Bill W.
Reged: 10/09/05
Loc: Western PA, USA
CGE Pro Cables new
      #5603876 - 01/03/13 11:20 PM
Ok, I'm buying a CGE Pro... I need to know what cables I need. Can my autoguider cable be plugged into the CGE Pro or do I need a Shoestring USB adapter? I also need to know how to connect my computer to the mount to be controlled via Maxim 5. Celestron doesn't seem to say too much in their manual about autoguider or the aux ports. I'm looking forward to getting this beast... Thanks!
-Bill
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
Re: CGE Pro Cables new [Re: Bill W.]
      #5603995 - 01/04/13 01:49 AM
Hey Bill...it's equipped with and autoguide port. A guide camera like Orion's SSAG will have the proper cable. For your laptop, you may need an RS232 to USB adapter, but I may be wrong about this. I'd give the guys at Astronomics a call to find out for sure. But I'd be willing to bet that one of the Pro owners here will be chiming in shortly.
David
cn register 5
Reged: 12/26/12
Re: CGE Pro Cables new [Re: David Pavlich]
      #5604032 - 01/04/13 03:06 AM
I don't have a pro but AFAIK all the Celestron mounts are the same.
Autoguide uses a straight through cable between the autoguide port on my Atik camera and the port on the mount. I expect your Autoguide cable will just plug straight in.
The RS232 control for the mount plugs into the base of the HC. There may be a cable supplied with the mount, some have this, some don't.
You will need a RS232 to USB adaptor. These are notoriously unreliable, the only ones I've found to be good are the IOGear and FTDI ones.
The HC and Aux ports are interchangable, the HC and other devices designed to plug into the AUX port can be plugged into either, but NOT the autoguide port.
You can ignore the PC port. There is nothing that currently needs this.
Hope this helps,
Chris
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: CGE Pro Cables new [Re: cn register 5]
      #5604628 - 01/04/13 11:48 AM
For info on the connectivity options on the mount ... http://www.nexstarsite.com/download/NexStarCablingV5.pdf
The site also contains a lot of other useful information about the mount (and other Celestron products).
Bill W.
Reged: 10/09/05
Re: CGE Pro Cables [Re: mclewis1]
      #5605346 - 01/04/13 06:33 PM
Thanks guys, I appreciate the info!
-Bill
12 registered and 32 anonymous users are browsing this forum.
