Pages: 1 | 2 | 3 | (show all)
rgm40
Reged: 04/15/08
Loc: Western Kentucky
Eyepiece cleaning woes
      #5607507 - 01/05/13 11:19 PM
I have learned many a lesson in my 45 years of existence. Regarding eyepiece cleaning, other than learning to leave them alone and limit cleaning frequency to rare and necessary occasions, the most recent lesson I have learned is to never use anything other than a super small drop of regular Dawn dish soap, distilled water, and a cotton swab with no pressure applied, only dragging across the top lens after being saturated with the Dawn/distilled water solution. What I have learned not to do, unfortunately, is to never use "optical cleaning solution." I am not product bashing, but using pur o sol has ruined the coatings on my classic Ultima 18mm eyepiece and has left a couple of small bright spots on two others before I realized what was going on. I don't really know to what extent the damage is, because I can't tell that it has any negative effects on the view. All I know is that the 18, which is my oldest eyepiece, has several of these bright spots that I thought were just residual oil spots that were left over from the first cleaning. After about three cleanings and doubling up on the spots I figured I had done enough damage. I followed directions to the letter, using only a very light mist and microfiber lens towel. I am not a happy customer and will never let this stuff tough my eyepieces again. I am not product bashing, I can just tell you it didn't work for me, and that is a fact. It is advertised as safe for telescopes, binoculars, military optics, and a host of other things. Maybe. But it is not for me. If anyone has any idea what might have happened I would appreciate any information you would care to share. I read an article sometime ago about "contaminants" causing spots on eyepieces which was a result of the contaminant changing the composition of the coating and effectively changing the apparent color of the coating, but not actually removing the coating. This is what it looks like to me. Just lighter spots about the size of a ink pen tip or pencil lead.
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
Re: Eyepiece cleaning woes new [Re: rgm40]
      #5607534 - 01/05/13 11:33 PM
Have you tried to reclean them with Windex?
This is what TeleVue recommends:
Cleaning eyepieces
rgm40
Reged: 04/15/08
Re: Eyepiece cleaning woes new [Re: csa/montana]
      #5607551 - 01/05/13 11:39 PM
No but I did try to reclean it with Dawn and distilled water. No change. Thanks for the link. I should note that I do use a bulb duster to blow off loose particles (and on rare occasions a lens brush). I do this to get rid of anything that could cause a scratch of course.
dpwoos
Reged: 10/18/06
      #5607556 - 01/05/13 11:41 PM
Try fogging the lens with your breath and gently wiping it off with an unscented Kleenex.
rgm40
Reged: 04/15/08
Re: Eyepiece cleaning woes new [Re: dpwoos]
      #5607570 - 01/05/13 11:49 PM
If nothing else works I'll try to get a picture of it. I'll post back with results of anything else I try. Keep those ideas coming
JamesL
Reged: 10/19/12
Loc: Pacific,MO
      #5607654 - 01/06/13 01:05 AM
The link said alcohol from the hardware store is ok.
Would that be "Isopropyl" or "Denatured" alcohol?
Acetone is used to strip finishes, paint, laquer etc. Too strong in my opinion.
dpwoos
Reged: 10/18/06
Re: Eyepiece cleaning woes new [Re: JamesL]
      #5607672 - 01/06/13 01:23 AM
I use 100% pure ethanol that I got from a guy I know who is a chemistry prof at a local college. Also, I believe that TeleVue knows how to clean eyepieces, and I have used acetone (as they recommend) without a problem. I wouldn't use acetone (or alcohol) on eyepieces that use plastics and/or paint, e.g. home made ones. That said, I have largely switched to ROR, finished off with a breath fogging and wiping with an unscented Kleenex. Really works well for me.
Scanning4Comets
Markus
Reged: 12/26/04
Loc: Deep Space!
      #5607687 - 01/06/13 01:55 AM
I've been using a brush from the lens pen, then a blower bulb, to remove anything first then I use a Q-tip with my own solution, (90% isopropyl + a drop of dawn dish soap + distilled water, 1/2 & 1/2 solution mix), then a huff on the lens and a rub with a lens pen for years with excellent results.
I replace my lens pens every couple of months because lens pens gather debris and can re-deposit debris back onto a lens surface..... I only clean mine when I have to. I may go to the unscented kleenex for my final cleaning because lens pens are expensive to keep on buying.
planet earth
Reged: 09/07/10
Loc: Ontario
      #5607763 - 01/06/13 04:32 AM
I doubt the cause was the pur o sol.
Acid dew possibly over time, storage conditions, the coatings themselves?
But yes when in doubt, change to another product/method.
My older Meade plossls have a few spots as do my old 7x50 binoculars, no effect on the view though that I can see.
Sam
Edited by planet earth (01/06/13 04:49 AM)
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Re: Eyepiece cleaning woes new [Re: planet earth]
      #5608208 - 01/06/13 12:06 PM
From least harmful/effective to most:
1) Water. Doesn't dissolve eyelash oils or pollen. Not recommended.
1a) Breath on eyepiece. Can't say why this is more effective than just water, but it is.
2) Pure isopropyl alcohol. Without soap added, this can't clean a lot of organic debris. Just not strong enough. Safe, though. Does a decent job on already fairly clean lenses.
3) Water/soap/alcohol mix (like ROR). Very effective to remove organic contaminants. Doesn't clean everything off eyepieces, though, without multiple cleanings. I had some thick mascara streaks that required several cleanings with something harsher.
4) Acetone. Much better solvent. Not harmful to lenses, but can dissolve plastic. If the cleaning is anywhere near a plastic baffle or rubber eyecup, don't use it. It's quite safe on all-metal eyepieces, though, and cleans off some stains that other cleaners can't.
