Thomas Karpf
Reged: 02/09/09
Loc: Newington, CT
Vixen Porta II head - 3/8" bolt?
      #5615246 - 01/10/13 10:57 AM
Will a Vixen Porta II head attach directly to a tripod with a 3/8" bolt? I already have a very solid tripod and don't really want/need another.
Thanks.
Agatha
Reged: 06/04/12
Loc: Coulee Region, Wisconsin
Re: Vixen Porta II head - 3/8" bolt? new [Re: Thomas Karpf]
      #5615434 - 01/10/13 12:29 PM
Tom,
Yes, it should work. Depending on the top surface of your tripod, make sure that there is plenty of bolt threads that turn into the Porta base. Also, it is always a good thing to make sure all threads are clean of any metal debris, etc. I always like to put a hint of grease on clean threads also. It spins easier and pulls tighter easier and will even help protect threads. I like at least 4 full turns of a bolt into a mount head. It simply gives more holding power and less likely to strip the threads. And if you have a spare 3/8-16 bolt just by itself, do hand thread that into the Porta first just to make sure threads are good.
Best, Linda B.
Thomas Karpf
Reged: 02/09/09
Loc: Newington, CT
Re: Vixen Porta II head - 3/8" bolt? new [Re: Agatha]
      #5615470 - 01/10/13 12:52 PM
Linda,
Excellent. Thank you. Spending an additional $80 for a tripod that I don't need seemed silly.
DavidNealMinnick
Reged: 03/06/06
      #5616388 - 01/10/13 10:14 PM
The Porta utilizes M10-1.5 threading.
Agatha
Reged: 06/04/12
      #5616679 - 01/11/13 04:28 AM
Tom,
Oh dear. David is absolutely right. I just seemed to remember the number 3/8 being thrown around when the Porta II came out. I liked my original Porta so much I purchased another one (Porta II). I've never had it on a different tripod. So, just now at 3:30 in the morning , I went and removed the head and checked the threads. Yes indeed. Definitely 10mm.
So, Tom, if possible, do change your tripod mount bolt to a 10mm X 1.5
A 3/8 will fit BUT it will be loose. The 10mm is correct and a proper fit.
Sorry for the confusion.
Best, Linda B.
Agatha
Reged: 06/04/12
Re: Vixen Porta II head - 3/8" bolt? new [Re: DavidNealMinnick]
      #5616685 - 01/11/13 04:38 AM
David,
Thank you for making the correction. I'm usually very particular with bolt threads, etc. I just went by what I remember hearing.
I still am surprised that the Tak Teegul uses a 3/8. At least, that is how it is described. A good reason to always check.
Thanks again.
Best, Linda B.
Edited by Agatha (01/11/13 04:52 AM)
Thomas Karpf
Reged: 02/09/09
Loc: Newington, CT
      #5616763 - 01/11/13 07:24 AM
David and Linda,
Thanks for the information.
19 registered and 43 anonymous users are browsing this forum.
