Privacy Policy |
Please read our Terms
of Service | Signup and
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
Finally Lassoed the Horsehead!
#5619154 - 01/12/13 02:15 PM
I recently took my 10" f/4.8 Dob to a yellow zone site to bag H400 objects. At first there were patchy clouds across the sky. But by 7:30 PM a strong west wind started blowing all those clouds away. The sky was transparent at least until the Moon appeared over the trees at about 1 AM. After finding and observing a couple dozen H400's, I decided to give the Horsehead Nebula (B33) a try before I headed home. I've tried to tease out B33 several times before at this site, but have never been successful. This night would be different.
The night was very transparent with poor seeing, as Clear Sky Chart had predicted. I swung the Dob over to Alnitak, Zeta Orionis. Attaching a spacing ring onto my 2" twist-lock adapter, I screwed a Lumicon H-Beta filter onto the end and slipped it all into the focuser. This setup would allow me to try several 1.25" eyepieces on B33 without having to remove the filter - and without hitting the filter with the end of an eyepiece.
The eyepieces I used were a UO Abbe Ortho 25, BGO 18, Brandon 24, Sterling Plossl 25.1 and XW20, in that order. I tried to select eyepieces that were somewhere around 24mm focal length - to give me about a 5mm exit pupil for my f4.8 Dob - as suggested by Barabara Wilson in this thread:
The Magic Horse Head Eyepiece
The following Megastar chart of the area posted by RolandosCY in another thread helped me tremenously in finding the Horsehead.
Bound and determined : Horsehead thru a ten..BUT..
This was the first night I recall ever seeing IC 434. Common sense would suggest that if you cannot see IC 434, you cannot see the Horsehead. So I always look for IC 434 first. If I don't see it, I don't bother looking for B33. That night IC 434 was fairly easy to see, though not as obvious as NGC 2024 northeast of Alnitak.
Many previous nights I could see NGC 2024 easily, but had no sign of IC 434. Now IC 434 looked like a faint wedge beginning west of Alnitak and extending southeast to a point. The area immediately to the east of IC 434 was clearly darker than that to the west. I used the Megastar chart to locate the Horsehead, situating it on the east edge of IC 434, south of an arc of four stars.
I also kept in mind that the apparent size of the Horsehead is about the same as the dark central area of NGC 2024. I glanced up at 2024 to get a check on the size of its central dark nebula before hunting the Horsehead. Of course, when actually trying to catch the Horsehead, I was careful to keep Alnitak and NGC 2024 out of the field of view.
The first eyepiece in the focuser was my UO Abbe Ortho 25. This was also the first eyepiece that ever showed me the Horsehead. I threw my DarkSky Apparel hood over my head to enhance my dark adaptation. I could just barely make out a slightly darker notch where the Horsehead was supposed to be. Bingo! Next I put in my BGO 18. As expected for an eyepiece with somewhat better coatings - fully multicoated instead of just multicoated - the Horsehead was somewhat easier to tease out from IC 434. (The higher magnification and narrower exit pupil may have helped a bit, too.)
Then I tried my Brandon 24mm. Mine has the amber coatings, which are supposed to be an improvement upon the older, bluish coatings. As expected given the Brandon's reputation, the Horsehead appeared more distinct than in either the UO Abbe Ortho 25 or the BGO 18. But the improvement over the BGO was subtle.
Next in goes my humble and inexpensive Sterling Plossl 25.1mm. Surprise! Best so far in show! The Horsehead was much more prominent than in the Brandon 24. Not a subtle improvement, but an obvious one. The large dark nebula immediately east of IC 434 was darker than in any of the other eyepieces. The outline of IC 434 was easier to tease out. And the Horsehead itself was a much more distinct notch in IC 434. At times, for an instant now and then, I could see a fairly clear outline of the Horsehead and even catch a glimpse of the snout. Very impressive, especially for an eyepiece which only cost me about $45 new!
Finally I tried my new acquisition, an XW 20mm. It has a 70 degree AFOV, so I had to be extra careful to keep Alnitak out of the field. This forced me to view the Horsehead rather close to the edge of the field, which probably had an negative effect on the view. But in any case, the XW 20 showed the Horsehead well. However, I would give it second place to the Sterling Plossl. Maybe if I'd used an XW closer to the magical 24mm, it would have performed better. But you gotta run the horses you've got.
I regret that I did not think to try my Televue Plossl 25mm on the Horsehead. That eyepiece never left the stable except to prime my Paracorr when going after the H400 objects. I didn't use the Paracorr either in viewing the Horsehead.
