bilgebay
Reged: 11/06/08
Loc: Türkiye - Istanbul and Marmar...
FSQ106EDXIII - Micro Touch adaptation
      #5606311 - 01/05/13 10:52 AM
Details will follow, hopefully tomorrow, but here is the video:
http://www.youtube.com/watch?v=fEVCGtBBR4A
1 count is equal to 5 microns. The total free travel is 29.58mm (5916 counts).
I discovered that my FSQ's focuser had 45 microns backlash (9 counts)
By manufacturing a bushing for the gear to fit the FSQ's fine focus shaft and an adaptor to fit the MSM30 motor to the FSQ's focuser body, I was able to use the existing motor and Micro Touch controller to drive the stock FSQ focuser.
Clear skies
Denimsky
Reged: 01/21/07
Loc: BC, Canada
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: bilgebay]
      #5606451 - 01/05/13 12:02 PM
Wow very nice clean setup!
Thank you for sharing.
bilgebay
Reged: 11/06/08
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: Denimsky]
      #5609632 - 01/07/13 04:37 AM
Thank you Donghun. Yes, it is a very neat setup indeed. I haven't seen a better motorization to date
Here are the detailed photos for those who are interested:
This is how the Tak focuser looks after removing the fine and course focus knobs.
The pinion gear is approx 1mm larger than the focuser shaft. I fixed it onto the shaft with the help of the set screw just to take the necessary measurements.
The motor will be approx at this position after the adaptation
Measuring the critical diameters
Edited by bilgebay (01/07/13 08:17 AM)
bilgebay
Reged: 11/06/08
      #5609752 - 01/07/13 08:35 AM
A week later...
Before installing the adaptor and the modified gear
I could have fit the gear with the help of a sleeve. Due to a misunderstanding I have a modified hub that fits the Tak shaft
The sleeve technique is used by Starizona
Here is the slit adaptor I produced to fit the MSM30 motor to the Tak focuser.
Motor goes in
Et voila!
The motor extends out 4-5 centimeters more compared to the knobs. Don't think this will be a problem though
I have also removed the manual focus knob on the left/port side of the scope. This is necessary to avoid the risk of damaging the motorized focusing system. Using a piece of Gorilla Band, I have sealed the cavity lest dust and other stuff should penetrate the focuser bearings
Bottom view
bilgebay
Reged: 11/06/08
      #5610079 - 01/07/13 12:03 PM
Oh! One last thing before I forget: I have fixed the lock lever in the open position with some Gorilla band until I find a better solution. To keep the lock lever disengaged is very important. Locking it can be a very costly mistake.
Edited by bilgebay (01/08/13 01:49 AM)
dflipp
newbie
Reged: 01/03/06
Loc: Central Arkansas
      #5610442 - 01/07/13 03:31 PM
Very nice!
I'd love to see the details of how you did this, but the photos aren't displaying.
-Dan
bilgebay
Reged: 11/06/08
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: dflipp]
      #5610479 - 01/07/13 03:55 PM
Thank you Dan.
According to me, the only missing information here is the drawing of the adaptor and the pinion sleeve. I hope to add those tomorrow.
The pinion gear, the MSM30 stepper motor assy and the Micro Touch Controller are sold by Starizona and Starlight Instruments.
If there is anything else you want know, please be more specific and I'll do my best to explain.
Cheers
Edited by bilgebay (01/07/13 03:58 PM)
dflipp
newbie
Reged: 01/03/06
      #5610510 - 01/07/13 04:14 PM
I see the photos now.
I already have the Micro Touch controller and MSM30 motor. I will need to get the Tak micro focuser. My scope is the older FSQ-106N, but hopefully the dimensions will be the same. I should be able to get a local machine shop to make the adaptor and pinion collar.
Thanks for posting this!
-Dan
Logan Tudor
Reged: 12/28/11
      #5610582 - 01/07/13 05:01 PM
Is it just me and my cpu, or are the pictures not visible? I only see a red 'X' in their place. Cheers, Logan.
P.S. bilgebay, if possible, could you upload high res versions to say Dropbox? Very intersted in this modification.
bilgebay
Reged: 11/06/08
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: Logan Tudor]
      #5610605 - 01/07/13 05:29 PM
Hope this link works for you. If not, pls let me know and i will load the photos to dropbox tomorrow morning.
