pjglad
Reged: 01/29/11
Orion RDF Mounting Question new
      #5623164 - 01/14/13 06:05 PM
Currently, I have an Orion RDF (Orion EZ Finder Deluxe II Telescope Reflex Sight) at the 1:00 position on my CPC800. I would like to mount it at the 12:00 position, but the holes are spaced to far apart for the base. Any suggestions? Thanks.
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
Re: Orion RDF Mounting Question new [Re: pjglad]
      #5623373 - 01/14/13 08:33 PM
Those centerline screws on the CPCs are for mounting a dovetail plate for piggybacking photo gear or a small refractor. I suppose you could just use one hole and snug the RDF down real tight, or maybe try some double-sided adhesive like what some people use to mount a Telrad. I'm curious why you would want it center-mounted, as finders offset to one side or the other seem easier to use that the neck-cricking top position.
pjglad
Reged: 01/29/11
Re: Orion RDF Mounting Question [Re: MikeBOKC]
      #5623485 - 01/14/13 09:45 PM
Currently, I have a RACI at 11:00 and an RDF at 1:00. I plan on replacing the RDF with a StarSense. In the event the StarSense does not align then as a fallback, I would like an RDF so I can do a two Star alignment. Per the press release, StarSense is mounted at 1:00.
9 registered and 25 anonymous users are browsing this forum.
Moderator:  Brian Risley, panhard, Mitchell Duke, mayidunk
