Pages: << 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 30 | 31 | >> (show all)
186vett
Reged: 01/29/13
Re: Celestron VX mount [Re: GTBaker]
      #5676847 - 02/13/13 12:01 AM
Sir;
From whom did you order from? Just curious.
Jerry
jfrech14
Reged: 01/17/12
Loc: Virginia, USA
Re: Celestron VX mount [Re: powerstroke01]
      #5678092 - 02/13/13 05:58 PM
You really think that the two saddle screws are not enough? I will have 25 lbs on that bad boy with 22 lbs of counterbalance. I dont want the screws to slip and drop my scopes. Of course an ADM saddle will be better but will the celestron saddle suffice?
GTBaker
Reged: 02/01/13
Re: Celestron VX mount [Re: 186vett]
      #5678384 - 02/13/13 09:25 PM
I ordered it from a local shop here in town. I'm in Newfoundland, Canada. It's an authorized Celestron re-seller. I also got an email saying I'll have it in 2 weeks instead of waiting till April.
I was going to get it through Canadian Telescopes but they're not a authorized Celestron re-seller.
cn register 5
Reged: 12/26/12
Re: Celestron VX mount [Re: jfrech14]
      #5678736 - 02/14/13 02:59 AM
I think it will be fine. I've got a dual mount with two scopes and two CCD cameras that comes to about 18 lbs and it's not budged.
If you are concerned fit stop screws to the dovetail bar, then the scope can't slide right off the end.
Chris
morecoffee
Reged: 02/06/13
Loc: USA
Re: Celestron VX mount [Re: cn register 5]
      #5679295 - 02/14/13 11:57 AM
I wonder if the 11 inch SCT now offered on the VX with one CCD would be pushing it's limits with counter weights.
dr.who
Reged: 01/05/12
Re: Celestron VX mount [Re: morecoffee]
      #5679374 - 02/14/13 12:37 PM
Not for visual but for AP it would not be something I would want to try.
chasdz
Reged: 01/04/13
Re: Celestron VX mount [Re: dr.who]
      #5679550 - 02/14/13 01:54 PM
For what's it's worth Astronomics has the VX in stock today a shipment arrived last night 2/13.
MDearingJaxFL
Astronomicus
Reged: 08/28/04
Loc: Florida
Re: Celestron VX mount [Re: chasdz]
      #5679558 - 02/14/13 01:58 PM
Does anyone think that the vx could handle for AP the Astrotech AT8in F/4 astrograph with 50mm guider on it? About 22 lbs maybe......
:>) mark
R L Harris
Reged: 01/31/13
Loc: Tecumseh, OK
Re: Celestron VX mount [Re: MDearingJaxFL]
      #5679580 - 02/14/13 02:09 PM
you will be several pounds over 50-60% point for ap on this
setup!
Edited by R L Harris (02/14/13 02:14 PM)
jfrech14
Reged: 01/17/12
Loc: Virginia, USA
Re: Celestron VX mount [Re: R L Harris]
      #5679713 - 02/14/13 03:11 PM
I will be at 25.2 lbs and I have been told that since I am using 22lbs counterbalancing and im mostly in an observatory this new mount has enough torque to handle it (told by astronomics, opt and celestron) so I think 22 lbs will handle it UNLESS you have a long tube.. my longest tube is 19.6 inches which is really short so i have less of a moment arm causing less torque exertion
jfrech14
Reged: 01/17/12
Loc: Virginia, USA
      #5679717 - 02/14/13 03:13 PM
PS I ordered from highpoint scientific. free shipping plus I got 5% off which was enough to get the ac adapter and still save 20 bucks... it got to my doorstep in 3 days
Carl N
Reged: 03/18/12
Loc: San Diego, CA
Re: Celestron VX mount [Re: rmollise]
      #5679782 - 02/14/13 03:51 PM
Got mine yesterday. I ordered it from Celestron, OPT was out after I drove there to pick up when they said. It was in stock. celestron consigned it to Hands on Optics. Interesting, since I mounted a 102 AstroTelescopes f/11 from Hands on upon it. I received it in 4 days.
