Privacy Policy |
Please read our Terms
of Service | Signup and
chrisg
Reged: 02/15/09
Can this be adapted?
#5608068 - 01/06/13 10:57 AM
Helllo everyone. I've een thinking of getting an AYO Mark 2, wondering if I can adapt my tripod legs to attach to the AYO. I've got a standard aluminum surveyor tripod from Stellarvue that has a 5/8"-11 bolt, AYO states that it can attach to standard Vixen SP/GP and SX tripods with a 3/8" center bolt. I imagine I could find a 3/8" center bolt for my surveyor tripod but is that a standard part that can be easily found/adapted? What's the typical way to make this work?
ccs_hello
Reged: 07/03/04
Re: Can this be adapted?
[Re: chrisg]
#5609173 - 01/06/13 08:23 PM
Vixen is 10mm not in imperial unit. Consider putting a sleeve on the tripod side to reduce the size.
PaulEK
Reged: 05/25/08
Loc: Wisconsin
[Re: ccs_hello]
#5609580 - 01/07/13 01:45 AM
10mm is not far from 3/8-inch, and the threads are close, too: I use 3/8" threaded rod to attach my Vixen Super Polaris to its wooden tripod with a homemade spreader. But I'm not using lovely new equipment.
I'm not familiar with the items you're thinking about, but did look at photos of them. I couldn't find one with a picture of the top of the tripod. If you are talking about just a bolt that has to feed through a hole from the bottom and screw into the AYO Mark 2, any decent hardware store will have both American and metric bolts of just about any size, thread pitch, and length you could need, with washers to cover any gaps, and probably sleeves (both nylon or metal) for a tighter fit in the hole in the tripod, if needed.
Sorry if this is an ignorant answer; just trying to help!
ccs_hello
Reged: 07/03/04
[Re: PaulEK]
#5609701 - 01/07/13 07:40 AM
(Sidenote)
RE: 10mm vs 3/8" screw...
This topic has been discussed in the past. They are very similar but the diameter and thread pitch are still different.
Many inexpensive mounts are using soft Aluminum Alloy metal (pot metal) and can easily be cross-threaded. That's is why a mismatched bolt (3/8") can be threaded into a 10mm hole.
Disadvantages: one way and one time method to destroy a previously proper-fit, strong holding strength, and mechanically sound coupling.
Advantage: save few cents and 3/8" is easy to purchase in US.
My take, don't go that route. Short-cut? Yes. But... One way street and irreversible.
28 registered and 20 anonymous users are browsing this forum.
