Mr. Bill
Reged: 02/09/05
Loc: Northeastern Cal
"new" 70mm 45s
      #5605333 - 01/04/13 06:23 PM
Just found these on Big Binocular website.
http://www.bigbinoculars.com/70bt45.htm
Anybody with first hand knowledge?
Didn't 90 degree versions have effective aperture and edge of field illumination issues?
Rich V.
Reged: 01/02/05
Loc: Lake Tahoe area, Nevada, USA
Re: "new" 70mm 45s new [Re: Mr. Bill]
      #5605482 - 01/04/13 08:01 PM
It was the 100mm 90° that had effective aperture problems and considerable vignette. The MKII version of the Garrett 70mm measured full aperture, IIRC. Don't know about the illumination of field, though.
There was a long thread a while ago about these:
Garrett BT70-90 MK II's arrived!
Still looking for the reference to the flashlight aperture test; maybe it was another thread...Searching CN can be a pain sometimes!
Rich
daniel_h
Reged: 03/08/08
Loc: VIC, Australia
Re: "new" 70mm 45s new [Re: Rich V.]
      #5605618 - 01/04/13 09:42 PM
i think i remember 68mm being quoted, it was close (i agree searching CN is a pain-the lists can be huge)
GamesForOne
Reged: 09/29/09
Loc: Knoxville, TN
      #5606249 - 01/05/13 10:19 AM
Not meaning to get off-topic, but we do have one poster who recently purchased a 100mm 90° model direct from the Chinese factory and it tests at very near full aperture with the appearance of good field illumination to the edges.
I don't know if/when this model will propagate to dealers such as Garrett and Orion, but it appears the shortcomings have been addressed at least in the one sample that has been reported.
Michael Mc
peter k
Reged: 02/03/07
Re: "new" 70mm 45s new [Re: daniel_h]
      #5608451 - 01/06/13 01:59 PM
Yes. approximately 68mm effective aperture on the 90s (link to my original post).
I believe the 45-degree version has been on the United Optics web site for years--just no US distributors until now.
STEEL
Reged: 01/24/07
Re: "new" 70mm 45s new [Re: peter k]
      #5609890 - 01/07/13 10:33 AM
Beautiful optics.. attention to the inter-pupil distance 68 mm max (my eyes are almost 70 mm),hope that as soon as possible this small problem is modified.
Edited by STEEL (01/07/13 10:35 AM)
Rich V.
Reged: 01/02/05
Re: "new" 70mm 45s new [Re: STEEL]
      #5609958 - 01/07/13 11:02 AM
Good point, Steel, I hadn't noticed the 68mm max. IPD spec for these...
Rich
OBERWERK
Vendor
Reged: 06/24/03
Loc: OH
      #5610072 - 01/07/13 12:01 PM
Rich
True, and we'll soon change that. In the mean time, there is an IPD linkage stop that can be easily removed to gain additional width. The binocular's handle then acts as the new stop, and it will then go to 78mm.
kray1
Reged: 06/22/10
Loc: NC
Re: "new" 70mm 45s new [Re: OBERWERK]
      #5610400 - 01/07/13 03:05 PM
I have the 25 x 100 Garrett and the 15 x 70 Oberwerk; would the 70mm/45 binocular telescope really add that much to my viewing experience?
If so, what addtional magnifications be most beneficial for this bino?
OBERWERK
Vendor
Reged: 06/24/03
Loc: OH
Re: "new" 70mm 45s new [Re: kray1]
      #5610455 - 01/07/13 03:39 PM
If so, what additional magnifications be most beneficial for this bino?
The image quality is exceptional, very sharp at 47x (8mm eyepieces). The combination of versatility and high quality, in a small relatively-lightweight (8.5 lb.) package is quite unique.
Mr. Bill
Reged: 02/09/05
      #5610496 - 01/07/13 04:09 PM
Not to mention 45 degree oculars which are very desirable for those of us that spend most of our binocular time looking up....
Kevin...meant to ask, what is the prism clear aperture?
Am I going to vignette my 24 Pans with a 27mm fieldstop?
I think I remember 22mm being mentioned for the 90s.
Rich V.
Reged: 01/02/05
      #5610525 - 01/07/13 04:21 PM
Kray, you're pretty well set for wide field views. A 70mm BT would give you a range from 16x to maybe 50x. Your current large binos at 25x@ 2.5° and 15x@ 4° already cover the lower mags a 70mm BT would provide. The only gain would be in the 25-50x range but I think for the sake of avoiding redundancy, a 100mm BT would be more appropriate with its 25x-75x mag. range. If you only want to travel with one multi-purpose instrument, though, a 70mm BT might just be the ticket.
BTs have a big advantage over straight-through bino designs in their viewing comfort. You can sit comfortably and look through the angled eyepieces all the way to zenith; try that without some kind of p-gram or chair mount with your 25x100s.
A binocular telescope gives you the ability to reach low to medium telescopic magnifications but still retain the advantage of binocular vision. You reach a point at higher mags where a telescope is superior to a BT due to its simpler optical design and higher resolution, though.
It comes down to different optics for different purposes. I personally use fixed mag. binoculars up to 22x for WF use, a 100mm BT for 33x-71x midpower views and telescopes up to 300x or so. One or another optic I have will frame an area of the sky or object the way I want to see it!
Rich
OBERWERK
Vendor
Reged: 06/24/03
Loc: OH
      #5610542 - 01/07/13 04:34 PM
Prisms are 24mm, but there is a 23mm stop at the base of the focuser.
Rich V.
Reged: 01/02/05
      #5610553 - 01/07/13 04:43 PM
Bill, you still get 20x @ 3.3° with your 19 Pans; 4°+ @ 16x with the 24s. I can't imagine the vignette with the 24s would be so bad as to be a deal breaker.
To add to any vignette, though, there might be quite a bit of field curvature with such a short focal length objective!
Rich
Mr. Bill
Reged: 02/09/05
      #5610598 - 01/07/13 05:18 PM
Looks like 19 Pan with 21.3mm fieldstop would be ideal...
OBERWERK
Vendor
Reged: 06/24/03
Loc: OH
      #5610603 - 01/07/13 05:27 PM
Yes, that would be 20x (375mm f/l).
Mr. Bill
Reged: 02/09/05
      #5610607 - 01/07/13 05:31 PM
Guess another issue is the robustness of the collimation...looks like you would have to pull the top of the "can" to make adjustments.
OBERWERK
Vendor
Reged: 06/24/03
Loc: OH
      #5610634 - 01/07/13 05:54 PM
Yes, a pain to adjust, but it is a robust 3-point push-pull system. Once set, maintaining alignment will not be an issue with this model.
planetmalc
Reged: 10/21/09
      #5611886 - 01/08/13 12:42 PM
The studs on the sides of the tubes suggest that the instrument could be supplied with a proprietary fork mount (like Miyauchis were) - is this going to be the case?
kray1
Reged: 06/22/10
Loc: NC
Re: "new" 70mm 45s new [Re: planetmalc]
      #5614410 - 01/09/13 07:58 PM
Thanks for the suggestions. The 100s certainly would give higher mags but I think that I will be happier with the 70s at 47X. That should offer a nice increase over the 25 x 100 and less light to tame the views of Jupiter and Saturn.
12 registered and 31 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, WOBentley
