bilgebay
Reged: 11/06/08
Loc: Türkiye - Istanbul and Marmari...
Re: FSQ-106EDXIII F5 Astrograph for Imaging
[Re: mmalik]
#5686961 - 02/18/13 12:50 PM
Hi Mike,
We are exhibiting at a boat show in Istanbul until next sunday. Then I will fly to Austria for CEDIC. The earliest I can take the measurement is like 10th of March. Please PM me if you don't get this info from anybody else.
Cheers
mmalik
Reged: 01/13/12
Loc: USA
[Re: bilgebay]
#5687371 - 02/18/13 05:24 PM
Sedat, here is latest from Wayne, "All 3* versions of the FSQ106ED should all have the same thread dimension of the OTA which is M133X1"; what does M133X1 mean, I don't know. Any ideas? If you know what he means then we may not need to measure the threads. Thx
•FSQ-106ED..........................(Old one)
•FSQ-106ED New “Q”............[with ‘Captain’s Wheel’]
•FSQ-106EDXIII.....................[without ‘Captain’s Wheel’]
bilgebay
Reged: 11/06/08
[Re: mmalik]
#5689036 - 02/19/13 02:51 PM
Mike- 133 is the diameter of the thread in mm and 1 is the pitch of the thread in mm again. I cannot confirm this before measuring.
Clear skies.
mmalik
Reged: 01/13/12
Loc: USA
[Re: bilgebay]
#5696491 - 02/23/13 12:13 PM
Look forward to your measurements when you can? Thx
mmalik
Reged: 01/13/12
Loc: USA
[Re: bilgebay]
#5727437 - 03/12/13 04:28 AM
bilgebay
Reged: 11/06/08
[Re: mmalik]
#5727524 - 03/12/13 06:27 AM
I know I'm on a biz trip. As soon as I reach my obs i will do this.
bilgebay
Reged: 11/06/08
[Re: mmalik]
#5735701 - 03/16/13 09:02 AM
Hi Mike,
Finally, I am able to confirm that the thread is M133x1.
To be able to use this thread, you need to dismantle one more part from the rear of the scope:
First, you need to loosen the two 1,3mm socket head lock screws then, unthread the aluminium distance piece.
Then you reach the stainless steel collar where you will see this M133x1 thread
Once you remove the aluminium distance piece and leave the tube only with the SS collars, both EDXIII and ED with Captain's Wheel will be the same. I don't have access to a first generation FSQ106ED so I am unable to confirm whether it has the same carcass as the other two or not.
Just to help visualise the situation, here are 2nd and 3rd generation FSQ106 ED scopes once again:
Hope this helps.
Before I forget, you owe me a beer Mike Removing this last adaptor was a bit risky, I sweated a lot when I was removing it. Since I didn't have any exploded views of the scope, I wasn't sure if it had anything to do with the collimation of the rear lens group. I was lucky! It turned out to be just another adaptor, nothing more
Clear skies
Sedat
mmalik
Reged: 01/13/12
Loc: USA
[Re: bilgebay]
#5738014 - 03/17/13 04:42 AM
Thanks Sedat; really appreciate it. I owe you one!
Per Frejvall
Reged: 09/28/12
Loc: Saltsjöbaden, Sweden
[Re: mmalik]
#5744866 - 03/20/13 10:56 AM
Hi all!
Just found this thread...
I have an EDXIII that I bought from OPT and transported to Sweden where I have it on my balcony on top of either the 10Micron GM1000HPS or the GM2000HPS.
I find the focuser a little "untight" and passed by TNR two weeks ago while on a business trip to Houston. The message was clear; the focuser can be adjusted - carefully.
A drop of acetone in the four hex screws at the bottom of the focuser, wait a while, then tighten them exactly the same amount.
All in all, the visit to TNR was very short and very nice (I was on my way to the airport with my collegues waiting in the car). Top guys!
/per
mmalik
Reged: 01/13/12
Loc: USA
[Re: Per Frejvall]
#5745662 - 03/20/13 05:06 PM
Thanks for the tip. This acetone remedy has been mentioned quit a bit; seems like a viable option for the default focuser. Regards
mmalik
Reged: 01/13/12
Loc: USA
[Re: bilgebay]
#5745682 - 03/20/13 05:12 PM
Sedat & all, following is the latest per Wayne Schroeder of FeatherTouch; pretty much validates our conclusion. Thx
"Yes the A35-503-FSQ106ED adapter will fit all versions of the FSQ106ED. The scopes that come with the stock captains wheel must be removed."
mmalik
Reged: 01/13/12
Loc: USA
[Re: mmalik]
#5745734 - 03/20/13 05:32 PM
Following are now "confirmed" pieces of the puzzle if someone could put together and may be share the pics of the setup; if someone may already have this, please post the pics as well and share your experience. Thanks in advance!
•FSQ-106EDXIII... (without ‘Captain’s Wheel’)
•A35-503-FSQ106ED...
•FTF3515B-A...
mmalik
Reged: 01/13/12
Loc: USA
[Re: mmalik]
#5748037 - 03/21/13 05:04 PM
Thanks to Wayne Schroeder of FeatherTouch, here is what an...
•FSQ-106EDXIII...
•FTF3515B-A...
...integration looks like; pretty impressive! ONLY now if Takahashi would also offer one out of the box? Will try contacting Art of TNR; your support will be greatly appreciated. Regards
bilgebay
Reged: 11/06/08
[Re: mmalik]
#5749254 - 03/22/13 09:17 AM
This is a real beauty! I want to thank you and Wayne to present this as a tangible option to us.
Unfortunately, current owners have already paid for the stock focuser.
Unless, someone has a real heavy rig to hang, he has to contend with the stock focuser.
Another problem I see here is losing the ability to play with the back focus as necessary. When you chose this option, you will be stuck with 1.5" focuser travel.
tomcody
Reged: 07/06/08
Loc: Titusville, Florida
[Re: bilgebay]
#5749329 - 03/22/13 09:54 AM
What do you mean by " loose the ability to play with the back focus as necessary" ? Rex
mmalik
Reged: 01/13/12
Loc: USA
[Re: mmalik]
#5756356 - 03/25/13 02:58 PM
•FSQ-106EDXIII... •A35-503-FSQ106ED... •FTF3515B-A...
Image...
Sedat and all, I have heard back from Art of TNR, he is going to see if Takahashi will consider this; this is what Art said, "I will replay it to Takahashi". Regards
mmalik
Reged: 01/13/12
Loc: USA
[Re: bilgebay]
#5756377 - 03/25/13 03:07 PM
Don't you think 1.5" travel would be sufficient for standard imaging setup, e.g., a DSLR with an off-axis guider or CCD with an off-axis guider integrated filter wheel? I understand using anything additional, e.g., a magnifier will put you beyond the back focus point. Your thoughts?
bilgebay
Reged: 11/06/08
[Re: mmalik]
#5756620 - 03/25/13 05:11 PM
I think this will depend on the individual setup. I need to study this but will not have time for a while Mike.
Good to hear that Tak will at least hear about our cries
tomcody
Reged: 07/06/08
[Re: bilgebay]
#5760094 - 03/27/13 12:00 PM
Sedat, What is the total travel in the stock FSQ106ED focuser? Looking at your pictures it can't be much more than 1.5" ? Rex
bilgebay
Reged: 11/06/08
[Re: tomcody]
#5760301 - 03/27/13 01:32 PM
Rex, IIRC it should be 3-4 cm as you are guesstimating
