Dave12345
Reged: 01/09/13
Best eyepiece sizes for viewing Moon close up? new
      #5617778 - 01/11/13 06:50 PM
Hi
I am just wondering if anyone has any general advice and experience of what the best sized eyepiece would be to get for viewing the Moon close up. Maybe a 4mm?
Tim2723
The Moon Guy
Reged: 02/19/04
Loc: Northern New Jersey
Re: Best eyepiece sizes for viewing Moon close up? new [Re: Dave12345]
      #5617814 - 01/11/13 07:13 PM
Dave, you need to make the calculations pertinent to the scope you choose. You can't really accomplish much before you decide on the scope you're buying. For the Moon I sometimes start with the maximum magnification my skies allow on good nights and work backward.
Does this mean you've decided on the scope?
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
      #5617825 - 01/11/13 07:20 PM
What telescope do you have; what's the diameter of the main lens or mirror, and what's the focal length or f/ratio? This will determine the range of eyepieces which will be useful, where you want to achieve a range of exit pupils between about 5-6mm down to 0.7mm. Bigger exit pupils are low power, and smaller exit pupils are high power.
Let's say you want to determine the highest useful magnification, where the exit pupil is 0.7mm. If your scope is a 6" f/8, the eyepiece focal length delivering a 0.7mm exit pupil equals the f/ratio times the exit pupil. And so f/8 * 0.7mm = 5.6mm. A 6mm focal length eyepiece would be the closest 'standard' focal length.
Dave12345
Reged: 01/09/13
Re: Best eyepiece sizes for viewing Moon close up? new [Re: Tim2723]
      #5617837 - 01/11/13 07:27 PM
Yes, it was between the Skymax 90 (EQ1) 90mm (3.5") Maksutov-Cassegrain an the Celestron Astromaster 90EQ... I am choosing the Skymax, becaus of portability etc, and it's suggested a few times by people, i've seen a picture of the Moon through that particular scope and i wes pleased with it, and because of it's potential stability for the purpose of photography. On the other hand the 90 eq has a slightly higher usefull magnification...
The Skymax 90
Dave12345
Reged: 01/09/13
Re: Best eyepiece sizes for viewing Moon close up? new [Re: GlennLeDrew]
      #5617853 - 01/11/13 07:33 PM
Hi
The telescope focal length is 1250mm (f/13.88)
Dave12345
Reged: 01/09/13
      #5617854 - 01/11/13 07:34 PM
Or maybe a 2x barlow?
mogur
Reged: 07/29/11
Loc: WI
      #5617901 - 01/11/13 07:59 PM
IMHO, a 7mm EP would give you pretty much the maximum (180x) power you will be able to use with that scope. Most times probably not that much even. A 9 or 10mm would also be a good companion.
Reged: 06/16/04
      #5617911 - 01/11/13 08:05 PM
Hi
Typical wisdom is 2x per millimeter of aperture, with a 90mm scope, that would be 180x. In your scope, that would be a 7mm. Short focal length Plossls, Orthos and the like, often have short eye relief, that can be uncomfortable.
Eyepieces like the TMB Planetary eyepieces have what amounts to a built in Barlow and maintain a reasonable amount of eye relief.
I like to have a number of magnifications available for viewing the planets.. some nights the atmosphere is stable, the images are stable and you can increase the magnification, some nights it's turbulent and lower magnifications are best. For a single higher power eyepiece, a 9mm would provide a reasonable magnification (140X) that could be used effectively most nights.
Dave12345
Reged: 01/09/13
Re: Best eyepiece sizes for viewing Moon close up? new [Re: Jon Isaacs]
      #5617948 - 01/11/13 08:24 PM
Thank's for the reply
Dave12345
Reged: 01/09/13
      #5617979 - 01/11/13 08:42 PM
How about 7.5? do ou know how the barlow efect is achieved?
Edited by Dave12345 (01/11/13 08:43 PM)
Dave12345
Reged: 01/09/13
Re: Best eyepiece sizes for viewing Moon close up? new [Re: mogur]
      #5617986 - 01/11/13 08:44 PM
Great, thank's for the reply
Tim2723
The Moon Guy
Reged: 02/19/04
      #5618380 - 01/12/13 01:56 AM
With mine, specifically on the Moon, I spend most of my time at 125x. The scope is especially comfortable there, sort of a 'sweet spot' for this particular scope (besides being a really nice view of the Moon). I think it comes with a 10mm, so don't spend a lot up front. You'll be surprised how little you need with this scope. I prefer a long eye relief EP, so I use an old Vixen Lanthanum, but the one it comes with is pretty nice for the price. Maks work well with the simpler designs too, so you don't really have to spend tons on the elaborate stuff unless you want something special like eye relief. Live with the scope for a while at first. Learn what it can do, learn what your skies are like. You'll be surprised how well you can do with just the set up as it comes.
