CosmoJoe
Reged: 10/03/12
Loc: Gilbert, Arizona
Craftsman digital torpedo level idea
      #5599434 - 01/01/13 11:46 AM
i have a craftsman digital torpedo level as my altitude SC. However there is a problem, the display is a bright green, but not bright enough to shine through taillight tape. This basically ruins dark adaptation unless I'm diligent about using a eyepatch. so my idea is to buy some glass stain for a couple bucks and stain the display transparent red. does anyone know if this would work? or would it just ruin my level?
Al8236
Reged: 08/18/10
Loc: 48.9173N 122.1390W
Re: Craftsman digital torpedo level idea new [Re: CosmoJoe]
      #5599684 - 01/01/13 02:03 PM
Why not try some red celophane or rubylith to start, and forgo the stain?
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #5599710 - 01/01/13 02:16 PM
The LED display has a wavelength output that is in the green so there is very little red light available if any. I would try looking through red transparent plastic to see what level of output you get. Even a clear red candy wrapper will work for a test. You can also look thru a red eyepiece filter at the display and see how visible it.
- Dave
CosmoJoe
Reged: 10/03/12
Re: Craftsman digital torpedo level idea new [Re: DAVIDG]
      #5599892 - 01/01/13 04:04 PM
good point about the wavelength. If the red does not work, would i be able to use something to just dim it so it doesn't hurt my dark adapt?
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #5599985 - 01/01/13 05:13 PM
The display is a backlite LCD that uses LEDs for the backlighting. A LCD is polarized so if you get some polarizing plastic film you can rotate it to dim the display. If you have a pair of polarized Sunglasses you can try it out to see how it works.
- Dave
Gary Fuchs
Reged: 05/22/06
Loc: Easton, PA, USA
      #5600041 - 01/01/13 05:53 PM
Dave, would what you're suggesting work from any viewing angle?
Gary
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
Re: Craftsman digital torpedo level idea new [Re: Gary Fuchs]
      #5600145 - 01/01/13 06:59 PM
Gary
Gary,
If you can find plastic that acts like neutral desnity filter then I would try that. Maybe some of the film used to tint car windows. You could also double and triple layer it to get the amount of reduction in brightness that you want.
Happy New Year,
- Dave
AB9MS
Reged: 10/19/12
      #5600243 - 01/01/13 08:01 PM
How about welders glass?
CosmoJoe
Reged: 10/03/12
      #5600529 - 01/01/13 11:24 PM
would it be feasible to take apart the level and replace the led's with red ones?
Darenwh
Reged: 05/11/06
Loc: Covington, GA
      #5602568 - 01/03/13 09:07 AM
Look at it with polarized glasses and turn the torpedo level to see if the image disappears. If it works, which it should as David suggested, then you can get a polarizing filter for a camera (not a circular polarizer) and a filter ring (empty) of the same size then permamently mount the empty ring and screw the polarizer to it. Now you will be able to turn the polarizer to control the brightness from nearly 100% through put to 0% through put. That will be controlled with only 1/4 turn of the filter.
CosmoJoe
Reged: 10/03/12
Re: Craftsman digital torpedo level idea new [Re: Darenwh]
      #5603853 - 01/03/13 11:01 PM
sounds like a good idea. until i get a polarizer to do that i taped my moon filter i don't use to it. it seems to work pretty well. thanks for the idea, and i'm sure others will benefit from that suggestion as well.
Gene7
Reged: 06/10/10
Loc: Mid Ohio, USA
      #5604489 - 01/04/13 10:33 AM
Get some copper foil. Place a piece of foil-Paper-Foil on one end of the battery with your choice of resistor connecting the two pieces of foil, or run a small pair of wires out to a pot. Gene
Gastrol
Reged: 11/04/11
Loc: los angeles
Re: Craftsman digital torpedo level idea new [Re: Gene7]
      #5604718 - 01/04/13 12:45 PM
Or buy a new digital angle finder that is not back lit. I use a Wixey on my dob.
CosmoJoe
Reged: 10/03/12
Re: Craftsman digital torpedo level idea new [Re: Gastrol]
      #5604796 - 01/04/13 01:24 PM
you say the wixey is not backlit huh? i bet i could open my craftsman up and just break the leds
CosmoJoe
Reged: 10/03/12
      #5643672 - 01/26/13 01:12 AM
i did it. i broke the led's on the craftsman. works like a charm, no blinding light to deal with anymore
10 registered and 22 anonymous users are browsing this forum.
