rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: My M42 final?? for 2013 HARGB new [Re: jaddbd]
      #5623160 - 01/14/13 05:59 PM
Nice! I really like how you maintained the core and still went deep with it.
John D
Thanks John! Lots of different exposures and layer masks! I really want to try a close up of the Trapezium sometime.
alpal
Reged: 06/15/09
Loc: Melbourne Australia.
Re: My M42 final?? for 2013 HARGB new [Re: rigel123]
      #5623783 - 01/15/13 02:58 AM
Looking nice - I want to do a good one of M42 too.
Would 5 hours of data be enough?
Thanks! It will depend upon your skies, if you have dark skies 5 hours would work well. If you are doing mono then put most of the time into Luminance (HA in my case) so you get the details you want. Half of my total time was done focusing on the HA which I used as the Luminance channel.
What about gathering Luminance but with my light pollution filter?
It's a 2" CLS-CCD from Astronomic.
Leonardo70
Reged: 04/16/09
Loc: Turin - Italy
      #5623803 - 01/15/13 04:02 AM
Really nice..
All the best,
Leo
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: My M42 final?? for 2013 HARGB new [Re: alpal]
      #5624009 - 01/15/13 08:53 AM
If you are using an LP filter then you will need longer exposures to get the deep stuff but the filter should allow that. My suggestion would be to first grab your short exposures in each channel for the core. I do 10 seconds and that is pretty good to keep the core from blowing out and it doesn't take long to get 30 subs for each channel. Then try 2 minutes for the inner portions of the nebula and then finally go as long as you can without saturating the image with sky glow. 5 minutes was good for me and I am highly light polluted, but I was using an HA filter and the light pollution has little effect on it. If you can see the faint nebulosity at the top of the nebula in your sub at 5 minutes you should be good, but you will need at least 2 hours in my experience to get a clean background. Your chrominance you can typically get away with less and I blur mine so that no noise comes through the Luminance layer when I blend them together.
Hope this helps!
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: My M42 final?? for 2013 HARGB new [Re: Leonardo70]
      #5624012 - 01/15/13 08:54 AM
Thanks Leo!
SGT500
Reged: 10/03/06
Loc: Sarasota, Florida
      #5624160 - 01/15/13 10:44 AM
Hey Warren,
Excellent job on this imge!!! The colors and contrast look really good. My only suggestion would be to layer a little additional hydrogen alpha data into the red channel. This will give you some nice rich saturation to the dimmest areas. Just my constructive input, though much astronomical image processing boils down personal preference .
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: My M42 final?? for 2013 HARGB new [Re: SGT500]
      #5624294 - 01/15/13 12:14 PM
Hey Warren,
Thanks Sal, I actually thought about the same thing and will give it a try.
Here is what I came up with after following Sal's suggestion. Subtle, but that one area definitely came out better with more saturation than before. Thanks! Flip between the B and C image and you will see the change.
Edited by rigel123 (01/15/13 01:10 PM)
alpal
Reged: 06/15/09
      #5624677 - 01/15/13 03:45 PM
Warren,
Hope this helps!
Thanks Warren.
I think I will use the LP filter just to see what happens.
Maybe Ha on 2x2 binning would be good too -
I could divide the time by 4 necessary for a good signal but
of course lose a little resolution.
cheers
Allan
rigel123
Reged: 06/29/09
Loc: SW Ohio
      #5624842 - 01/15/13 05:32 PM
Warren,
Hope this helps!
Thanks Warren.
cheers
Allan
You should not have to bin your HA, it will come through strong even with LP. I used HA totally as my Luminance, no LP filter necessary.
JoseBorrero
Reged: 09/04/09
Loc: Puerto Rico Island
      #5625424 - 01/15/13 11:11 PM
Love it!
Harel_Boren
Vendor-The Boren-Simon PowerNewt Astrograph
Reged: 03/15/09
Loc: Israel
Re: My M42 final?? for 2013 HARGB new [Re: JoseBorrero]
      #5625675 - 01/16/13 06:09 AM
Warren,
This is so well done... I just love the fact that when trying to focus my vision and see the trapezium - it is actually crisply there!
Harel
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: My M42 final?? for 2013 HARGB new [Re: Harel_Boren]
      #5626277 - 01/16/13 02:13 PM
Thanks Jose, Harel!
Harel, I actually thought 10 sec exposures were almost too much to keep the Trapezium how I wanted it!
roryt
Reged: 10/31/07
Loc: Athens, Greece
      #5626323 - 01/16/13 02:47 PM
Awesome, just awesome!!!
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: My M42 final?? for 2013 HARGB new [Re: roryt]
      #5626718 - 01/16/13 06:12 PM
Thanks John!
18 registered and 23 anonymous users are browsing this forum.
Moderator:  Oldfield, Scott in NC, bilgebay, WOBentley
