jhirsch
Reged: 10/06/10
Loc: Ohio
Re: Show off your NexStar
[Re: jturie]
#5605857 - 01/05/13 12:45 AM
Jack I absolutely love my Telrad. The biggest reason I have it on the 6se though is the fact that I bought the 6se used and the RDF didn't work. Even replaced the battery and still no luck. I had the Telrad from my previous set up so I thought what the heck. Gave it a try and... needless to say it ain't comin off anytime soon. It is about as long as the OTA but my boys think it looks cool...
bindibadgi
Reged: 04/15/07
Loc: Canberra, Australia
[Re: jhirsch]
#5605990 - 01/05/13 03:52 AM
Brand new!
102SLT 13" dovetail Rings (for the dovetail) Electronic focuser 2" dielectric diagonal 8x50 RA finder (not new) Hyperion 8-24 EP (not new)
I tried to give you some idea of the weather it caused. It has been crystal clear for ages now, but today it was 104 deg F (40 Celcius) and the storms have rolled in. I should apply for a grant from the government to buy scopes and put an end to the drought!
I swear, they predicted for no rain at all!!
spiphoto
Reged: 12/05/12
Loc: Michigan
[Re: bindibadgi]
#5608148 - 01/06/13 11:35 AM
Fantastic!! Do you try photography with this?
usfpaul82
Reged: 12/13/12
Loc: Lakeland, Fl
[Re: spiphoto]
#5611888 - 01/08/13 12:42 PM
Hey guys. I finally got a few pics of my setup. I have had her for about a month now and am absolutely hooked!
WO 2" Diagonal, JMI motofocus, I am looking into possibly upgrading my finder, but I actually like the red dot. Seems like it would be a little more difficult to point the scope at a alignment star with a RACI, i could be wrong though. I will also be putting in an order for the wing thing bracket for the handcontrol. Thanks for looking!
spiphoto
Reged: 12/05/12
Loc: Michigan
[Re: usfpaul82]
#5611908 - 01/08/13 12:59 PM
Nice....did you find much difference with the WO diagonal? I have been toying with the idea of the JMI focuser...what is your take on it. Nice scope....enjoy
usfpaul82
Reged: 12/13/12
Loc: Lakeland, Fl
[Re: spiphoto]
#5612034 - 01/08/13 02:16 PM
The reason why I went with a 2" diagonal is so I could use the wide angle 2" eyepieces. Honestly, I chose the WO because I liked the way it looked, I doubt there is much difference optically to some of the other diagonals out there. I really like the focuser, I used the scope a few nights when I first got it without it and felt the shakiness annoying but manageable, the focuser really helps with high power planetary viewing IMO.
Midnight Dan
Reged: 01/23/08
[Re: usfpaul82]
#5612121 - 01/08/13 02:59 PM
Nice looking rig! I got the WO 2" diagonal for the same reason. Love the way it looks!
Nothing wrong with the red dot finder if you don't find it uncomfortable. Most of us move to a RACI or GLP just because we don't like contorting our old backs into the position needed to look through it!
-Dan
usfpaul82
Reged: 12/13/12
Loc: Lakeland, Fl
[Re: Midnight Dan]
#5612148 - 01/08/13 03:16 PM
-Dan
but isn't it harder to get the scope in the right direction with a RACI? With the red dot, sure I have to bend down, but i can make a strait line with my vision to the star from the red dot. With the RACI, you are not looking straight up at the sky, is it harder to get to where you want to be?
Midnight Dan
Reged: 01/23/08
[Re: usfpaul82]
#5612183 - 01/08/13 03:32 PM
If you're using it for starhopping, then a straight through finder, or a unity finder like a red dot or Telrad works best. But I find that with the 8SE, I only use the finder briefly during alignment. And even for that, the scope gets me in the vicinity so I really don't have to move very far. For that kind of use, it doesn't seem like a problem to not be looking at the sky.
What I DO find is a bit of a problem is the magnification of my 9x50 finder. To line it up, even initially, with a star like Polaris, I have to sight along the outside of the barrel to get it close enough to see the star in the magnified view. If I just had the RACI alone, I'd probably opt for a lower mag finder like a 6x30 because it shows a wider view. But I use both a GLP and a RACI. The GLP gets me close really quickly, and the 9x50 zeroes it in. An neither one requires that I get in an awkward position.
-Dan
donnie3
Reged: 12/15/04
Loc: bartlesville oklahoma
[Re: Midnight Dan]
#5613006 - 01/09/13 12:39 AM
red dot, red dot, red dot!!!!!! i have a bunch of finder scopes in a box collecting dust. if you wont to upgrade buy orions ez finder deluxe reflex sight, its built like a tank and has 7 different brightness levels and different patterns. on sale for $ 55.99. donnie
Arthur Dent
Galactic Hitch-Hiker
Reged: 10/23/08
Loc: South Yorkshire, UK
[Re: donnie3]
#5613170 - 01/09/13 06:00 AM
That finder is what I refer to as a Multi-reticle finder (MRF).
and here it is om my scope:
Mine didn't cost me £79.95 either (as a UK based supplier is charging).
Art
usfpaul82
Reged: 12/13/12
Loc: Lakeland, Fl
[Re: Arthur Dent]
#5613260 - 01/09/13 08:14 AM
Last question on this since I don't want to derail this thread to much, but is that multi reticle finder a direct fit with the 8se? Meaning I can use existing screws, or are you guys using double sided tape?
Arthur Dent
Reged: 10/23/08
[Re: usfpaul82]
#5613351 - 01/09/13 09:15 AM
Nope, I didn't want to trust double-sided tape to hold the finder's shoe in place.
I removed the rear cell - documented here, drilling and then tapping holes in the aluminium casting of the rear cell.
The shoe for the multi-reticle finder should fit in place of the standard RDF as it only has a single machine screw (as can be seen in post #2982975 of the above thread), but I was also fitting a 9x50 RACI finder which you can see on the right-hand side of the rear cell behind the orange OTA and the slots for the screws wouldn't mate up with Celestron's existing holes in the rear cell.
Art
Smittty692k4
Reged: 07/05/11
Loc: East Bernard, TX
[Re: Arthur Dent]
#5616002 - 01/10/13 06:23 PM
That ES24 really completes that package. I wish I woulda bought one when they were on sale.
DawieZA
Reged: 12/30/12
Loc: Johannesburg, South Africa
[Re: Smittty692k4]
#5634339 - 01/21/13 04:21 AM
Here is my stock 6SE. Summer rains are in full swing so I am waiting for clear skies for its first light.
spiphoto
Reged: 12/05/12
Loc: Michigan
[Re: DawieZA]
#5635197 - 01/21/13 03:22 PM
Yep...thats a nice scope for sure. What the heck is rain...its -10 windchill here.....
bcuddihee
Reged: 11/04/06
Loc: Cincinnati Ohio
[Re: Starlighter]
#5656774 - 02/01/13 05:04 PM Attachment (45 downloads)
Latest iteration with an Antares 80mm finder added. Surprisingly still tracks fine.
bcuddihee
Reged: 11/04/06
[Re: bcuddihee]
#5656778 - 02/01/13 05:05 PM
another view
bcuddihee
Reged: 11/04/06
[Re: bcuddihee]
#5656779 - 02/01/13 05:06 PM Attachment (47 downloads)
spiphoto
Reged: 12/05/12
Loc: Michigan
[Re: bcuddihee]
#5656958 - 02/01/13 06:55 PM
Really nice. What is your diagonal? Tell what you use the 2 refractors for.
