Observing >> Solar
Ain Soph Aur
Reged: 08/11/11
Loc: Tennessee
New Baader Herschel Wedge for Christmas new
      #5598882 - 12/31/12 11:03 PM
Hi folks. While I've been viewing Sol with Baader film filters in all of my scopes for the past year or so, I was able to purchase a Baader Herschel Wedge (V) system with a Baader 2" Polarizing filter for Christmas (thanks Tom!) I can hardly wait for the clouds to part this weekend.
This will be used in an outstanding quality 100/1300 refractor. With the ND 3.0 + Baader Continuum and the variable polarizing filter, should I be able to make good images with a DFK 31au03 color camera or will perhaps need some of the filters that come with the (P) model?
My custom OTA was made a few inches shorter than typical for eventual binoviewer and Herschel wedge use, but I've not had the weather to check if it actually has enough back focus. Until I get a chance to verify the back focus, I leave that out of the equation.
Any heads up or advice from others who have been down this path?
Fish
Reged: 10/13/07
Loc: Norridgewock, ME
Re: New Baader Herschel Wedge for Christmas [Re: Ain Soph Aur]
      #5599915 - 01/01/13 04:25 PM
Brandon,
Firstly, congrats; you will find a wedge is the best way to go!
I have been using your basic setup for a few years now (127mm f/9 & DMK41). You will have enough filtering with your 'V' setup for the camera to image. As for focus, the wedge is essentially the same optical length as a normal diagonal. I can easily image with the camera as well as view with an eyepiece.
BTW, you should have no problem seeing granulation with 100mm and the wedge. I use a 105mm on outreaches and it shows up every time!
Regards, Marc
5 registered and 7 anonymous users are browsing this forum.
Moderator:  Bowmoreman, KWB
