giantfan92
Reged: 01/01/13
2" Diagonal upgrade for Nexstar 6se...FIRST POST
#5603083 - 01/03/13 02:07 PM
Hello everyone this is my first post on this forum! First of all let me say that this nexstar 6se is absolutely a blast and I am already hooked on this hobby just two weeks in!!!
I have heard some conflicting information about installing a 2" diagonal on my nexstar 6se.(Telescopes.com beleives it does not accept a 2" diagonal). So after hearing this I decided to go ahead and purchase two 1.25" EP's. Baader hyperion 21mm(I've heard it goes to 2") and Edmund 28mm RKE
I viewed a 2" on a friends dob and I have to say I was impressed with the comfort of the EP and I would like the ability to upgrade to nicer EP's on my nexstar in the future (Cost is not a big factor for me)
Would you guys recommend that I upgrade to a 2"? Or better than that do you guys even think a 2" is compatible?
Any help would be awesome I am already completely in love with this hobby and forum and I greatly appreciate any replies!
giantfan92
Reged: 01/01/13
Re: 2" Diagonal upgrade for Nexstar 6se...FIRST POST
[Re: giantfan92]
#5603107 - 01/03/13 02:18 PM
Oh let me also note that I do have a power-pack and a dew shield after I saw a lot of people recommending them. Dew shield comes in tomorrow!
Midnight Dan
Reged: 01/23/08
[Re: giantfan92]
#5603112 - 01/03/13 02:23 PM
Hi giantfan92 and welcome to the forum!
The 6SE will definitely accept a 2" diagonal. You'd want to get an SCT-type diagonal that threads directly onto the rear cell. You remove your current visual back piece, and install the diagonal instead. Nearly all 2" diagonals come with a 1.25" adapter so you'll be able to use your 1.25" eyepieces too.
Note that for any 1.25" eyepiece, there will be no advantage in moving to a 2" diagonal. So, while your Baader 21mm Hyperion will indeed fit into a 2" diagonal (with or without an adapter), the view you see through it will be the same as with a 1.25" diagonal.
There are 2 advantages of a 2" diagonal. One is that it is a more secure connection to the scope for larger eyepieces, cameras, binoviewers, and other heavier accessories. The other advantage is that it allow you to use 2" eyepieces.
As you buy eyepieces with longer focal lengths and wider views, you reach a point where it will no longer fit into a 1.25" barrel. In the Baader lineup, a 24mm/68° eyepiece is at this maximum. To achieve any wider view, the eyepiece needs to be designed as a 2" rather than a 1.25". And of course if the eyepiece is designed as a 2", then it needs a 2" diagonal.
The Baader combo eyepieces, with the 1.25"/2" design, are really just 1.25" eyepieces. They have a 2" part to the outer barrel so that they fit into a 2" diagonal without an adapter, but the optics are designed to fit into a 1.25" barrel.
-Dan
Arthur Dent
Galactic Hitch-Hiker
Reged: 10/23/08
Loc: South Yorkshire, UK
[Re: Midnight Dan]
#5603118 - 01/03/13 02:28 PM
Hi Giant, a warm welcome to the NexStar forum.
Yes, the 6SE will accept a 2" diagonal as shown here in this photo of my 6SE on the rear patio at home. As Dan says, you need a diagonal that has an SCT threaded locking-ring.
Also seen in this photo is a skylight filter (which is between the diagonal and the rear cell of the scope - which is why there are TWO locking rings) my RACI finder (behind the scope) and, on the top, a multi-reticle finder (much better than the standard red-dot finder IMHO). The EP is a Celestron Ultima 35mm.
Art
giantfan92
Reged: 01/01/13
[Re: Arthur Dent]
#5603128 - 01/03/13 02:32 PM
Wow!! I really appreciate the quick reply both of you guys!! What 2" diagonal would you guys reccomend?
Arthur Dent
Reged: 10/23/08
[Re: giantfan92]
#5603134 - 01/03/13 02:35 PM
William Optics 2" Carbon Fibre
Link: 2" WO Carbon Fibre Diagonal
Art
jhirsch
Reged: 10/06/10
Loc: Ohio
[Re: giantfan92]
#5603150 - 01/03/13 02:43 PM
FIrst off welcome aboard giantfan92. As you already know you've found THE site to grow your understanding and appreciation of the night sky.
Now to your questions.... Yes you can attach a 2" diagonal to a 6se. However there are a few things to consider.
1. Be careful of the clearance of the diagonal to the base while pointed at zenith.
2. While a 2" diagonal will allow you to obtain a slightly larger FOV there is no way the 6se can compete w a dob when it comes to wide views. Just can't break the laws of physics....
3. If I remember correctly I thought I had read somewhere that there are/were issues with the threads on the 2" Astro-Tech diagonals. maybe someone else can chime in on that. I have a 2" GSO and it threads on just fine. The threads are very fine so when attaching be careful that you don't cross thread it.
4. Possibly consider a focal reducer also. Drawback to the focal reducer is it WILL cause diagonal/base clearance issues when pointed at zenith unless some slight modifications are done to the dove tail. You can find them in the Links and Best of the Celestron NexStar Fourm.
