tag1260
Reged: 10/07/12
Loc: Ohio, USA
What IS a Planetary eyepiece?
#5611902 - 01/08/13 12:53 PM
What make an eyepiece a so called Planetary? Is it the size, the design, or what? Is a 5mm TMB Planetary just a 5mm eyepiece with a gimmicky name or is there something special that make it a planetary. Inquiring minds need to know!!!
dpwoos
Reged: 10/18/06
Re: What IS a Planetary eyepiece?
[Re: tag1260]
#5611914 - 01/08/13 01:07 PM
What makes a "sports" car?
keroppilee
Reged: 09/14/12
[Re: dpwoos]
#5612052 - 01/08/13 02:21 PM
the only factor i can think of that ISNT up for personal preference (FOV and such) would be fairly high magnification.
dpwoos
Reged: 10/18/06
[Re: keroppilee]
#5612072 - 01/08/13 02:31 PM
Even magnification depends on the focal length of the scope.
Jim Rosenstock
Reged: 07/14/05
Loc: MD, south of the DC Nebula
[Re: tag1260]
#5612098 - 01/08/13 02:46 PM
Heck, we don't even know what a Planet is, anymore.
I had a great planetary eyepiece, but I made the mistake of looking at Pluto with it.
Now it's just a "minor eyepiece"....
Dave Ittner
Reged: 05/29/12
Loc: SF Bay Area, California
[Re: Jim Rosenstock]
#5612101 - 01/08/13 02:48 PM
+1
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
[Re: tag1260]
#5612107 - 01/08/13 02:50 PM
It is just an eyepiece that yields the higher power needed to view detail on the moon and planets. Some people require it to be limited in design complexity (as few elements as feasible) and high in coating quality to reduce the amount of scattered light in the field, but other people use "planetary" eyepieces that have many elements. Many so-called "planetary" eyepieces have focal lengths smaller than around 15mm, but in a very long focal length telescope, this may not be true. The same goes for apparent field of view, as some people who call an eyepiece a "Planetary" eyepiece often feel their fields of view are less than around 60 degrees. Again, this isn't universally so. One of my favorite eyepieces for planetary viewing is my 8-element 5-8mm Speers Waler variable focal length eyepiece with a whopping 78 degree apparent field of view. It violates both ideas of limiting the number of elements and limiting the field of view. In the end, whatever eyepiece you like to use to get the powers you need for viewing the planets will be a "planetary" eyepiece for you. Clear skies to you.
tag1260
Reged: 10/07/12
Loc: Ohio, USA
[Re: Dave Ittner]
#5612113 - 01/08/13 02:54 PM
OK. Sounds like it's just a marketing hype when you use the term "Planetary Eyepiece". As was stated it could be anything in your arsenal.
Tank
Reged: 07/27/09
Loc: Stoney Creek, Ontario, CANADA
[Re: David Knisely]
#5612115 - 01/08/13 02:55 PM
Best in these areas: light transmission scatter control Contrast
Main due to: minimal glass elements coatings polish
BillP
Reged: 11/26/06
Loc: Vienna, VA
[Re: tag1260]
#5612116 - 01/08/13 02:57 PM
A "planetary" eyepiece is one that is optimized for the task of planetary observing - simple as that. Classically, this has been considered to be an eyepiece that shows the least distortion to the image (hence the Abbe design becoming popular for this as it has an "orthoscopic" field of view), and an eyepiece which best preserves image brightness and contrast (hence why minimum amount of glass is usually noted as less glass means brighter and higher contrast since less optical elements and surfaces to scatter and absorb light).
So those are IMO the classical views of planetary eyepieces. Today however, with technology marching on, this is getting challenged. With latest multicoating technologies element count "can be" increased and still retain outstanding transmission and contrast. More elements also means wider AFOVs and better eye relief also, which can be benefitial traits for a planetary eyepiece. So today there are some challengers to the classic planetary such as the Pentax XW series, Leica Vario ASPH Zoom, and the TV Ethos for many.
In the end, IMO, the general characteristics of a "planetary" eyepiece would be:
1. Maximum Transmission possible compared to other eyepieces (i.e., best coatings and least glass)
2. Maximum Contrast compared to other eyepieces (i.e., best polish for least scatter, best application of the coatings for least scatter, elimination of all stray light within the eyepiece for least scatter)
3. Lack of Visible Distortions (or greatly minimized) compared to other eyepieces (i.e., an orthoscopic field of view and so the view stays as true to what the telescope is producing; no/little visible AMD and RD so planets stay round and linear features do not bend when near field stop)
4. Neutral Tonal Quality compared to other eyepieces (i.e., does not impart a hue or coloration to the view in any way so the view stays as true to what the telescope is producing)
------Nice to Haves------
5. Longer eye relief for more comfortable extended viewing
6. Larger AFOV for longer drift times in non-tracking scope mounts
Note - while there may be planetary eyepieces here and there, most all eyepiece lines I do not consider planetary because they do not offer focal lengths that are very close together. TMB Supermonos are an exception with focal lengths in 1mm increments from 4mm to 10mm. But in reality, when considering both fast APOs and slow SCTs, really need 1mm increments from 3mm to 14mm IMO to be considered a planetary "line"...or a zoom with this range.
