bouffetout
Reged: 11/21/12
Loc: Canada
Dark frames temperature ?
#5611489 - 01/08/13 08:22 AM
I would like to start a dark frame library but don't know few things ... If I take darks at -10 Celcius ,How much degree higher and lower ,+/- ,can I use those ??? Is a master dark as good as putting all the darks in DSS ??? Can I make my darks during cloudy nights using only the camera and cap on ,or do I have to fit it to the scope ??? Thank you all for answering ! Maxx
guyroch
Vendor (BackyardEOS)
Reged: 01/22/08
Loc: 3rd rock from the sun, Canada
Re: Dark frames temperature ?
[Re: bouffetout]
#5611589 - 01/08/13 09:38 AM
You typically can match darks +/- 3c.
You can (and you should) take darks during cloudy nights. The camera cap is all you need.
You don't have to fit your camera back on the scope. A dark is just that, a picture with no light photons reaching the sensor so lens/scope does not matter. But duration and ISO do matter so make sure you match those to your light images.
Hope this helps,
Guylain
bouffetout
Reged: 11/21/12
Loc: Canada
[Re: guyroch]
#5611601 - 01/08/13 09:46 AM
Merci Guilain !
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
[Re: bouffetout]
#5611869 - 01/08/13 12:32 PM
I'd just be careful not to lay the camera on its back while taking darks. I have no data to prove this, but I'd be a little concerned that changing the heat losses through the back of the camera could have an effect on the sensor temperature. +/-3C is good up to about 25-30C (sensor temperature), between 30C and 40C +/-2C is better, and above 40C (yes I've imaged with a sensor temperature above 40C) the temperature needs to be pretty well matched.
bouffetout
Reged: 11/21/12
Loc: Canada
[Re: jgraham]
#5611885 - 01/08/13 12:42 PM
Dude! imaging at 40 Celcius...40 C at night ? during the day it must have been terribly hot ! You have a good point there ,when I image ,my camera's back touches nothing and temperature exits differently depending the angle of the camera. Thank you for helping me ! Maxx
Magellan
Reged: 01/26/06
Loc: Enfield, NS Canada
[Re: bouffetout]
#5611975 - 01/08/13 01:41 PM
I have been using Darks taken in August for images shot in January. I take Dark Flats and Bias frames at light temps, seems to work for me. What does a more seasoned APer feel about this thought?
jrcrilly
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
[Re: Magellan]
#5611999 - 01/08/13 01:56 PM
Looking at the noise v. temp charts for the chips, there's a difference at even 1 degree C. A degree or two probably isn't too bad, though - and I know that with an unregulated camera that much error is inevitable even within a given session. You can check - take two darks at different temperatures and subtract the cooler one from the other. What remains is the noise that the warmer dark won't correct at the lower temp because of that much temp error. Reliable darks is just one more reason for selecting a dedicated astro camera.
Magellan
Reged: 01/26/06
[Re: jrcrilly]
#5612002 - 01/08/13 01:59 PM
Interesting thought. Maybe I should start taking darks after my lights, a bit of a pain but at least I am using a dedicated modified 450D.
jrcrilly
Reged: 04/30/03
Loc: NE Ohio
[Re: Magellan]
#5612035 - 01/08/13 02:16 PM
When I used a DSLR I relied more on handling the noise during combination. If you dither the frames via the autoguider, the noise will move around relative to objects in the image and a median combine will deal with whatever the darks miss.
guyroch
Reged: 01/22/08
[Re: Magellan]
#5612077 - 01/08/13 02:34 PM
That is fine for most, but consider adding a few new darks and retiring a few older darks from your library every now and then. This will keep you library up to date with your camera sensor changing over time.
Just my 2 cents.
Guylain
bouffetout
Reged: 11/21/12
Loc: Canada
[Re: Magellan]
#5612120 - 01/08/13 02:59 PM
Because it was a cold August and a hot January ???
Beautiful pictures you have on Flickr.
Maxx
Edited by bouffetout (01/08/13 03:03 PM)
bouffetout
Reged: 11/21/12
Loc: Canada
[Re: guyroch]
#5612137 - 01/08/13 03:10 PM
I thought that dark frames lasted for the time I used the same camera...How long can I use a master dark then ?
bouffetout
Reged: 11/21/12
Loc: Canada
[Re: jrcrilly]
#5612145 - 01/08/13 03:14 PM
Thank you for answering ,but you kind of lost me there ! Maxx
guyroch
Reged: 01/22/08
[Re: bouffetout]
#5612152 - 01/08/13 03:19 PM
A camera sensor will deteriorate over time, new dead pixels will show up, etc...
Adding new dark frames to your library and removing older ones will ensure your library is up to date with your sensor.
Guylain
John Wunderlin
Reged: 10/01/04
Loc: Mineral Point, Wi
[Re: bouffetout]
#5612155 - 01/08/13 03:20 PM
I've heard it suggested you replace them every 6 months, but I've never seen anyone back that up with an actual study. One thing I wanted to mention is that it's a good idea to use a pause between frames to let the DSLR's chip cool between shots. When I was using a DSLR I discovered that the chip heats up significantly if you take many exposures in a row which effectively changes the temperature you are targeting. I can't remember if this happened with my 350 or 450, but I'll bet a lot of cameras will have this issue.
bouffetout
Reged: 11/21/12
Loc: Canada
[Re: guyroch]
#5612164 - 01/08/13 03:24 PM
Thanks again dude !
Magellan
Reged: 01/26/06
[Re: guyroch]
#5612173 - 01/08/13 03:30 PM
thank you for the Flickr comment I am thinking about doing a new set of darks anyway with dark cloudy skies coming, thats the best time me thinks. I can't dither with the Nextguide wish I could.
bouffetout
Reged: 11/21/12
Loc: Canada
[Re: John Wunderlin]
#5612181 - 01/08/13 03:31 PM
Thank you John ! How long do you suggest the pause ? I do 5 seconds pause ,is it enough ? Maxx Beautiful astropics in your gallery...WOW !!!
John Wunderlin
Reged: 10/01/04
[Re: bouffetout]
#5612202 - 01/08/13 03:46 PM
My educated guess is that 5 seconds would be enough, but I'm afraid I didn't test- shortly after I discovered this issue, I bought my ST8300 and rarely do DSLR imaging any longer. I'm sure 5 seconds would be much better than none.
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
#5612326 - 01/08/13 05:06 PM
Heh, heh, that's 40C sensor temperature, not ambient air temperature.
I've been using uncooled cameras for the past 9 years and handling the darks is always a mixed bag. My CCD does automatic dark matching in real-time which is nice, but even there I update the libraries at least once a year. On the DLSR side I switched to using the internal dark subtraction. I used it last night with 600 second subs and my source images looked great! I haven't taken a stand alone dark frame with my DSLR in over a year. If you want to see something interesting look at the sensor temperature as a function of time as you take your darks. Also, look at each individual frame. As time goes on the sensor keeps getting warmer and the darks noisier.
Fun stuff.