Again Welcome aboard and Clear Skies
Jerry
giantfan92
Reged: 01/01/13
[Re: Arthur Dent]
#5603166 - 01/03/13 02:55 PM
Thanks for the reply! What exactly would the benefits of a focal reducer be for this scope? Sorry for the newborn questions I'm on my phone at work!
jturie
Reged: 11/19/12
Loc: Valley Forge, PA
[Re: Arthur Dent]
#5603169 - 01/03/13 02:57 PM
Art
Art--very nice setup. Can you supply the details of your RACI and the finder? What are they and how did you attach both of them to the 6SE?
Not thrilled with my red dot, and am looking for alternatives.
giantfan92
Reged: 01/01/13
[Re: jturie]
#5603203 - 01/03/13 03:12 PM
Great info guys! I want to upgrade to the 2" because I see myself buying like a 12" dob after I learn the skies really well.
Art, that is a very attractive looking scope!
Midnight Dan
Reged: 01/23/08
[Re: giantfan92]
#5603317 - 01/03/13 04:25 PM
Hi giantfan92,
Pretty much any of the major brands of 2" diagonal will do. Just be sure to get one that's has a dielectric coating. That makes the mirror surface much harder and resistant to scratches from cleaning. You DON'T need a "quartz dielectric", just "dielectric coating".
Some of the well known, reasonably priced brands are GSO, Astrotech, and William Optics. You probably won't see one bit of difference between the brands when you're looking through them. But the William Optics is just cooler looking on the outside! (costs more too, unfortunately).
-Dan
giantfan92
Reged: 01/01/13
[Re: Midnight Dan]
#5603357 - 01/03/13 04:50 PM
Thanks Dan! I will most certainly be purchasing one of those. I've had almost as much fun buying more stuff for my scope as I have had observing lol!
jhirsch
Reged: 10/06/10
Loc: Ohio
[Re: giantfan92]
#5603364 - 01/03/13 04:56 PM
giantfan92
Reged: 01/01/13
[Re: giantfan92]
#5603412 - 01/03/13 05:37 PM
Hey guys this looks like a really good buy!
Any opinions?
http://agenaastro.com/gso-2-90-99-quartz-dielectric-sct-mirror-diagonal.html
Edit: Would you guys recommend a particular barlow with this?
Lots of questions forgive me!
Edited by giantfan92 (01/03/13 05:49 PM)
Arctic_Eddie
Reged: 12/30/07
Loc: St. Petersburg, FL
[Re: giantfan92]
#5603424 - 01/03/13 05:51 PM
I have this one which works fine with the 2" diagonal on my 6SE.
http://agenaastro.com/gso-2-2x-ed-barlow-lens.html
giantfan92
Reged: 01/01/13
[Re: Arctic_Eddie]
#5603431 - 01/03/13 05:57 PM
Thanks! I was actually just looking at this, its good to hear from someone with the same scope.
Midnight Dan
Reged: 01/23/08
[Re: giantfan92]
#5603511 - 01/03/13 06:49 PM
Hi giantfan92:
That GSO model from Agena Astro will work fine. Nice thing about Agena is that they nearly always have free shipping.
I have the same barlow that Eddie mentioned above, and it is an excellent quality barlow for a good price. Someone here on Cloudy Nights did a comparison of 2" barlows a while back and this one came out even with or slightly ahead of some much more expensive models.
Seems to be out of stock now at Agena, but if I remember correctly, it was around $60 or so.
-Dan
Arctic_Eddie
Reged: 12/30/07
[Re: Midnight Dan]
#5603535 - 01/03/13 07:03 PM
It also comes with a 1.25" adapter. Both have brass compression rings.
giantfan92
Reged: 01/01/13
[Re: Arctic_Eddie]
#5603555 - 01/03/13 07:19 PM
Just bought this gso 2" 90 deg, seems like a great price! I have been googling that barlow a ton but I cant seem to find it! Now on to 2" eye peices... I'm gonna be hooked up!
If only it would stop raining lol
giantfan92
Reged: 01/01/13
[Re: giantfan92]
#5603584 - 01/03/13 07:39 PM
http://www.opticsmart.com/apertura-2-inch-2x-ed-barlow-lens-with-compression-...
Looks like I am going to settle for this. From everything ive seen it seems like apertura is the same thing as GSO.
Lets hope im right. Anyone have input on apertura?
Arthur Dent
Reged: 10/23/08
[Re: giantfan92]
#5603595 - 01/03/13 07:44 PM
Hi Jack
Can't remember the make of the RACI off the top of my head but I'm 99% certain that it is an Antares.
Multi-reticle finder (MRF) is the same kind of finder used as a gunsight with an appropriate quick-release shoe.
Both are screwed into the aluminium casting of the rear cell. The shoe for the RACI (also quick-release) has holes that were of a different spacing to the holes of the Celestron RDF - so I removed the rear cell, drilled and tapped the holes and then replaced the rear cell.
