Napersky
Reged: 01/27/10
Loc: Chicagoland
Stellafane Mirror Test Stand
      #5616013 - 01/10/13 06:25 PM Attachment (85 downloads)
My completed Stellafane mirror test stand for my new 15" flat.
Napersky
Reged: 01/27/10
Loc: Chicagoland
Re: Stellafane Mirror Test Stand new [Re: Napersky]
      #5616016 - 01/10/13 06:27 PM Attachment (46 downloads)
Before the angle supports are cut.
Napersky
Reged: 01/27/10
Loc: Chicagoland
      #5616018 - 01/10/13 06:29 PM Attachment (36 downloads)
Assembled before glueing.
Napersky
Reged: 01/27/10
Loc: Chicagoland
      #5616020 - 01/10/13 06:31 PM Attachment (42 downloads)
Mostlu completed missing the top supporting rubber grommet.
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #5616927 - 01/11/13 09:45 AM
Mark,
If your going to use the flat for autocollimation testing, beside the up/down tilt adjustment screw on the back you'll need a method to adjust the tilt from side to side.
- Dave
kfrederick
Reged: 02/01/08
Re: Stellafane Mirror Test Stand new [Re: DAVIDG]
      #5616956 - 01/11/13 10:06 AM
That flat would make a great"Fundy" telescope fixed eyepiece The planet is the mounting .Could also try EDs window Chief idea . Nice setup Maybe you could start a "Rent A Flat"
Pinbout
Reged: 02/22/10
Loc: nj
      #5616963 - 01/11/13 10:13 AM
I ripped of Mr. Parkers AC to make a non perf AC.
still on the list of things to do...
Napersky
Reged: 01/27/10
Loc: Chicagoland
      #5616981 - 01/11/13 10:27 AM
Mark,
- Dave
Dave,
I have on the front of the tester two adjustible feet to move one up and the other down. Also from what I've read on the instructions for side to side I can just move the whole stand.
Mark
Napersky
Reged: 01/27/10
Loc: Chicagoland
Re: Stellafane Mirror Test Stand new [Re: Pinbout]
      #5616984 - 01/11/13 10:30 AM
Now that is cool. Also has the swivel for DavidG's "side to side" comment!
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #5617193 - 01/11/13 12:30 PM
Mark,
Trust me you'll need a way to precisely move the flat in both axis to get it aligned. Those rubber feet will grab and then let lose and you over shot and also get the up/ down alignement out of wack. Two adjustments screws for both direction will make life much easier. If the flat isn't aligned correctly, you see astgmastism which causes the Ronchi lines and interference fringes to bow which makes it difficult to determine if the errors are in the optics your testing or coming from alignment issues.
Dick Parker's portable setup is very well engineered. It takes about 30 seconds to get the alignment dead perfect since you can easily do tip/tilt and side to side adjustmenst using two threaded rods.
- Dave
Gary Fuchs
Reged: 05/22/06
Loc: Easton, PA, USA
      #5617270 - 01/11/13 01:17 PM
Here are some views of Dick's tester.
The extra threaded rods (on the left below) allow the mirror stand to be adjusted at longer distances.
For your setup you probably could have the tip/swivel controls on the inside and reach them from your viewing position.
I found what Dave G. described to be the case. If you don't have some sort of fine adjust for the swivel at least do something like a pin in the middle underneath and smooth bearing surfaces so you can push it smoothly to adjust.
The diagonal needs fine adjustability too...
Gary
kfrederick
Reged: 02/01/08
Re: Stellafane Mirror Test Stand new [Re: Gary Fuchs]
      #5617292 - 01/11/13 01:33 PM
Would not a Testing at the RC be more sensitive ??. I know it is a null test .Great test . Just ASKING a faint zone would the knife edge at RC be better to see?? You would know the zone was only on the mirror at the RC . Love to use the test only asking .
Pinbout
Reged: 02/22/10
Loc: nj
Re: Stellafane Mirror Test Stand new [Re: kfrederick]
      #5617307 - 01/11/13 01:44 PM
the AC doubles your error so they look twice as bad, but I heard Swayze say RoC is more sensitive.
You know that's a good reason to have the 3 test in your back pocket, to verify each other and rule out uncertainty, the KE, Ross-Null and AC.
the AC is so immediate with feedback, just opposite from what I'm use to so it can be disorienting.
Gary Fuchs
Reged: 05/22/06
      #5617321 - 01/11/13 01:53 PM
My guess would be that the AC flat (or Ross lens) can't introduce a zone; but I'd like to hear a definitive answer.
Gary
MKV
Reged: 01/20/11
      #5617923 - 01/11/13 08:11 PM
Gary
AC flats can depart from flatness by many waves, but their surface finish must be impeccably smooth. One way to check if the zone is introduced by the flat is to rotate the mirror. If the zone remains unchanged in the same location on the wavefront, then it must originate in the flat.
Napersky
Reged: 01/27/10
Loc: Chicagoland
Re: Stellafane Mirror Test Stand new [Re: MKV]
      #5619357 - 01/12/13 04:09 PM
Dave,
I need a mirror test stand for my interferometry. I do like Dick's mirror stand. I wonder does he have specific measurments and plans available such as for the Stellafane test stand I built?
Mark
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #5619404 - 01/12/13 04:37 PM
Mark,
I understand that you need the stand to hold your flat for interferometry, but the setup to test a mirror or lens using a flat and your interferometer is exactly the same as autocollimation just instead of using a Foucault/Ronchi tester it will be replaced with your interferomter. So your going to need to able adjust things with the same or better precision as what we do when doing autocollimation since you'll be looking at fringes.
I don't know if Dick has set of plans available.
- Dave
MKV
Reged: 01/20/11
      #5620136 - 01/13/13 02:24 AM
Gary, you are not looking at any optical surfaces but at a returning wavefront, whose quality is a sum-total of all the errors/deformations caused by individual optical components.
It stands to reason that a small, say, 1/30 wave valley on the flat will reflect off of it as a 1/15 wave local deformity on the wavefront and that it should be visible to an observer as a "zone".
Mladen
Pinbout
Reged: 02/22/10
Loc: nj
      #5620350 - 01/13/13 09:29 AM
I did another model more like his, the threaded rod ends in the dowel nuts so the stand can rotate as the screw is turned.
Gary Fuchs
Reged: 05/22/06
      #5620547 - 01/13/13 11:18 AM
Mladen
Thanks Mladen,
I'm in over my head so please bear with me; I'm thinking of a "zone" as an annular region of the mirror; and having trouble understanding how, say that valley on the flat, could cause a zone to show up if it wasn't there in the first place.
Gary
10 registered and 14 anonymous users are browsing this forum.