Cheers
Mike Clemens
Frozen to Eyepiece
Reged: 11/26/05
Loc: Alaska, USA
      #5610633 - 01/07/13 05:53 PM
Super nice. 5 micron steps. How big is the critical focus zone for blue light on the FSQ?
Logan Tudor
Reged: 12/28/11
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: Mike Clemens]
      #5610867 - 01/07/13 08:31 PM
Thanks bilgebay, pics are now visible. Great post, thanks for sharing.
I wonder if the entire range of FT focus motors would work, namely: MSM20, MSM30 and MSM35? Anyone know?
I have a TOA-150 with the older focuser (not the 'B' version as also used on FSQ) and a new Microtouch hand controller (just like yours) sitting around unused. Would this be possible? Fingers crossed!
hytham
Reged: 12/25/12
Loc: Canadian in the US
      #5611109 - 01/07/13 10:55 PM
Very clean and very nice!
bilgebay
Reged: 11/06/08
      #5611318 - 01/08/13 02:31 AM Attachment (26 downloads)
Hi Mike, thank you.
In the case of FSQ, 5 micron steps are a bit coarse. The CFZ @ f/5 is 58 microns and @ f/3.6 it is 30 microns for blue light.
Attached is a spread sheet I put together for calculating CFZ for all scopes and here is a thread with some discussion on the subject based on a previous thread Jerry Lodriguss posted where he refers to his article on Focus Change Due to Temperature Variation.
If you follow the calculations in Don Goldman's article on New Critical Focus Zone you need to reduce the figure you find in my spread sheet by almost 60%.
bilgebay
Reged: 11/06/08
      #5611323 - 01/08/13 02:37 AM
Hi Logan,
I guess the motor selection depends on the load you are going to apply. In my case even the MSM20 would be sufficient but MSM30 was a better fit for an easier adaptation.
Hope you find the best solution for your case.
Clear skies.
Sedat
schling
newbie
Reged: 12/02/06
      #5612365 - 01/08/13 05:28 PM
Hi Sedat,
Great job. Funny, I am thinking about getting a FSQ106 and was tinkering with the idea of then doing exactly what you did, as I already have the Microtouch driving a StarlightInstruments focuser. Much neater setup like this.
I'll drop you a line if I get in trouble with my project when the time comes...
Clear skies
Robert
schling
newbie
Reged: 12/02/06
Re: FSQ106EDXIII - Micro Touch adaptation new [Re: schling]
      #5613546 - 01/09/13 11:36 AM
Hi Sedat,
One more thing...
You mention that you discovered that the focuser has a backlash of 9 counts (45 microns). Do you think that this is due to the planetary reduction gear, or is it linked to loose tolerancing of the rack & pinion set?
Robert
bilgebay
Reged: 11/06/08
      #5613632 - 01/09/13 12:25 PM
Hi Robert,
I will be glad to be of any help.
Hope to post the drawing with dimensions as well but it is in my other computer which is 500 miles away from me now
Regarding the backlash, I can say at least 7 out of 9 counts are coming from the Tak's rack and pinion. There should be a way to reduce this but then some other problems may/will occur.
As long as I know the backlash in terms of counts or microns, it is not that important in fact. Since the load will apply a force that will push the draw tube away from the scope, I will always reach focus from the opposite direction, i.e. by moving the draw tube inwards. The software I will be using (Sequence Generator Pro) takes care of that. When adjusting the focus, if the new focus position is further out from its current position, it moves out some further distance (which I am determining, say 50 counts) then comes to the new focus point. If, on the other hand, the new focus position is further inward compared to the current position, it just moves the draw tube in by the necessary distance.
schling
newbie
Reged: 12/02/06
      #5613840 - 01/09/13 02:38 PM
If you could get around to posting the drawings and dimensions that would be great.
With respect to backlash, I actually never bothered to try to measure it on my FeatherTouch. Just like you mention, when autofocusing I always move from out to in on the final move, making sure the any backlash has been "eaten up". The question was just technical curiosity on my part.
Robert
Denimsky
Reged: 01/21/07
Loc: BC, Canada
      #5613993 - 01/09/13 04:12 PM
Hi Sedat,
Why do you say 5 micron steps are coarse even though it is way below the CFZ ?
33 registered and 37 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