I've taken the scope to 250x on good nights with perfectly acceptable results. It's 'empty magnification', but the scope can take it. At least on the Moon where there's enough light. Don't run out and spend money to do that, but if you end up with a 2x Barlow one day don't be afraid to try it.
Quinn
Reged: 03/19/12
Loc: California, Los Angeles
      #5618391 - 01/12/13 02:22 AM
G'Day Dave
The pictures of the Moon taken with a Orion starmax 90mm I posted in your
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5613806/page...
were taken through a Plossl 10mm 52mm aFOV EP. Using a 25MM Plossl EP would show the entire Moon.
CosmoSat
Reged: 07/24/09
Loc: India
Re: Best eyepiece sizes for viewing Moon close up? [Re: Dave12345]
      #5618395 - 01/12/13 02:45 AM
Pictures of the moon look great taken through almost any telescope irrespective of the design.
The EQ1 mount you are considering is definitely not stable enough for any descent astrophotography.
A telescopes potential magnification depends upon its aperture size, So both the 90mm scopes are capable of achieving the same magnification thought in the refractor the images may look sharper because of no central obstruction.
A 15mm eyepiece with a 2x barlow lens will will effectively act as a 7.5mm eyepiece.
I would suggest u have a look at this on too.. Celestron Powerseeker 114/900mm newtonian telescope.
Clear Skies!
Dave12345
Reged: 01/09/13
Re: Best eyepiece sizes for viewing Moon close up? new [Re: Quinn]
      #5618884 - 01/12/13 11:37 AM
Hi i didn'r realise you posted them, but i had a look, very nice, didn't know where the thread had gone. Thank's for posting, if i take any pictures i'lle upload them ;-)
Dave12345
Reged: 01/09/13
      #5618891 - 01/12/13 11:40 AM
Great ;-)
Dave12345
Reged: 01/09/13
Re: Best eyepiece sizes for viewing Moon close up? new [Re: CosmoSat]
      #5618898 - 01/12/13 11:43 AM
Clear Skies!
Thank's for the reply, the only problem with the Powerseeker is the size, and portabilty, or it deafinatley would be a consideration. What mount would you suggest?
Reged: 06/16/04
      #5619456 - 01/12/13 05:05 PM
Dave:
If I am not mistaken you are planning on purchasing the SkyWatcher Skymax 90 EQ1 90mm Maksutov Cassegrain Telescope. As I recall, you are hoping to take photos as well as just view the moon through the eyepiece and need a reasonably compact, portable telescope for under 200 pounds.
I think that the 90mm Mak is a very good choice. Maks are well suited for viewing the moon, there will be plenty to see. The EQ-1 is not a heavy duty mount but the StarMax 90mm is a nice, compact telescope, under 4 lbs and only 10 inches long, it does not tax the mount the way a longer, heavier Newtonian or refractor would. The Powerseeker 114 uses the same EQ-1 mount for a telescope that it about 36 inch long and much heavier.
As far as taking photos, it's always difficult but the moon is one of the easiest targets, its bright enough that you can use short exposures, I am sure that with time and practice, you will be able to take some satisfying photos of the moon.
As far another eyepiece, the Starmax comes with 25mm and 10mm eyepieces. That would provide you with 50x and 125x, those are actually quite nice magnifications for a 90mm scope. I would start with those.
Tim2723
The Moon Guy
Reged: 02/19/04
      #5619624 - 01/12/13 06:40 PM
One of the nice features of this little 90mm Mak is that it has a Vixen-style dovetail and a 1/4" socket, so it can go a lot of places. Even if the EQ-1 isn't the very best photo mount, the scope can still last a lifetime.
CosmoSat
Reged: 07/24/09
Loc: India
      #5619929 - 01/12/13 10:24 PM
I would always suggest an alt-az mount, easy to setup and use. Taking good pics of the moon is not difficult in a alt-az mounted scope even with a hand held digi cam.
And yes I am aware the 114 comes with the same eq-1 mount like the others u mentioned, but along with them, I just wanted u to have a look at(and maybe consider) the reflector too which has more light gathering power.
Clear Skies!
3 registered and 27 anonymous users are browsing this forum.
Moderator:  zjc26138, WOBentley, kkokkolis
