Telescope Specific Forums >> Meade Computerized Telescopes
JR#8
Reged: 08/31/04
Loc: Edison, NJ
Tri-pod or pier new
      #5609167 - 01/06/13 08:16 PM
Looking to get a wedge for my 10" lx200 SMTGPS. I'm wondering if it will work well with the field tri-pod or should I look to builg/get a pier. Looking for the least vibration possible.
dmdouglass
Reged: 12/23/07
Loc: Tempe, AZ
Re: Tri-pod or pier new [Re: JR#8]
      #5609262 - 01/06/13 09:26 PM
Least vibration would point you to a well configured pier.
By that, i mean a pier with adequate diameter (in this case i would suggest 1' dia), and a good strong, deep, wide base.
The fact that you are considering a pier, suggests that this is going to be a "fixed" location.
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Re: Tri-pod or pier new [Re: dmdouglass]
      #5609487 - 01/06/13 11:48 PM
If you will be moving it around at all, look for a Meade Giant Field tripod. Weighs about 50 lb, has 4" legs, and is *really* solid. I used my 14" on a Superwedge on this tripod for a couple of years. Next best thing to a pier!
But if you have a permanent place, do a 12" concrete pier.
JR#8
Reged: 08/31/04
Loc: Edison, NJ
Re: Tri-pod or pier new [Re: Rick Woods]
      #5610747 - 01/07/13 07:07 PM
i forgot to say i would like it to be portable
Rick Woods
Reged: 01/27/05
      #5610835 - 01/07/13 08:07 PM
Then I *really* advise the big Meade tripod. (Not the one that comes standard with the 10" SCT!) A heavy-duty, precision wedge is a good idea, too. Don't get a Superwedge; they work great, as long as you don't have to adjust them; but Mitty or Milburn make state of the art, fine-adjustable wedges.
I've never tried a portable pier; but it seems like it wouldn't be as stable as a tripod. And with a tripod, you can also use a scope buggy!
And don't forget the vibration suppression pads for the tripod legs. Those even worked on my 14" w/wedge and all - right about 250lb of weight, and I could still tell the difference with the pads! (That much weight ended up mushing them down pretty good, though.)
JR#8
Reged: 08/31/04
Loc: Edison, NJ
Re: Tri-pod or pier [Re: Rick Woods]
      #5610845 - 01/07/13 08:17 PM
thanks for the info That makes alot of sence
5 registered and 3 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
