Paul G
Reged: 05/08/03
Loc: Freedonia
Re: What IS a Planetary eyepiece? new [Re: Rick Woods]
      #5612607 - 01/08/13 07:52 PM
Someone once asked me if his guitar was a "jazz guitar". I said it was if he played jazz on it.
Same principle here.
+1
Paul G
Reged: 05/08/03
Loc: Freedonia
Re: What IS a Planetary eyepiece? new [Re: Tank]
      #5612616 - 01/08/13 07:55 PM
Best in these areas:
light transmission
scatter control
Contrast
Main due to:
minimal glass elements
coatings
polish
Planets are usually so bright that light transmission isn't really important. 10% either way shouldn't make any difference. Scatter control and its effect on contrast is most important IMO.
Edited by Paul G (01/08/13 07:56 PM)
ibase
Vendor Affiliate
Reged: 03/20/08
Loc: Manila, Philippines 121*E 14*N
      #5612622 - 01/08/13 08:00 PM
Viewing a planet entails a lot of EP time to glimpse those otherwise unseen surface details which are visible in those fleeting moments of atmospheric stability. If one is not viewing comfortably, then the tendency is to call the night earlier than what would have been a longer run if the EP used was a high-comfort one (i.e., with good eye relief). Retiring earlier means missing out on those prized minute planetary details altogether even if one were using the uber-premium "planetary" EP. If scope used does not track, a wider AFoV EP is a plus (at least 70-deg AFoV where "widefield" starts). Couple that with good power and great transmission & contrast for a clear crisp image and sharp to the edge view that stays longer to observe before nudging, and you've got the ideal "planetary eyepiece." Among the EP's that I own & use frequently for this purpose, Televue's Delos 6mm fits the bill - generous eye relief (20mm), wide AFoV (72-deg), good power to pull in details, and great crisp images up to the edge of view. Just my 2 cents.
Best,
Tank
Reged: 07/27/09
Loc: Stoney Creek, Ontario, CANADA
Re: What IS a Planetary eyepiece? new [Re: dpwoos]
      #5612623 - 01/08/13 08:02 PM Attachment (12 downloads)
One of my favorite eyepieces for planetary viewing is my 8-element 5-8mm Speers Waler variable focal length eyepiece with a whopping 78 degree apparent field of view.
Not being an eyepiece "collector" I don't covet a lot of eyepieces. However, the SW 5-8 variable is one I would love to try! These are hard to come by, and I have never even seen one. Enjoy it!
Its a very good planetary performer and a very great all round EP:
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
Re: What IS a Planetary eyepiece? [Re: ibase]
      #5612627 - 01/08/13 08:04 PM
For actual viewing of planets I prefer binoviewing, I can bino ortho and plossl pairs for hours with no strain at all. I see more detail with two eyes and floaters are virtually eliminated.
tag1260
Reged: 10/07/12
Loc: Ohio, USA
Re: What IS a Planetary eyepiece? new [Re: johnnyha]
      #5613059 - 01/09/13 01:33 AM
Thanks for all the opinions and info. Looks like I'll be sitting tight where I am for a short time. I was out tonight with my Paradigm 12mm and I have to say, Jupiter was the best I've ever seen her. I barlowed the 12mm with my Celestron Ultima and I am impressed. If you would see where I view from when I can't get to a dark site you would understand. I've often thought a pellet gun might be my next viewing accessory, if you know what I mean. With the 8mm on the way I should be all set for a while.
Kutno
Reged: 08/17/09
Re: What IS a Planetary eyepiece? new [Re: Paul G]
      #5613075 - 01/09/13 01:59 AM
cjc
Reged: 10/15/10
Loc: Derbyshire, England
Re: What IS a Planetary eyepiece? new [Re: BillP]
      #5613100 - 01/09/13 03:07 AM
I would emphasise Bill's point 2. in his list of characteristics for a planetary eyepiece. I find that some otherwise satisfactory eyepieces will produce strong distracting ghost images when viewing planets, ruining my concentration and removing some of the enjoyment. The TMB Planetary IIs are among those which are significantly affected.
I also dislike systems that flare up with something just out of view, though it is less of a hindrance to observing in practice. This is often an eyepiece issue, but it can also be caused by diffraction from the secondary spider in a Newtonian.
george tatsis
Reged: 11/20/08
Loc: Flushing, NY - Europe
Re: What IS a Planetary eyepiece? new [Re: cjc]
      #5613201 - 01/09/13 06:58 AM
Just for the record, last night I used the Agena SWA 15mm and 20mm with two inexpensive barlows (3X Meade #128, and 2X GSO ). The telescope used was a 120ED refractor. The combination of the 15mm +3X Barlow was as good as the Nagler Zoom at 5mm and the BGO 5mm ortho. Jupiter was equally good and contrasty in all of the above oculars.Go figure!