Edited by BillP (01/08/13 05:03 PM)
Monoeil
Reged: 08/01/11
#5612132 - 01/08/13 03:06 PM
You are lucky. My planetary eyepieces show me planets ONLY, unless it is because of the light pollution... I am not sure. Maybe I should buy some deep sky eyepieces?
tag1260
Reged: 10/07/12
Loc: Ohio, USA
[Re: Monoeil]
#5612149 - 01/08/13 03:16 PM
Well, you all knew this was leading up to another question. What is a good planetary to consider under $100 ? I already have a 12mm Paradigm and I have an 8mm on it's way. I use a 12" f/5 dob scope which I'm sure will make a difference. I have enough money left in my eyepiece fund for one more.
JohnMurphyRN
Reged: 09/09/12
Loc: Near St Louis
[Re: tag1260]
#5612185 - 01/08/13 03:34 PM
ES82 6.7mm or just maybe 4.7mm
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
[Re: tag1260]
#5612191 - 01/08/13 03:38 PM
Well, the Paradigm should be OK.
What is a planetary eyepiece? Any eyepiece you use to look at planets with. A non-planetary eyepiece can become one with a Barlow lens to up the magnification. Your 12mm becomes a shorter focal length when used with a Barlow.
The sad truth is that the difference between the very best and only average eyepiece is of a considerably smaller scale than the difference in seeing from night to night and even hour to hour. My lifetime-best view of Jupiter was with 18 elements in the focuser (!) at 456X. But seeing was essentially perfect in every way. Even my 12.5" was "aperture-limited" at that time. It's a shame there was no really big scope nearby on that night.
What you need, when the seeing is like that is: --sufficient aperture --high magnification --a cooled and collimated scope. --a decent eyepiece and scope.
That's about it.
dpwoos
Reged: 10/18/06
[Re: David Knisely]
#5612201 - 01/08/13 03:45 PM
Not being an eyepiece "collector" I don't covet a lot of eyepieces. However, the SW 5-8 variable is one I would love to try! These are hard to come by, and I have never even seen one. Enjoy it!
BillP
Reged: 11/26/06
Loc: Vienna, VA
[Re: Starman1]
#5612330 - 01/08/13 05:08 PM
This is very true! However, I do not consider it a sad truth but a wonderful truth to be capitalized on because it means with the proper "planetary" eyepiece I can see a planet both a little better and a little more
To give an example of the other side of the scale...my all time best view of Mars was with a singlet sphere lens...one element contrast rocks
btw, isn't it cool when the views become aperture-limited instead of atmosphere-limited! I had an evening a few years ago where I ran out of eyepieces and multiply stacked Barlows as the view just stayed crystal clear no matter what insane magnification I was using. It was 3am and I was looking at my scopes (had a 5" and a 10" out) wondering how they were doing what they were doing. Moments like these makes one understand just how much we are limited by the atmosphere.
Edited by BillP (01/08/13 05:12 PM)
Starman1
Reged: 06/24/03
Loc: Los Angeles
[Re: BillP]
#5612436 - 01/08/13 06:15 PM
2003 apparition of Mars. 5" Maksutov, 1540mm focal length, 4.7mm Meade Series 4000 UWA eyepiece, magnification 328X. NO scintilation of the image at all for 29 out of 30 seconds and so much detail visible in albedo features I decided to try something I'm not good at--sketching. I made a map showing everything I could see and, using a good map later, identified about 50 named features on the planet. I really got to see what "aperture-limited" really meant.
October, 1987, Saturn high in the sky, 7" f/12 AstroPhysics refractor, Parks 3.8mm eyepiece in 2X Barlow, 1123X (!). We saw spokes hovering above the grooved rings, many belts and storms on the disk, Cassini's division all the way around, the Encke Minima, and, every now and then, a glimpse of the Encke Gap at the ends of the oval. Seeing contrast variations within the rings was unexpected, and the image is burned into my brain. Again, no scintillation of the image at all, and aperture-limited.
Eyepieces used? Garden-variety, whatever-was-available types. Images seen? Stupendipity!
SteveTheSwede
Reged: 09/28/09
Loc: Stockholm, Sweden
#5612487 - 01/08/13 06:42 PM
I know this was a joke, but I can't help pointing out that it's the exact other way around. Prior to when Pluto lost its status as a planet there existed no official definition of a planet at all. Since then there is one, so it's truer to say finally we know what a planet is
Steve
csrlice12
Reged: 05/22/12
Loc: Denver, CO
[Re: SteveTheSwede]
#5612503 - 01/08/13 06:50 PM
No definition created by man has withstood the passage of time.......
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
[Re: csrlice12]
#5612569 - 01/08/13 07:26 PM
Someone once asked me if his guitar was a "jazz guitar". I said it was if he played jazz on it. Same principle here.