I documented the procedure here: linky-dink
Hope this helps,
Art
giantfan92
Reged: 01/01/13
[Re: giantfan92]
#5603629 - 01/03/13 08:00 PM
Just bumping this so people can view on the second page.
chuck56
Reged: 01/21/07
Loc: Chicago, Illinois
[Re: giantfan92]
#5603772 - 01/03/13 10:01 PM
Not to highjack the thread but how did you get the ota that far back on the dovetail bar?
Midnight Dan
Reged: 01/23/08
[Re: giantfan92]
#5603857 - 01/03/13 11:03 PM
Looks like the same one as the GSO to me. Most of these items are sourced from the same far-east manufacturer and just dressed up slightly differently depending on who's selling it.
-Dan
Arthur Dent
Reged: 10/23/08
[Re: Midnight Dan]
#5604112 - 01/04/13 05:33 AM
Hi Chuck
Nothing special. No extra bars/spacers etc. Just pushed the OTA as far forward as it would go until the rear cell fouled on the arm's plastic shroud (cover).
Should I need the OTA to be more forward, I'd need a rail or spacers between the dovetail and the OTA.
Art
giantfan92
Reged: 01/01/13
[Re: Midnight Dan]
#5604190 - 01/04/13 07:41 AM
-Dan
Thanks Dan, looks like I will be grabbing this 2" barlow!
CelestronDaddy
Reged: 08/22/09
Loc: Central Texas
[Re: giantfan92]
#5604840 - 01/04/13 01:44 PM
Well I did upgrade but not to a 2". I got a 1.25" Williams Optic Dielectric. Should be better than the stock diagonal that I was using. Got it for a decent price. May look at moving to a 2" down the road though. Tony
jturie
Reged: 11/19/12
[Re: CelestronDaddy]
#5605004 - 01/04/13 03:12 PM
Art:
Nice job, but your pics gave me the shakes. No way would I ever have the courage and skillset to do what you did!
Arthur Dent
Reged: 10/23/08
[Re: jturie]
#5605053 - 01/04/13 03:45 PM
Aw go on, Jack. All I needed was blind ignorance and a screwdriver. Anyone can do that!
Seriously, I reasoned that as long as I asked questions first and documented what I did step-by-step as I disassembled the scope, I should be able to put it back together again.
Thankfully, this cunning plan worked.
What I didn't want to do was entrust an expensive RACI finder to a single retaining screw or an expensive multi-reticle finder to strong double-sided tape (no matter how strong the manufacturer claimed the tape was).
Art
donnie3
Reged: 12/15/04
Loc: bartlesville oklahoma
[Re: Arthur Dent]
#5607277 - 01/05/13 08:51 PM
i have a 6"se and a meade 8"sct ota that i use on the se mount, works great. ive used my 2" diagonal on the 6" with a 26mm 2" q70 and was not impressed. using it on the 8" was a joy. truly wide field. using it on the 6" i kept getting black outs around the edge of the fov.
hazilim
Reged: 09/11/08
Loc: Arizona
[Re: donnie3]
#5619145 - 01/12/13 02:09 PM
I've used the AstroTech 2" SCT dielectric diag on both the 6SE & 8SE. Quality is great, the price is reasonable, & the diag clears the mount with room to spare. Bob
giantfan92
Reged: 01/01/13
[Re: hazilim]
#5628249 - 01/17/13 03:01 PM
Whew, quite a delay in my posting, I mostly have been looking up! I got the GSO Quartz 2" diagonal and I am glad I did because it feels very sturdy. I spent some time (9 hours lol) at a nearby darkspot with a friend and he had a 8" dob but we spent most of the time looking through my nexstar because of the very good goto tracking on it.
In addition to the diagonal I also received a 28mm RKE a 21mm baader hyperion and an 11mm ES 82 degree and wow I am blown away!!!
I feel like for now those EP's will be fine and the only thing I have left to purchase is a 0III filter because I really like looking at dso's.
kkokkolis
Reged: 09/23/09
Loc: Piraeus, Greece
[Re: giantfan92]
#5628388 - 01/17/13 04:07 PM
I would recomend a Narrowband UHC filter over an OIII. Not the Baader or Celestron UHC-s (they are Broadband) but something like the Orion Deepsky, Lumicon UHC or Thousand Oaks LP2. Nice selection of eyepieces, that give the critical 2mm and 1mm exit pupils. Since you have a 2" diagonal and the RKE is narrofield, consider later a Baader Hyperion Aspheric to get more field for some objects.
giantfan92
Reged: 01/01/13
[Re: kkokkolis]
#5629586 - 01/18/13 09:59 AM
Thank you! After hearing this and reading a huge filter review I will pick up one of these!
FishInPercolator
Reged: 04/30/13
Loc: NYC
[Re: Arthur Dent]
#5899542 - 06/03/13 12:25 PM
Nice pic... how much clearance do you have with the 2" diagonal on the 6SE? What would need to be done in the event you decided to put an f/6.3 onto it?
Edited by FishInPercolator (06/03/13 12:50 PM)
