johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
Re: Denk Binotron rollout new [Re: bcuddihee]
      #5601518 - 01/02/13 04:17 PM
Thanks I will check that out!
beatlejuice
Reged: 04/05/11
Loc: Hamilton, ON,Canada
Re: Denk Binotron rollout new [Re: johnnyha]
      #5601627 - 01/02/13 05:25 PM
what happened to make this thread twice as wide as it was at the start? Annoying!
Eric
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: Denk Binotron rollout new [Re: beatlejuice]
      #5601709 - 01/02/13 06:26 PM
The last post on page two has ridiculously long hyperlinks. They should have been shortened, as per the suggestions/guidelines posted at the tops of at least most Forums.
bcuddihee
Reged: 11/04/06
Loc: Cincinnati Ohio
Re: Denk Binotron rollout new [Re: GlennLeDrew]
      #5601757 - 01/02/13 07:03 PM
Eric..i was simply trying to answer a question. Sorry for yor inconvienience.
beatlejuice
Reged: 04/05/11
      #5601926 - 01/02/13 08:41 PM
Isn't this convient link
the same link without the extra length?
Eric
bcuddihee
Reged: 11/04/06
      #5601936 - 01/02/13 08:48 PM
yes it is.. but isn't civility even more desirable.
beatlejuice
Reged: 04/05/11
      #5601954 - 01/02/13 08:56 PM
No incivility implied on my part, I was just pointing out a better way of doing something as I am sure there are others who dislike having to scroll in both directions to read a thread. If you are not sure how to do it I would be happy to guide you.
Cheers
Eric
panhard
It's All Good
Reged: 01/20/08
Loc: Markham Ontario Canada
      #5601958 - 01/02/13 08:57 PM
Shorter links are desired.
drprovi57
Reged: 06/13/06
Loc: Virgina USA
      #5603776 - 01/03/13 10:03 PM
Thank you for the insights.. The CDK 12.5 has about 7" of back focus , so should work
Best
Jason
Mr. Bill
Reged: 02/09/05
Loc: Northeastern Cal
Re: Denk Binotron rollout new [Re: drprovi57]
      #5604783 - 01/04/13 01:19 PM
I have the Denk IIs....other than picking up 1mm of clear aperture with the Binotrons (and collimation adjustment) what would I gain with the new model that would justify buying?
If I was starting from scratch, I certainly would buy the new model.
Jim7728
Reged: 04/10/05
Re: Denk Binotron rollout new [Re: Mr. Bill]
      #5605134 - 01/04/13 04:18 PM
Same here. Introduction price is a nice deal, but I'm not about to sell my Standard PX and TV Bino-vue for them.
FWIW, I like the power switch for Solar, Lunar and Planets. Gotta find that mod thread for mating the TV Bino-vue to the Denk PX.
teskridg
Reged: 01/15/08
Loc: PA
Re: Denk Binotron rollout new [Re: Eddgie]
      #5606176 - 01/05/13 09:27 AM
What I like to know is that the Denk II still loses the aperture for the other two magnification factor (not the reduction arm is used): I think it is 1.2X and 2.8X.
Remember, this problem is somewhat unique to telescopes with moving mirror focusing and baffles, though it could be encountered in some refractors if the in-focus allows the front of the focuser tube to cut into the light cone, which is a very real possibility in some cases.
To answer the question though, in the case of the MCT, I was loosing apeture in reduced mode (severe aperture loss) and staight through mode (minor loss).
This has to do with the fact that the Super-system I used was based on the use of a 2" diagonal.
The C14 and C8 both start to loose aperture once the back focus goes past about 200mm. The C9.25 I think starts loosing aperture once the back focus goes above about 170mm and the falloff is quick.
As an example, in my C5, as measured directly, I am using a back focus of 203mm, and the 127mm scope is being reduced to 122mm.
The Denkmeier System I used was based on a 2" diagonal, and the entire back focus required to use it was about 230mm or so.
With 230mm of back focus, the C14 is working at slighly less than 14" of apeture (Maybe 13.75") and the C8 would be working at about7.7". The plot that I have for the C9 suggests that the 230mm of back focus would give an aperture of 8.75".
Because the aperture is reduced, the central obstruction becomes bigger by percentage of aperture so the contrast is further lowered.
This is in straight through mode.
With the High Power arm in, the back focus requirment is reduced. I don't know how much it changes, but this would mean that the high power arm will give the system more apeture than straight though, because the mirror needs to be moved back slighly to re-position the focal plane.
Now I can only be fair about this and say that many people (perhaps most people) will not care about this very slight loss in performance.
So, it only matter if it matters, but for those that want to get the absolute best performance from their SCT or refractor, they want to make sure that they are not working with a reduced aperture.
If the new Denkmeier can be attached to a Baader Prism or other device that will shorten the light path, aperture loss can be reduced or prevented in SCTs, MCTs, and many refractors that were not designed to allow a full apeture when the focuser was fully racked in (and this is not at all unusual, though after the Stellarvue debacle 10 years ago, I think it doesn't happen so much anymore).
Again, the back focus is the issue, and the point where aperture loss is very model specific (The C11 has the loosest baffle of the Celstron SCTs).