On setup, the only issues I have noticed are that the counterweight safety stop bolt at the end of the counter weight bar does not thread easily. Some burring in the female threads of the counter weight bar which. Had to chase and oil the threads to not need a pliers to remove the darned thing.
The other issue I noticed was an indented dimple on at least one tripod leg tube from the set screw being turned a bit hard at the factory. Neither is a big deal, but a bit disappointing.
Full disclosure, this is my first go to mount. I have a 10" dob.
I was able to do an alignment that got me finding things pretty much center of 9mm ES 100 every time with only a few "restarts". I am confident anyone familiar with the celestron menus and alignment process will have no issues.
The mount doesn't seem too noisy, even at fastest slew. At slowest it is virtually silent.
My total weight on it is around 15 pounds and it is rock solid. I plan to eventually put an 11" on it and I can't see it being an issue, particularly since when I do, the mount will be on a permanent pier. Once I am used to the mount and its menus, I will be trying AP with my Nikon D7000 on it.
Carl
Edited by Carl N (02/14/13 03:55 PM)
Carl N
Reged: 03/18/12
Loc: San Diego, CA
Re: Celestron VX mount [Re: Carl N]
      #5679974 - 02/14/13 06:04 PM
Also, I couldn't get a clear answer. The power receptacle has a threaded collar. The cord which has a cig lighter on the end that comes with it has a threaded housing for it.
But the AC adapter that is recommended by celestron is the one that is not threaded. They have a threaded one, at a different volt rating for the CGEM.
Can I use the threaded AC adapter or will that voltage harm my electronics?
Whichwayisnorth
Reged: 07/04/11
Loc: Southern California
      #5679977 - 02/14/13 06:07 PM
Different Volts or different Amps?
Should all be 12v and amps don't matter as long as they are over about 2.5 amps.
morecoffee
Reged: 02/06/13
Loc: USA
Re: Celestron VX mount [Re: Whichwayisnorth]
      #5680064 - 02/14/13 07:09 PM
Newfoundland, wow, never been, would love to see it some day. Keep us posted on when it arrives.
jfrech14,
How do you go about the 5% off I was poking around their site but could not find it. Thanks in advance.
Edited by morecoffee (02/14/13 07:14 PM)
jerwin
Reged: 05/17/12
Loc: Romeoville IL
      #5680424 - 02/14/13 11:30 PM
I too am wondering about this 5% discount at highpoint scientific. I got a 2% rewards program discount at optcorp. Better than nothing but not enough to really buy anything.
jacktechie
Reged: 03/20/08
Loc: SF Bay Area
      #5680496 - 02/15/13 12:39 AM
I bought a CGE Pro in January and it has the threaded collar. I found the 2.1mm power coaxial plug comes in a 12mm and 14mm length. The 12mm works on the CGE which has no threads as well as the 14mm. But the 12mm is too short on the Pro so there is no contact, but the 14mm works.
Do not use a power adapter that is rated lower than what equipment requires, otherwise you can burn out your adapter. Or in my case, I blew a 2.1 amp inline fuse, wired to my marine deep discharge battery, when I tried slewing the CGE Pro.
Jack
esthel
journeyman
Reged: 06/21/12
Re: Celestron VX mount [Re: jacktechie]
      #5682013 - 02/15/13 05:25 PM
Will Stellarium and EqMod work with the VX mount?
Reged: 07/06/07
Re: Celestron VX mount [Re: esthel]
      #5682034 - 02/15/13 05:34 PM
Yes and no. Stellarium will work. EQMOD is _for SynScan only_...but...NexRemote is similar to EQMOD...
esthel
journeyman
Reged: 06/21/12
      #5682068 - 02/15/13 05:55 PM
I would need to install NexRemote to have Stellarium and any software that requires EqMod. I would not be able to only run only EqMod?
21 registered and 39 anonymous users are browsing this forum.
