Telescope Specific Forums >> Meade Computerized Telescopes
dogeddie
Reged: 03/26/10
Loc: Wisconsin, USA
firmware version ETX 125 current?
      #5609437 - 01/06/13 11:13 PM
I have an ETX 125PE and when I fire up the Autostar the very first screen says it is 43e - is that current? Is it worth an update if not, as I have never tried that. I believe I have the original 497, not the 497ep handset. Thanks
Edited by dogeddie (01/06/13 11:28 PM)
dogeddie
Reged: 03/26/10
Loc: Wisconsin, USA
Re: firmware version ETX 125 current? new [Re: dogeddie]
      #5615744 - 01/10/13 03:38 PM
Wow - must be a harder question than I thought!
Photobud
Reged: 01/07/13
      #5615881 - 01/10/13 04:54 PM
The #497 ETX Autostar is what the ETX 125 came with.
Note at Meade Support:
Important note about #497 Autostars. The classic #497, and the newer #497EP, utilize different firmware that is not interchangeable. However, the #497EP Autostar is backward compatible with prior generation telescope that used AutoStar technology. If you have an older version of the #497, it will continue to work with your existing telescope. AutoStar Updater 5.9 or greater can detect either version and load the appropriate firmware.
Current version shown for that controller is 43Eg
Also at Meade Support:
#497 AutoStar hand controller software update.
Version 43Eg (479 KB) is available. To get this new version, use either the 43Eg link to download and unzip the file to the Ephemerides directory of the Autostar Update (ASU) installation directory; or use ASU and press "Upgrade Autostar Software Now" and ASU will download and upgrade the handbox. If you don't already have ASU use the link on this page to download and install it on your PC. New Initialization instructions for Autostar exist.
Safest way is to use Autostar Update as it will check for compatibility.
Edited by Photobud (01/10/13 04:55 PM)
dogeddie
Reged: 03/26/10
Loc: Wisconsin, USA
Re: firmware version ETX 125 current? new [Re: Photobud]
      #5616133 - 01/10/13 07:40 PM
Thanks. That whole thing makes me very nervous. The old "leave well enough alone" saying. I got a replacement scope from Meade back in July 2010, so I assume that they would have the most current firmware on the refurbished scope they provided me with. Plus I see a date of 4/13/07 for the 43eg version, so I assume I must be okay. If one did decide to try the update, specifically what would you have to re do to the autostar or data to re enter? Thanks alot
dogeddie
Reged: 03/26/10
Loc: Wisconsin, USA
      #5616312 - 01/10/13 09:37 PM
Also, the cable you are to use to connect the Autostar to your pc still has the old serial RS-232 port, so I would need an adapter. Meade wants $50 for that. Then you have download different drivers to use it. Sounds like a mess.
blb
Reged: 11/25/05
Loc: Piedmont NC
      #5618921 - 01/12/13 11:54 AM
If it ain't broke, why fix it?
dogeddie
Reged: 03/26/10
Loc: Wisconsin, USA
Re: firmware version ETX 125 current? new [Re: blb]
      #5620047 - 01/13/13 12:01 AM
Agreed
cavefrog
Reged: 11/11/08
Loc: loozyanna
      #5627263 - 01/17/13 12:09 AM
" specifically what would you have to re do to the autostar or data to re enter?"
cost depends on how handy you are. one can make their 505 cable pretty easy using a telephone handset cord and a serial D9 connector. you would also need a serial to USB adapter. I would only go for the Tripplite Keyspan for about $30. download meade's updater program, and load whatever version firmware you want. (one can also use previous versions if wished) follow the on screen directions. after loading the 497, one has to do a full reset, which clears all your data... time, date, site, and whatever else that does not come with a brand new controller. then calibrate, and last but not least, train the drives.
Theo
dogeddie
Reged: 03/26/10
Loc: Wisconsin, USA
Re: firmware version ETX 125 current? new [Re: cavefrog]
      #5627577 - 01/17/13 08:15 AM
Thanks for the help - learning more all the time
Edited by dogeddie (01/17/13 08:15 AM)
wd8sbb
Reged: 08/26/12
Loc: Southwest Ohio
      #6213996 - 11/24/13 08:27 PM
I am late to this one, but maybe someone will also be looking for the info. from the 43Eg build.
readme43Eg.txt follows:
Upgrades to 33Ef
Added Zip Codes.
Some serial strings fixed.
Upgrades to 33El
Fixed site problem
Fixed LST display
Upgrades to 34Ec
Fixes moon tracking problem
Improved pointing on second star with LNT module
New LX90 scopes added
Upgrades to 40Eb
Improved pointing on Alignment Stars after Cal Sensors.
Park position now shortest distance on ETX scopes.
Park position fixed after automatic alignment.
Smart Drive is now normalized.
Please see the attached file for the new operating instructions.
Upgrades to 40Ee
Fixed Comets
Add Brightest Star to Utilities, so scope will always show the name
of the alignment stars.
Upgrades to 40Ef
Fixed Polar mode for LX90's (10 & 12)
Upgrades to 41Ec
Added GPS for new LX90 GPS scopes.
Fixed #909 Accessory Port Module to work with LX90's 10 and 12 inch.
Fixed problem on DS2000's mounts with LNT module.
Couple of data base corrections.
Upgrades to 42Ed
Displays how far off polar on two star polar alignment.
Fixed park position on LXD55/75's
Get serial command for daylight savings (:GH# returns 0 for disabled 1 for enabled)
Set serial command for daylight savings (:SH0# disables, :SH1# enables)
Upgrades to 43Ea
New scopes added
Fixed error with longer strings
Upgrades to 43Ed
Fixes problem with LNT module and Reverse L/R on
Upgrades to 43Eg
Added :GW#, :AL#, :AA#, & :AP# serial command.
Fixed IC & NGC in Guided Tours.
3 registered and 7 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