But if the back focus is over 200mm, most SCTs will start loosing aperture, which means in straight through or reducer mode, many will work at reduced aperture. With the high power arm in, the amount of apeture reduction will either be reduced, or in some cases, perhaps even eliminated.
The key to doing this in these scopes is the Baader approach where the binoviewer attaches directly to the top of the diagonal and keeping the connection to the telescope as short as possible.
If someone wanted to use the new Denkmeier in an SCT and keep the system working at full apeture, they would need to go to a Baader type diagonal with a short connector (Like the Baader SCT connector which only adds 15mm of back focus) and the Prism, which only adds I think 38mm of back focus. The Mark V binos add about 120mm of back focus, so this system will have a total requirement of about 173mm.
But in my Denkmeier, the power-switch alone added 18mm of back focus, so right there, if you go with a standard 2" SCT adapter and a standard lenght 2" nose, even if you used a Baader type diagonal, you are well over 200mm, which is the point that many SCT models will start to loose aperture.
Here are the numbers....
The Baader SCT adapter requires 15mm of back focus.
The Baader Prism requires about 38mm of back focus.
the Power Switch requires about 18mm of back focus (unless they have made it thinner).
A large prism bino will require about 120mm of back focus (this is what the Mark v requries).
Add this up and you get 191mm. If someone wants to use a powerswitch and avoid aperture loss with a moving mirror scope even in straight though mode, this will be the best configuration to use.
A 2" diagonal alone will put you well over 200mm, even if it is the Baader 2" diagonal.
Thanks a lot, Eddgie! I might not have cared about the effective aperture loss at low power switch setting in my CPC-1100 if you hadn't started this some months ago. Seriously, I'm willing to trade this aperture reduction at low power for the wider field for certain DSO's like M35. In addition, Eddgie, you can get customized high power lenses for the Denks and Earthwins that are less powerful and more convenient perhaps for you. I'm curious to find out from the first users of this new system if the extra mm of clear aperture renders less vignetting with 24mm Panoptics in the reduced power x switch setting than presently with 26mm clear aperture binoviewers. Tim
Edited by teskridg (01/05/13 09:45 AM)
Space Dragon
Reged: 02/19/12
Loc: Scotland UK
Re: Denk Binotron rollout new [Re: teskridg]
      #5606566 - 01/05/13 12:57 PM
I use the Earthwin PFS-B with Power/Filter switch [the model optimised for Newts] in a CPC 925. It was a great price.
In this configuration, the barlow acts as a reducer but not as reduced as the reducer itself.
I also have a 2x Barlow OCS which screws into the nosepiece.
There's about 7 turns of the focuser between each point.
I did consider changing out this glass from the powerswitch for one that would act as a barlow but I've found that I use the less reduced option a lot as the vignetting is hardly noticed and on the rare occasions I want to Barlow, screwing the OCS on only takes seconds.
I use the Baader T2 Diagonal with the 10mm SCT connection and a T2 - 2" adapter on the other side.[It's not ideal but the nosepiece on the Binos is not removable].
The vignetting is noticeable with 24mm Pans in full reducer mode, less so in half reducer and not in straight through or Barlow mode.
I did do the aperture flashlight test and did notice some loss with both reducers but not as much as I'd expected.
faackanders2
Reged: 03/28/11
      #5607284 - 01/05/13 08:57 PM
You can purchase the 45mm clear aperture 1.2x Multipurpose OCS seperately.
Jeff B
Reged: 12/30/06
Re: Denk Binotron rollout [Re: teskridg]
      #5607928 - 01/06/13 09:12 AM
I wonder if the power switch inlet becomes the limiting diameter now.
beatlejuice
Reged: 04/05/11
Re: Denk Binotron rollout new [Re: MikeBOKC]
      #5625293 - 01/15/13 10:05 PM
Had an informative talk with Russ today and finally purchased my first binoviewer: The Binotron-27. Will probably be over a month before it arrives so now the anticipation and waiting begins.
Eric
dajebriza
Reged: 01/15/12
Loc: Germany
      #5625661 - 01/16/13 05:36 AM
I bought one too. I sold my Denk II supersystem with filter switch (hardly used it) for the price of the Binotron-27 supersystem sale, so it was break-even for me to upgrade. Looking forward to getting it!
t.r.
Reged: 02/14/08
Loc: Upstate NY
Re: Denk Binotron rollout new [Re: dajebriza]
      #5626056 - 01/16/13 11:50 AM
This is quite an offer for those just getting in...I'll have to stick with my Denk II's though, nothing to gain.
ckwastro
Reged: 11/23/05
Loc: Tempe, AZ
Re: Denk Binotron rollout new [Re: t.r.]
      #5627665 - 01/17/13 09:14 AM
I've got the Denk standards, and have been debating whether or not to upgrade to the Denk II or the Mark V. Now I'm considering the Binotron or the Mark V. Decisions, decisions........
denis0007dl
Reged: 04/17/12
Loc: Croatia
Re: Denk Binotron rollout new [Re: ckwastro]
      #5627770 - 01/17/13 10:29 AM
Binotron sounds really good, but he has 26mm Clear Aperture prisms, while Mark V has 28mm! I really like my MkV
0 registered and 6 anonymous users are browsing this forum.
Moderator:  TG, Geo557, Joe C