5) Methyl Ethyl Ketone (MEK). This will take off ALL substances on the lens and requires ventilation for safety. It has removed mildew and chemical stains where nothing else would touch the discolorations. It won't harm the lenses with short-duration contact, but I only recommend it if the eyepiece has what looks like mildew or rust discoloration on the lens (likely to be a classic eyepiece being restored after disassembly).
It might interest you to know that I have tried, just for the sake of an experiment, cleaning brand new eyepieces right out of their boxes. Guess what? They got cleaner. Noticeably. It seems that many companies don't maintain perfect cleanliness in assembly one the eyepiece is put together. I've even seen a brand new eyepiece come out of the box with a fingerprint on the eye lens (!).
People on this forum are obsessed with picayune details that distinguish one eyepiece from another, but seldom address the possibility the eyepieces being tested might not be clean. Though one could become obsessed with cleaning, a judicious amount of cleaning at regular intervals or whenever anything foreign is seen on the lenses is definitely called for. Done right, no damage will result, and the eyepiece will be cleaner.
Most often, I see little tiny dots that probably are from the eyelashes touching the eye lenses or from accidentally breathing on the eyepiece lens. I don't let those sit because if left in place they can cause permanent damage to the lens coatings in time. But if there appears to be small shiny dots on the eyepiece, they are probably cleanable. The small dots I've seen that were where small dust particles present on the lenses interfered with the coating process were all invisible to the eye and only visible through a 20X loupe or microscope. I suggest you NOT inspect your eyepieces that way unless you realize that nothing is perfect.
If you get pure alcohol or acetone, make sure they are "reagent grade" or as pure as you can find. No additives. I've been able to find 90% pure IPA and 90+% pure acetone in local stores. ROR works great 99% of the time.
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
Re: Eyepiece cleaning woes new [Re: Starman1]
      #5608292 - 01/06/13 12:50 PM
6) Human spit. Ultimate remover of organic compounds from glass.
bremms
Reged: 08/31/12
Loc: SC
Re: Eyepiece cleaning woes new [Re: johnnyha]
      #5608349 - 01/06/13 01:14 PM
I never use the dish liquid on lenses unless it's out of the housing. It requires too much liquid to clean it off properly.
Acetone and IPA seem to work on different oils. Maybe an IPA, acetone, and dist H2O mix. Cleaning soulutions are like talking about oils on an automotive forum..
bremms
Reged: 08/31/12
Loc: SC
Re: Eyepiece cleaning woes new [Re: bremms]
      #5608360 - 01/06/13 01:16 PM
I blow them off with filtered compressed air.
frito
Reged: 10/05/12
Loc: Fremont, CA
      #5608491 - 01/06/13 02:11 PM
electronic component stores may carry highly pure alcohol, i get mine from fry's electronics its made by MG Chemicals and its 99.9 something pure. apparently too pure for california because on the bottle it states that you must dilute it 25% by weight with water or acetone to legally use it in this screwy state
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
Re: Eyepiece cleaning woes new [Re: frito]
      #5608530 - 01/06/13 02:31 PM
First be sure that there is no gritty material on the lens surface that could scratch the coatings. Use a Q-tip with alcohol to remove any visible particles.
Next, I use one or two Zeiss lens cleaning tissues, which come impregnated with a small amount of pure alcohol. You don't have to be super careful with these as they will not force any alcohol between the lens elements. Usually the wipes leave a bit of residue, which I remove by fogging the eyepiece lens by breathing on it, followed by wiping with a small section of Viva paper towel. These towels are soft and not contaminated with perfumes or oils. To avoid introducing oils from my own hands I am careful not to touch the Zeiss wipes or the paper towel with my fingers except in places that will not directly contact the lens.
This method has worked well on eyepiece lenses and objectives up to 8" in diameter.
JimC
Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
      #5608662 - 01/06/13 03:42 PM
Denatured alcohol is what I use, it removes oils and other stuff without harming glass. I use clean Q-tips dipped in it, eyelash oil and film is removed and it doesn't have the plastic attacking properties that acetone does when it's ethanol mixed with methanol.
Taras
wky46
Reged: 12/12/05
Loc: west Ky.
      #5608953 - 01/06/13 05:54 PM
Don, those are all excellent points (as always). Especially the one you make regarding evaluations between ep's that may not be clean. I've often wondered about this too. Maybe any future reviewers, whether it be a shoot-out between several ep's or simply a review of a single ep, should state they've all been cleaned first (regardless of how they 'look'). I've played many and have owned several high-end guitars in 40+ years of playing and MOST critizisms of tone directed at certain guitars are usually (I'd bet money on it) the result of strings that are old and have lost their tone and timbre. Anytime I read a review now of guitars (acoustic generally) I want to know if their using new strings (unfortunately something which they never say)
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
      #5608995 - 01/06/13 06:26 PM
This is difficult lesson for all of us to learn regarding all of our optics. There are times optics should immediately be cleaned. However, too often more problems occur from over cleaning than cleaning too little.
tag1260
Reged: 10/07/12
Loc: Ohio, USA
Re: Eyepiece cleaning woes new [Re: Scanning4Comets]
      #5609136 - 01/06/13 07:55 PM
What about the eyeglass lens cleaning solutions that are available to clean your glasses?
I'm not a chemist but here's the MSDS of the stuff I'm talking about.
http://www.calaccessories.com/MSDS_Sheet.pdf
bremms
Reged: 08/31/12
Loc: SC
Re: Eyepiece cleaning woes new [Re: tag1260]
      #5609387 - 01/06/13 10:41 PM
Really just water with a little alcohol and photo flo.
18 registered and 27 anonymous users are browsing this forum.
