 12/26/12 05:25 PM
Not an issue per se, it is more about what needs be ‘blocked’ and what needs to be 'passed'. Consider these three wavelengths:
Ultraviolet (UV) 10 nanometers (nm) to 400 nm [wide bandwidth]
Infrared (IR) 0.74 micrometers (µm) to 300 µm [wide bandwidth]
Hydrogen-alpha (H-alpha) 656.28 nm [narrow bandwidth]
Idea is to “block” first two (UV/IR) [to prevent star bloat] and to “pass” H-alpha [to capture the brightest wavelength of visible light in stellar astronomy].
H-alpha is a specific red visible spectral line created by hydrogen with a wavelength of 656.28 nm, which occurs when a hydrogen electron falls from its third to second lowest energy level. Modified LPF-2 (UV/IR blocking filter) allows the astronomically important H-alpha to pass through the narrow bandwidth at the H-alpha frequency (656nm).
Typical stock camera configuration:
1. Stock LPF-1 (IR/UV Block) does NOT block H-alpha
2. Stock LPF-2 (WB & IR/UV Block) “blocks/restricts” H-alpha
Typical modified camera configuration:
2. Modified LPF-2 (WB & IR/UV Block) “passes” H-alpha
Note: Updates/corrections welcome!
shrevestan
Reged: 04/19/12
Loc: Shreveport, LA
Re: Modified vs Unmodified DSLR new [Re: mmalik]
      #5590680 - 12/27/12 02:23 AM
All of my pictures are taken with a stock DSLR. It takes a little more work processing and some longer exposures but it's not impossible. I still use my camera for daytime use a lot so I haven't taken the plunge yet. I know it can be used with custom white balance etc.
Not saying don't get it done as it definitely is an improvement but its not a compete show-stopper if you have to wait.
nofxrx
Vendor (HyperCams & Mods)
Reged: 07/12/05
Loc: Palm Bay,Florida
Re: Modified vs Unmodified DSLR new [Re: shrevestan]
      #5591938 - 12/27/12 10:57 PM
Agreed, you can easily use an unmodified camera for galaxy, open and globular cluster, etc imaging!!
But, imho, is a waste of time on any Ha rich areas/objects..
But, pretty sure there are quite a few objects that you can image that will keep you busy for a good long while! lol
Again, imho though, modification is the best investment one can make AFTER having a decent mount
Good luck!
Hap Griffin
Reged: 04/15/08
Loc: Sumter, SC
Re: Modified vs Unmodified DSLR new [Re: nofxrx]
      #5592821 - 12/28/12 02:56 PM
Agreed. While shooting HA regions is possible with a stock camera, the signal to noise ratio of the HA objects will be much lower per frame than with a modified camera. You can increase exposure time to help make up for the lack of sensitivity at the HA wavelength, but that results in more camera noise to deal with and loss of star color due to overexposure of the stars. Or you can just shoot a WHOLE LOT more frames and stack them to raise the signal to noise ratio, but that means much less productive imaging sessions. The question is...how valuable is your imaging time under dark clear skies? A modified camera lets you capture more in less time for most showpiece objects that are rich in HA.
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Re: Modified vs Unmodified DSLR new [Re: Hap Griffin]
      #5593308 - 12/28/12 08:40 PM
All true. It depends on your interests and expectations. I consider most extended H-alpha objects to be specialty targets and an interesting challenge. If'n I ever end up with spare camera I might look at having one modified. It is an nice option to have and it's great that there are vendors available that provide that service.
northernontario
Reged: 07/01/09
Loc: Porcupine, Ontario Canada
      #5593412 - 12/28/12 09:48 PM
Are those incredible pictures on the homepage of your website taken with a stock DSLR.
The time has come to replace my aging kodak z612. I am looking at dslr cameras for the same reason.
thanks
jake
shrevestan
Reged: 04/19/12
Loc: Shreveport, LA
Re: Modified vs Unmodified DSLR new [Re: northernontario]
      #5593609 - 12/29/12 12:08 AM
Hey Jake, If you mean the homepage of Astrobin as a whole, then no, they're taken with all kinds of cameras. Everything taken in my gallery was with an unmodified Canon Rebel T1.
tclehman1969
Reged: 05/18/10
      #5593724 - 12/29/12 02:09 AM
If those images on your gallery are with an unmodded T1i, then I really don't see an urgency in making the modifications to the camera any time soon at all. Incredible images! Well done, sir!
alocky
Reged: 02/19/11
      #5593769 - 12/29/12 03:45 AM
Hi all,
I'm not much of an authority, but for what it's worth I've been using an unmodified D800 with an FSQ106ED and recently started using a CLS-CCD filter as per the links earlier in this thread. I've noticed that the one thing these filters do is make it very difficult to get any star colour - in particular the lovely yellows and golds I used to get are just whites now.
Here's my astrobin site - all the deep sky stuff is with the D800 and FSQ.
http://www.astrobin.com/users/alocky/
hope it helps your thinking.
cheers,
Andrew.
northernontario
Reged: 07/01/09
Re: Modified vs Unmodified DSLR [Re: tclehman1969]
      #5594017 - 12/29/12 09:50 AM
I'll second that.
Simply amazing Stan.
jake
nofxrx
Reged: 07/12/05
Re: Modified vs Unmodified DSLR new [Re: alocky]
      #5595365 - 12/30/12 12:02 AM
Hi all,
cheers,
Andrew.
WOW!!!
If that is with an UNmodified D800, then I cannot WAIT to see what my MODIFIED D800 can do!!
Those are brilliant images....just amazing..
great work!
Seriously guys, yes. Stock DSLRs ARE capable of BRILLIANT images, but modification makes them EVEN better.
No one ever said you HAVE to modify your camera(s)...but, the logical step up from stock is to modify your camera and get the most from your DSLR..
that's it..
For MOST people, that is the usual progression....but some never bother with modification...and that is perfectly fine!
You can still do a LOT with a stock camera.
But the point is that you can do EVEN MORE, and do it MUCH EASIER, with a modified camera
alocky
Reged: 02/19/11
      #5595461 - 12/30/12 01:42 AM
Thanks for your kind words! I've been seriously considering buying a modified D800E from Spencer's as an intermediate step to a a dedicated, cooled 16803 chip CCD, since I want to keep my unmodified D800 for daytime use. I will watch with interest to see what yours will produce.
Without wanting to sound like a rusted on Nikon fan, I've finally found a DSLR camera worthy of replacing my trusty RB67.
cheers,
Andrew.
hytham
Reged: 12/25/12
Loc: Canadian in the US
      #5595462 - 12/30/12 01:47 AM
Hi all,
cheers,
Andrew.
Hah! I was looking at your images earlier this week because I'm about to pull the trigger on a FSQ-106EDX and will be using a T2i. If you don't mind, may I ask you some questions offline regarding your configuration and set up?
Love your images and I hope to populate my astrobin site in the near future.
mmalik
Reged: 01/13/12
Loc: USA
      #5595510 - 12/30/12 03:05 AM
Few questions:
@hytham, what’s the difference between FSQ-106EDX and FSQ-106ED?
@alocky, could you post a pic of your D800/FSQ106ED/Mount setup?
@alocky, what’s the difference between D800 and D800E? Who is Spencer, can you provide the link/info?
@Brent, could you confirm if D800 takes FBCF-5DII filter?
Thanks you all in advance.
19 registered and 27 anonymous users are browsing this forum.
Moderator:  fishonkevin, tecmage
