Privacy Policy |
Please read our Terms
of Service | Signup and
TimP
Reged: 02/24/09
Hyper Tuning My CGEM DX
#5607361 - 01/05/13 09:49 PM
Hello all. Long time lurker first time poster. I am in the middle of Hyper Tuning my CGEM DX. I pulled the motors out and gave them a few rotations in both directions. The RA motor turns fine in the clock wise direction but when I rotate it in the counter clock wise direction it has a sticking point every once in awhile. There is no sticking of the Dec motor. Heres the question. Do you think I should swap the RA and the DEC motors or should I search for another motor for the RA ? Thanks Tim Patton
mak7
Reged: 09/29/07
Loc: light polluted Phoenix AZ
Re: Hyper Tuning My CGEM DX
[Re: TimP]
#5609120 - 01/06/13 07:44 PM
Tim, First thing I would do is email Ed Thomas at Deep Space Products and ask his opinion on a solution. He has been through many, many mounts and knows all the fine tuning they need. Ed is a straight shooter and will give you his honest opinion. I assume you purchased a HyperTune Kit from him, so he will be happy to work with you. Brad
TimP
Reged: 02/24/09
[Re: mak7]
#5609213 - 01/06/13 08:49 PM
Thanks Brad I powered the motor and it doesn't have a sticking point that I can see. I'll put it back in and see how it acts after the rebuild. Frankly as tight as the worm gears were I should be surprised if it doesn't have motor problems. When I removed the clutches the mount didn't move. I had to manually move it. Good ole Chinese quality control. But this is what I have to contend with in my price range.
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
[Re: TimP]
#5609448 - 01/06/13 11:22 PM
That's probably the best thing to do first since it is easy to remove the motors at any time. See how this one does, if it seems to be problematic, then I would recommend getting a replacement from Celestron but it may be fine as it is.
TimP
Reged: 02/24/09
[Re: EFT]
#5609466 - 01/06/13 11:35 PM
Thanks Ed. Everything is going great so far. I had to stop working on the mount until I get a tool I need to take off the end caps to the worm gear. This is my second mount. Celestron exchanged the first one because they couldn't figure out the problem. As I take this one apart it almost looks like someone has taken it apart before. Hmmm, I guess you never know.
22 registered and 29 anonymous users are browsing this forum.