George
BillP
Reged: 11/26/06
Loc: Vienna, VA
      #5613436 - 01/09/13 10:09 AM
light transmission
scatter control
Contrast
Main due to:
coatings
polish
This is aperture dependent. So transmission is critical for smaller aperture scopes since they will be at small exit pupils when at productuve planetary magnifications (which IMO includes ALL typical APOs). 10" and larger scopes and "typically" not so much of an issue...unless hunting a particularly faint planetary feature. Planets, like double stars, have many "challenge" features so they really are a playground of observing challenges.
Edited by BillP (01/09/13 10:10 AM)
t.r.
Reged: 02/14/08
Loc: Upstate NY
      #5613473 - 01/09/13 10:39 AM
Moments like these makes one understand just how much we are limited by the atmosphere.
Along with Bill and Don, I have a "never forget it observation" illustrating well the planetary eyepiece debate...South Korea, fall of 1995, Seoul is famous for its smog, meaning stable seeing. On one particular night, I had the 4 inch Genesis loaded up with the TV 2.5x barlow and Nagler 4.8mm eyepiece producing 260x! I could have used more! The view I had of Jupiter and Ganymede transiting the face was a revelation! Throwing all the rules out the window about magnification per inch, exit pupil and number of elements in the optical train, I just sat back and enjoyed the most stable, clean view of Jove while seeing color, minute detail and even suspected albedo on Ganymede! It looked like a marble in 3-D transiting. Yep...I've said it before, location, location, location = seeing conditions that deliver those finer planetary details...the eyepiece is the smaller factor in the equation.
CJK
Reged: 12/05/12
Loc: Northeast TN
Re: What IS a Planetary eyepiece? new [Re: Jim Rosenstock]
      #5613478 - 01/09/13 10:43 AM
Heck, we don't even know what a Planet is, anymore.
I had a great planetary eyepiece, but I made the mistake of looking at Pluto with it.
Now it's just a "minor eyepiece"....
-- Chris
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
      #5613523 - 01/09/13 11:19 AM
Yeah, they made a mistake with that classification.
Only the old guys like us would have been disturbed by calling Sedna, Varuna, Haumea, Quaoar, MakeMake, Eris, Orcus, Ixion, and Pluto the "Ice Planets". Of course, that list is now over 1200 objects long (and growing) and it's not known how many of them are large enough to be gravitationally compressed into a "roundish shape". I note that recently they've divided the group into Plutinos, Cubewanos, and a 3rd category not fitting the orbital standards of the first groups.
Jupiter, Saturn, Uranus, and Neptune could have been the "Gas Planets".
And Mercury, Venus, Earth, Mars, and Ceres the "Rocky Planets"
You know, in retrospect, it was right to demote Pluto into just a large Trans-Neptunian Object. Otherwise, we could end up with a list of planets over a thousand long.
Mike W
Reged: 04/30/06
Loc: Upstate NY
Re: What IS a Planetary eyepiece? new [Re: tag1260]
      #5613564 - 01/09/13 11:44 AM
Televue Plossls are good, inexpensive planetary eyepieces.
Mike W
Reged: 04/30/06
Loc: Upstate NY
      #5613572 - 01/09/13 11:48 AM
And nice and compact too!
dpwoos
Reged: 10/18/06
Loc: United States
Re: What IS a Planetary eyepiece? new [Re: Mike W]
      #5613598 - 01/09/13 12:01 PM
For sure it is not for every scope! In my case, my 10" is fairly massive which, btw, is exactly how I like it. I do a lot of public observing and so a bit of mass is really helpful in allowing folks to observe/focus without the scope moving. So, it can handle massive/long eyepieces, and I can swap them without worrying too much about losing the target. Maybe when I am old I will appreciate lightweight more, but not so much now.
Edited by dpwoos (01/09/13 12:03 PM)
BillP
Reged: 11/26/06
Loc: Vienna, VA
Re: What IS a Planetary eyepiece? new [Re: t.r.]
      #5613772 - 01/09/13 01:53 PM
Or perhaps, for the three of us, we were just viewing from...the Twilight Zone!
Edited by BillP (01/09/13 02:02 PM)
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
      #5613807 - 01/09/13 02:17 PM
An eyepiece used for observing planetaries?
There's the Ring, Dumbbell, Helix, Little Dumbbell, Eskimo (Clown for the politically correct), etc.
What's most confusing is Saturn, which is a planetary and a planet.
punk35
Reged: 01/26/05
Loc: lower michigan
      #5613931 - 01/09/13 03:29 PM
It's cause your collimation looked like that
MRNUTTY
Reged: 11/22/11
Loc: Mendon, MA
Re: What IS a Planetary eyepiece? new [Re: punk35]
      #5614457 - 01/09/13 08:23 PM
Thought that was time tunnel for a minute! Loved those old shows...
10 registered and 16 anonymous users are browsing this forum.