Here is a rundown of the eyepieces I used, showing their focal lengths, coatings, AFOV, and the TFOV, magnification and exit pupil in my 10" f/4.8
Dob, as well as my overall grade of their performance on the Horsehead Nebula (B33).
Eyepiece________Coating_____Mag______EP_____AFOV_____TFOV_____Grade
UO 25mm_________MC_______48x_______5.2_____47________59________C
BGO 18mm________FMC______67x_______3.8_____42________37________C+
Brandon 24mm_____FC_______50x_______5.0_____44________53________B
Sterling 25.1mm____FMC_____48x_______5.2_____58________73________A
XW 20mm_________FMC_____60x_______4.2_____70________70________B+
MC = Multi-Coated
FC = Fully Coated
FMC = Fully Multi-Coated
EP = Exit Pupil in mm
AFOV = Apparent Field of View in degrees
TFOV = True Field of View in arcminutes
One consequence of this comparo for me has been that I've taken the UO Abbe Ortho 25mm out of my deep sky eyepiece case. I have a pair of these. I'll keep them for binoviewing planets and the Moon, but not for viewing DSO. And I've decided to keep all my Sterling Plossls - 12.5 to 25mm - in the case for deep sky observing.
Clear Skies
IVM
Reged: 01/07/08
Loc: Western New York
Re: Finally Lassoed the Horsehead!
[Re: Sarkikos]
#5619392 - 01/12/13 04:29 PM
Interesting comparison, and well done on the Horsehead!
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
[Re: IVM]
#5619675 - 01/12/13 07:11 PM
Did you go back to the earlier eyepieces again, so as to verify it wasn't mostly a case of improved conditions or improved dark adaption?
Patricko
Reged: 01/30/07
Loc: USA
[Re: Sarkikos]
#5619811 - 01/12/13 09:07 PM
Congratulations Mike! I've only tried seriously a few times to bag this object. IC 434 has been observed from mag 6.75 sites with scopes as small as 50mm. I have tried with a Carton 60mm f/16.7 refractor but had no luck, this was at a mag 6.4 site. On a less than agreeable night I tried for about 15 minutes with my C6 SCT, again the brighter area of IC 434 was seen, so was NGC 2023 but no B33. With all instruments NGC 2024 was easy and even quite apparent in cheap ($24) "10x50mm" binoculars from these observing sites. With 15x70 BA8 binoculars NGC 2024 is ridiculously easy. So why am I missing B33? Maybe it is because I lack the proper filters as I have none, or perhaps my aperture is not large enough to match my skill. I will continue to try and make this DSO a top priority the next clear night out. BTW, I have a 25mm Sterling "Plossl" and is shows more color saturation in M42 than in any other eyepiece I own except for maybe a 26mm Meade 4000 Series 4-element JAPAN "Plossl". An exceptional DSO eyepiece by any standards IMHO.
Edited by Patricko (01/13/13 01:14 AM)
azure1961p
Reged: 01/17/09
Loc: USA
[Re: Patricko]
#5619901 - 01/12/13 10:07 PM
Mike,
Very well told. I enjoyed the workings-out of what worked best and why along with the surprise results.
Pete
Sarkikos
Reged: 12/18/07
[Re: GlennLeDrew]
#5620088 - 01/13/13 01:06 AM
Glenn,
I was wondering when someone would ask this question ... but I was pretty sure it was going to be you to ask it!
Well, the answer is, no, I didn't. My primary purpose that night was to bag H400 objects. I was able to locate and observe 25 more of them. Hunting for the Horsehead, and then comparing how it looked in different eyepieces, was a sideshow for trick ponies, not an act for the center ring. Besides, 25 mph gusts and temps in the mid-20's do not encourage exhaustive scientific controls. My observations are what they are.
However, I did spend nearly an hour on the Horsehead and the five eyepieces. For me, that is an enormous investment of time on any object that is not a planet or the Moon. I didn't start observing the Horsehead until about 10:45 pm, so my eyes had been dark adapting for over four hours. Also, over the course of my observations of the Horsehead, the sky was consistently transparent.
And for what it's worth, at the beginning of each observation with each new eyepiece, I would get my bearings by going back to Zeta Orionis (my Dob does not track). Even through an O-III filter, I'm sure this reset my eyes to an adequate base-line level of dark adaptation. Then, before I started viewing the Horsehead again with each eyepiece, I put the Dark Apparel hood back over my head to help my eyes dark adapt better and to shield them from ambient light.
I'm confident my report gives a good representation of the relative ability of these five eyepieces to present an image of the Horsehead Nebula. I've already made changes in my deep sky line-up of eyepieces based on the results.
2 registered and 4 anonymous users are browsing this forum.
Moderator: Dave Mitsky, okieav8r
