Can 87% humidity and 33F stop a CCD camera? #5613551 - 01/09/13 11:39 AM
Quote
My CCD camera stopped working just before I started to image on Sunday evening (Jan 6); the image of Jupiter froze on the screen after about two minutes the first time I tried and after only a few seconds upon subsequent reconnections :-(
I looked at the specs and saw that the maximum working relative humidity is 80% with a minumum working temp of 25 degrees F. The humidity was about 87% and the temp was 33 degrees F when all this happened. Has anyone ever experienced something similar? I'm debating whether to buy a new camera or wait for less challenging weather conditions. The camera is 17 months old and I've used it quite a bit.
Re: Can 87% humidity and 33F stop a CCD camera?
[Re: lcd1080]
#5613972 - 01/09/13 04:00 PM
Quote
Those conditions alone I don't think would hurt the camera. After being on a while it should be warm enough to fight off cold much more severe. Have you tried it indoors since that night? My first thought would be an intermittent cable problem.
[Re: DesertRat]
#5614232 - 01/09/13 06:28 PM
Quote
Echo Glenn on this Pete - even here in Oz I've worked at 20F a couple of times without any issues using the Flea3.....simple things - but is there power to the camera (is that pale green light at the back on?) and check all cabling as Glenn inferred.
The only problem I had with my Flea3 in close to 3 years was during my frst visit to Tennant Creek recently where it went ballistic and all the avi's had displaced top & bottom halves to Jupiter (a sort of bizarre "tearing") but it was only a temporary pecadillo which, when I tested the camera again the next day indoors had rectified itself.....course, I ain't used it much since then but I found the Flea3 to be a particularly reliable unit in general.
[Re: Kokatha man]
#5614401 - 01/09/13 07:54 PM
Quote
Glenn I did try the camera indoors both before I went out that night and just now. In both instances I maintained a good connection for an extended period of time using the same USB cable. The only other thing I can think of is that the USB hub I use to supply power to the camera from my laptop couldn't deliver enough power to both the camera and the other devices I had connected.
Darryl my camera doesn't have a light to indicate that it is receiving sufficient power. I've read about people successfully using CCD cameras down to 5 degrees F; I thought that perhaps the combination of low temperatures and very high humidity might have been a problem but now I'm thinking that the USB hub couldn't deliver sufficient power to operate both the camera and the other attached devices.
Paul once I get started I find it hard to stop regardless of how cold it gets so long as I retain manual dexterity. But you've got a good point!
[Re: lcd1080]
#5614545 - 01/09/13 09:33 PM
Quote
Good observation Pete. I've seen these hub problems with multiple devices myself. Finally I tossed the hub I had been using and got this: Metal 7-port USB2 Powered Hub
Others are probably just as good or better but this unit solved my problems fwiw.
