rwfisheriv
newbie
Reged: 12/30/12
Steiner roof prism alignment new
      #5596485 - 12/30/12 04:24 PM
Can anyone share information regarding how a pair of Steiner 10x26 roof prism binocs are adjusted (I won't differentiate between collimation and conditional alignment!)? The objectives don't appear to use eccentric rings, and i'd rather not blindly start stripping off the rubber armor until I have an idea of even IF there's an adjustment screw...
Robert
BillC
on a new path
Reged: 06/04/04
Loc: Lake Stevens, WA, USA
Re: Steiner roof prism alignment new [Re: rwfisheriv]
      #5597024 - 12/30/12 10:16 PM
Robert:
Welcome to CN!
Traditional collimation techniques on hand held binoculars usually involve binoculars with a single axle or hinge. Even so, most people who claim to have collimated their binocular . . . have not. They have only made it good enough for themselves, and possibly those having nearly the same IPD, or the conditional alignment you speak of.
The Steiner 10x26 is a DOUBLE axle model (increasing the difficulty of clinical collimation by at least a magnitude) and without the correct fixture and technique, CoAl is the best you can hope for. Thats not meant to be negative; only truthful.
The alignment adjustments may be under the EPsI think it is**. I have also noticed the alignment can be thrown off if one or both hinges are loose. Sometimes just tightening the hinge/hinges will do the jobor at least make things more acceptable. I dont recall collimating this model, but Im sure someone can give you definitive positions on the collimation screws. Just be careful around the **I think its . . . crowd.
Steiner is now imported by Burris in Colorado. If you can get past the Youll have to send them in, lecture, they may be able to point you in the right direction.
Best of luck.
BillC
rwfisheriv
newbie
Reged: 12/30/12
Re: Steiner roof prism alignment new [Re: BillC]
      #5597586 - 12/31/12 09:32 AM
Thanks. I will say regardless of the binocs other faults, the glue they use is certainly first rate...
The hinge screws are under a cover on the objective side. It looks like there's some sort of adjustment screw in the hinge itself.
I'm not looking for optical perfection, just something close enough that i don't go cross-eyed looking through these things.
Edited by rwfisheriv (12/31/12 09:38 AM)
BillC
on a new path
Reged: 06/04/04
Re: Steiner roof prism alignment [Re: rwfisheriv]
      #5597835 - 12/31/12 11:55 AM
"I'm not looking for optical perfection."
A realistic and mature attitude.
BillC
9 registered and 22 anonymous users are browsing this forum.
Moderator:  Greyhaven, Knuklhdastrnmr, WOBentley
